tell me what you think of this mix
Heres a song i recently recorded of my friends
http://www.soundclick.com/bands/page...?bandID=644522
My Band: Aqueous - www.aqueousband.com |
that's a cool song! the biggest thing about the mix is the drums are getting drowned out. the gits and the bass are coming through...the snare is almost all i can hear, and it sounds a little strange. great song though, the solo is awesome ! would love to hear that redone! keep working on it ...
JasonBird |
on my system...
the snare is generally to loud and isolated little to no kick the main vox ambiance doesn't seem to fit the backing vox needs balancing with the main vox... often it's over powering sections do sound very good though |
thanks guys for all the info, yeah i need to work on mixing those drums in better. This is a song my friends wrote, they have a few others that are really cool, im sure they will be recording them here soon, i'll be posting
Hi Nick.
I love the preformance. I have a few nits with the mix though. First of I would try to get it to sound tighter. just start with the Kick drum and snare, get it to sound powerfull, and level. Then add the rest of the drum mikes-(tracks) then I usually add bass, and there if your succsessfull you`ll have a foundation. Its usually wise to pan the kick sanre and bass guitar center. Then add guitars, thats the way I do it anyways. Then last vox, when it all is up, you probbabbly need to raise some tracks and lower others. Btw the vox, are way to wet. My sorta preset on vox is allways; Cut@100hz and then a little raise between 3000-5000 for prescence. And increase on 200hz helps giving the voice some more body if needed. Then I use a carefull amount of compression, (just play around with it). Then lastly I add some verb, usually medium room for starters, with a blend\mix at 15%. Anyways you probbably know all of this, or know better But thats my 2cents. Anyway my main thought on your mix, is get it a tad tighter cheers buddy ![]() Btw be carefull with the use of eq, and verb\delay it can really destroy a mix ![]()
Buy My Record, or APL will think your a douche, Rami will kill you and Gerg will yell at you real hard. http://daccord-music.com/?p=30 |
yeah i loaded delay on the vocals just to give it a unique sound but ill take that off ... thanks for the post NAK. its a very loose mix and things arent really panned right. Im gonna fix these things and ill repost !
Hi hi :
Some comments: Snare : I think it sounds good but it is just containing a fq that dominates the entire snare sound. Just sweep trough it with a 12dB boost an listen till the snare sounds ugly as hell. Will probably be around 300-700, then cut this fq, DONT overdo it otherwise it will sound thin. Also I think you did a 2k boost which is bit too much, maybe the cut will accentuate the 2k range by cutting another I dunno :P Same technique for the toms (they usualy benefit from a tiny 10k boost and some 3-4-5k ) Bassguitar sounds really nice but I think it's fighting with the kickdrum ![]() Guitars: Sound good for this style , the harmonics at the end are really cool Vocals: As said too wet while the backings are too dry switch them and you'll be fine !!Lead Guitar solo: Cool solo nice sound , a tiny bit of echo on it and turn it up and it will be blowing in your face. Nice songwriting and producing: The piece really keeps your attention... I don't have any experience in this kind of music but strangly It reminds me a bit of Paul Gilbert songwriting meets CCR sound?!. I could be way off tough ![]() |
| Soundtracs Topaz Project 8 | Nick The Man | Other Equipment and Reviews | 30 | 04-08-2008 14:02 |
| Can I get the right way to mix or a process I should use to mix correctly. | PaulKarate | Mixing / Mastering | 6 | 12-12-2005 11:24 |
| Breaks Mix - Feedback wanted. | digital_age | MP3 Mixing Clinic | 0 | 11-28-2005 14:09 |
| I really need some help with technique. Looking for pointers. | Lempface | Recording Techniques | 17 | 08-29-2005 17:09 |
