Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 12-28-2006
larry_emder larry_emder is offline
Newbie
larry_emder has a reputation beyond reputelarry_emder has a reputation beyond reputelarry_emder has a reputation beyond reputelarry_emder has a reputation beyond reputelarry_emder has a reputation beyond reputelarry_emder has a reputation beyond reputelarry_emder has a reputation beyond reputelarry_emder has a reputation beyond reputelarry_emder has a reputation beyond reputelarry_emder has a reputation beyond reputelarry_emder has a reputation beyond repute
Using a 2 conductor (mic) cable as a guitar cable
Went to my local electronics store today to get some single conductor co-axial cable, but they didnt have any. Spoke to one of the salesmen and he told me i could use a 2 conductor cable instead - by wiring the two inside wires to the hot connection.
He also said that this works even better than a single conductor cable, by reducing hum (in some way...he didnt explain it any further)
So my questions are:
Can i use the 2 conductor cable with a mono 1/4" plug, by wiring the 2 inner wires to hot?
And
Will it be less susceptible to hum, as Mr. salesman stated?
Thanks if you can help!
Old 12-28-2006
travelin travis travelin travis is offline
Banned
travelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond repute
I've done it and noticed no benefit or ill effect.
Old 12-28-2006
Track Rat's Avatar
Total Gear Slut
The cables I'm using right now are old mic cables for no other reason than I had some mic cable and needed instrument. As stated no difference that I can hear. They are beefy though.
Mike
Old 12-28-2006
antichef's Avatar
antichef antichef is offline
unfocuser
antichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond repute
"balanced" cables may hum less than "unbalanced" cables, and arguably, the TRS (tip-ring-sleeve) mic cable is balanced, while a TS (tip-sleeve) instrument cable is not. By resoldering the mic cable, I think you're turning it into an unbalanced cable, though, since the same signal is traveling through both wires (essentially just making the wire twice as beefy), so I wouldn't expect a difference in hum.
Old 12-28-2006
Newbie
Thanks for the quick responses dudes.
About to plug in the iron
Old 12-28-2006
Richard Monroe Richard Monroe is offline
Been Here, Posted That
Richard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond repute
It will work fine, but if you had hum before, you will probably still have it. And it will *not* balance the signal, which might get rid of *some* kinds of hum, especially with long runs of cable.-Richie
Old 12-28-2006
Banned
keep it clean and hot, tin everything, and avoid getting an eye hit.
I Totally Rule (another Variax thread) chrisharris Guitars and Basses 210 11-01-2006 21:11
Lightsnake USB to Guitar Cable Nilbog Other Equipment and Reviews 2 05-11-2006 04:01
midi filter for guitar syntch and fx crosstudio MIDI Mania 1 03-18-2006 15:26
Speaker Cable Gauge - Long run to Guitar Cab. WERNER 1 Guitars and Basses 4 03-18-2005 16:15
I don't feel like a guitar player..... UberGawkman Guitars and Basses 12 05-14-2002 14:08
