Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 12-29-2006
sirslurpee sirslurpee is offline
What does THIS button do?
sirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond reputesirslurpee has a reputation beyond repute
G1 or G2 coated?
Okay I need some opinions and info quick..
I might be going to pick up some new heads for my kit today, and I want to get evans g1s or g2s. Coated. I'm going to pair them with genera resonants on the other side..
Anyway, I am thinking that I want g1s because I don't want to choke the tone too much. I like them a little ringy but I think the single ply coated will kill the unwanted overtones and still give the drum room to breathe. Would a 2-ply head choke it off more? or am I just making bad assumptions?
What do you guys think?
My kit is a pacific CX maple btw, and I am using 8/10/12/14/16 toms..
Old 12-29-2006
Blue Groove's Avatar
Blue Groove Blue Groove is offline
Dedicated Member
Blue Groove has a reputation beyond reputeBlue Groove has a reputation beyond reputeBlue Groove has a reputation beyond reputeBlue Groove has a reputation beyond reputeBlue Groove has a reputation beyond reputeBlue Groove has a reputation beyond reputeBlue Groove has a reputation beyond reputeBlue Groove has a reputation beyond reputeBlue Groove has a reputation beyond reputeBlue Groove has a reputation beyond reputeBlue Groove has a reputation beyond repute
The G2s are still going to sound fairly open, with more control. They will sound fuller. The G1s will be wide open, with less control. They will sound a little thinner.
My opinion is the G2s, not that the G1s wouldn't work okay. The reason is maple shells, and also the stuff I play (plus I use DWs, the G2s just soud fatter on them)
Try one of each on a floor tom, see which one you like better that way. Also listen close and far away, you may find one sounds better at a distance.
Good luck
Old 01-03-2007
JoeyPazera's Avatar
JoeyPazera JoeyPazera is offline
Senior Member
JoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond reputeJoeyPazera has a reputation beyond repute
g2 coated on bigger toms
g2 clears on racktoms
Pearl SMX Green Burst
10, 12, 13, 16, 22
Pearl Steel Picillo 13 x 3
Zildjian A and K customs
Alesis MultiMix 16
M-AUDIO BX8a's
Old 01-04-2007
well.. it looks like I don't have enough money now to do anything more than the 14" and 16" toms, but that's all I'm playing with right now anyways...
Also I'm tossing up between aquarian regulator and evans emad resonant kick head. I already had a regulator on it and it sounded pretty good but I am just wondering if the emad/emad pair will sound better...
Old 01-04-2007
MrKwik's Avatar
MrKwik MrKwik is offline
**will man ho for gear**
MrKwik has a spectacular aura aboutMrKwik has a spectacular aura aboutMrKwik has a spectacular aura about
I use G2 clears on top and G1 clears on bottom. The sound is plenty open for my taste. I think I am going to try G2 coated batters next time though. The clears gave me the sound I wanted at the time but now I want a little warmer sound. The clears are fairly bright.
My drums
Old 01-10-2007
laststartoshine laststartoshine is offline
Junior Member
laststartoshine has a reputation beyond reputelaststartoshine has a reputation beyond reputelaststartoshine has a reputation beyond reputelaststartoshine has a reputation beyond reputelaststartoshine has a reputation beyond reputelaststartoshine has a reputation beyond reputelaststartoshine has a reputation beyond reputelaststartoshine has a reputation beyond reputelaststartoshine has a reputation beyond reputelaststartoshine has a reputation beyond reputelaststartoshine has a reputation beyond repute
personally i think the eMad just takes away a lot of tone and volume out of the drum. too much dampening, the superkick II and Regulator work beautifully together.
My Band - Rochester
Old 01-12-2007
Dedicated Member
The EQ3 and 4 are both really good heads too... I use the EQ3 on most kicks. Good control, killer tone, the emad is overrated.
Coated Ambassador as a resonant? RFrecordings Drums and Percussion 1 08-24-2006 17:10
remo coated emperor drumheads my2cents Drums and Percussion 3 09-16-2005 16:43
Coated Heads, Heavy Sticks, and Heavy Music gumplunger Drums and Percussion 6 02-14-2005 19:59
What's better for recording....coated or clear tom heads ruebarb Drums and Percussion 3 09-06-2001 10:58
G2 Coated Or Uncoated Tekker Drums and Percussion 9 03-26-2001 15:15
