Old 12-27-2006
Rocket Boy's Avatar
Rocket Boy Rocket Boy is offline
Force of Nature
Rocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant future
Tascam 38 not recording?
I just got a Tascam 38 that I was told was basically used once, then wrapped in plastic and sat in storage for many years. It looks cosmetically brand new. My only problem so far, is that I can't seem to record anything. I'm really hoping this is my fault somehow - although the operation of the machine seems pretty straight forward.
I put it in sync mode, I can hear my signal... I then press the function button for the track which then lites up... I press pause & record which lite up as well... after recording I put it into repro mode and I get no signal either on the meters or through the audio. What gives? Is there something I'm missing? I'm using Quantegy Gp9 tape.
Old 12-27-2006
_DK's Avatar
_DK _DK is offline
Dedicated Member
_DK has a reputation beyond repute_DK has a reputation beyond repute_DK has a reputation beyond repute_DK has a reputation beyond repute_DK has a reputation beyond repute_DK has a reputation beyond repute_DK has a reputation beyond repute_DK has a reputation beyond repute_DK has a reputation beyond repute_DK has a reputation beyond repute_DK has a reputation beyond repute
Assuming everything is connected properly and there's nothing wrong with cables.
Does the VU meter for the selected channel show any input?
Is there any output on playback in the Sync mode? You don't have to go to Repro all the time.
Have you tried recording to all channells in the Input mode and then going to Sync or Repro and checking every channel for output?
Old 12-27-2006
Rocket Boy's Avatar
Force of Nature
There is activity on the meters when recording, and I know the cables are ok because the outputs are going through my mixer as I record - so I can hear them. No difference in repro or sync.
Old 12-28-2006
FALKEN's Avatar
FALKEN FALKEN is offline
FALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond repute
Hi Rocket Boy. I am really confused by this sentence:
-so far so good
-wait a minute right here. you should have had the function button pressed already to be able to hear anything. how did you hear anything without the button pressed.
-once again, you should have already been in record mode to hear anything!
-did your machine come with the manual?
Old 12-28-2006
Rocket Boy's Avatar
Force of Nature
Yes, it did. Which I read. Let me rephrase this in the exact order I do it in...
1) enter sync
2) function select the track i want to record onto - at this point I can hear the signal, and see activity on the meters.
3) press pause & record which both lite up.
4) press play, at which point the function light for the track turns solid and the reels start turning. The record light is also solid.
Then, either in sync or repro mode when playing back I do not hear any signal. It doesnt matter if the function select button is on or off at this point. I also dont see any activity on the meters.
It seems pretty straight forward - but is there something I could be missing?
Old 12-28-2006
Rocket Boy's Avatar
Force of Nature
Could I be using the wrong tape?
Old 12-28-2006
MCI2424's Avatar
MCI2424 MCI2424 is offline
1K Silver Member
MCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond repute
#1 - Yes, you are using the wrong tape. Use 456. You should at least get SOME signal however bad it may sound (bias not set right for GP9)
#2 - Make sure all relays "click" when you select the track to record. If the relays are sticking (doubtfull ALL are bad) or the enable signal is missing, the track will not record.
#3. Verify your playback head is working. Use a reviously recorded tape OR a weak magnetic force (like a soldering iron) Bring it close to the playback head (with the deck in the play mode) You should hear a "hum". If all is well here, then you must use a O-scope with a schematic to verify the master bias oscillator is working OK. The oscillator is responsible for introducing AC bias to "excite" the signal that gets printed to tape. I am suspicious because of no recording on ALL tracks that the relay signal or bias oscillator may be bad.
#4- Suspect any and all electrolytic caps. Stored long enough, some might be shorted, leaky etc. Some machines use an electro cap for filtering or timing digital signals (like the relay circuits) and if they short, the signal is stuck low (or high) depending on the design. The worst case for electro failure is stored unpowered for too long.
You should get a manual for further probing.
Good Luck
Added Note: Make sure you threaded the tape right and you are not recording on the WRONG SIDE.
This DOES happen.
"Tascam, Fostex or Studers don't make hit records...........people do"
MCI2424 - 2007
Old 12-28-2006
Rocket Boy's Avatar
Force of Nature
Okay. I tried playing back a previously recorded tape and that seemed to work fine. The shiny side of the tape is pointing up towards the heads. I thought when I turned it up really high I could hear a little bit of what I had recorded - so maybe I just need to get some 456 and try that.
Old 12-28-2006
MCI2424's Avatar
1K Silver Member
The bias amplifiers in that deck are waay too weak for GP9 then. It happens. 456 should clear it up.
MCI2424 - 2007
Old 12-28-2006
Rocket Boy's Avatar
Force of Nature
hooked in 456, no change... but i can hear what was recorded on it before years ago.
Old 12-28-2006
MCI2424's Avatar
1K Silver Member
So, you are looking at the recording circuit then. You need a manual and an O-scope. All in my above post.
MCI2424 - 2007
  #12
Old 12-28-2006
cjacek's Avatar
cjacek cjacek is offline
Analogue Enthusiast
cjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond repute
Which shiny side is touching the heads ? The black or brown side ? It should be the brown.
  #13
Old 12-28-2006
Herm's Avatar
Herm Herm is offline
1K Silver Member
Herm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond repute
Check and make sure your tape lifters are going all the way up and allowing the tape to make good contact with the heads. They can hang up
  #14
Old 12-28-2006
Beck's Avatar
Beck Beck is offline
Analog Partisan Ranger
Beck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond repute
Something else to check…
When you lift the head cover there is also a Record/Sync head shield you have to flip down. The Record/Sync head is the middle of the 3 heads. If you fail to lift the head cover and release the shield while threading the tape, the tape won’t make contact with the record head.
«:: «::B::» «::E::» «::C::» «::K::» ::»
"Where in the hell are the red M&M's?"
~My Lil' Sister, 1976
  #15
Old 12-28-2006
The Ghost of FM's Avatar
The Ghost of FM The Ghost of FM is offline
French Mofo
The Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond repute
This sounds like the tape is being threaded wrong by the user and is inadvertently being played/recorded on the backing side of the tape.
Result; no recording is being made as there is no oxide on the backing side of the tape.
Cheers!
  #16
Old 12-28-2006
cjacek's Avatar
Analogue Enthusiast
Precisely my thought too.
  #17
Old 12-28-2006
beyond_therapy's Avatar
beyond_therapy beyond_therapy is offline
Junior Member
beyond_therapy is on a distinguished road
had a problem like this with my tascam34 it was a relay issue, although the tape upside down would also cause problems.
  #18
Old 12-29-2006
_DK's Avatar
_DK _DK is offline
Dedicated Member
Cheers!
He wouldn't have heard the old recording on that 456 if it was upside down.
  #19
Old 12-29-2006
Herm's Avatar
1K Silver Member
This has made me get my manual out and read some things and after alot of recording on the 38 I noticed that they mention to use the sync head for most functions.
Now I have always used the repro head for mixing and such so my question is have I been doing it wrong all this time or does it really matter?
  #20
Old 12-29-2006
_DK's Avatar
_DK _DK is offline
Dedicated Member
I haven't done any research on that, but I can hear small difference in sound between the Sync and Repro modes. Not sure why though. There's mode lows in Sync mode, but hardly noticeable.
  #21
Old 12-29-2006
Lt. Bob's Avatar
Lt. Bob Lt. Bob is offline
Spread the Daf!
Lt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond repute
you should always use the repro head for mixing.
  #22
Old 12-29-2006
_DK's Avatar
_DK _DK is offline
Dedicated Member
You mean the repro mode?
That explains why it is there But what's the difference from the sync mode?
  #23
Old 12-29-2006
MCI2424's Avatar
1K Silver Member
The synch head is not optimized for playback. It is only for reference when overdubbing. Recording heads are designed differently and play back on a record head is (electrically) a sonically lower quality sound. You want the optimization to be in the "record" mode.
The "repro" head is designed for sonically acceptable playback of the recording.
The "synch" head is a compromise in favor of the record function.
MCI2424 - 2007
  #24
Old 12-29-2006
Lt. Bob's Avatar
Spread the Daf!
yes ..... the 'sync' head is actually the recording head ..... there is no seperate synch head ..... they use the record head for playback during recording so the new tracks will be in synch with the old tracks.
  #25
Old 12-29-2006
A Reel Person's Avatar
A Reel Person A Reel Person is offline
It's Too Funky in Here!!!
A Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond repute
Arrow
I'm sorry,... [MCI] The 38 was engineered specifically to overcome the sync-head limitations of previous recorders. The Sync and Repro heads are exactly the same, as are the amp circuits, (relatively speaking). Both are optimized for playback and are virtually equal. [Lt. Bob] There are 3 heads: Repro, Sync & Erase. Repro & Sync are the same part #, but have their own support circuitry on the amp-card.
Granted, to get true "sync" function, you must use the "Sync" head, but the Repro and Sync on the 38 heads should have virtually the same freq. response.
Sorry if I've not addressed the main subject of this post!
Maybe later,...
C'ya!
Beatles and other Classic Rock covers!! Yeah, Yeah, Yeah!!!
637 songs by 191 bands.
tascam 788 analog recording question captain max TASCAM User Forum 5 05-28-2005 06:20
tascam US 122 Recording Problem Help? thegermnyc TASCAM User Forum 1 05-24-2005 07:24
tascam US 122 Recording Problem thegermnyc Analog Only 1 05-23-2005 18:18
Tascam 122 MKII Recording Levels?? MiXit-G Analog Only 8 02-21-2005 00:07
