Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 12-26-2006
kurtteej kurtteej is offline
Newbie
kurtteej can only hope to improve
dumb question.
Are microphone cables all created equal?? I'm in the process of setting up a small studio to record a radio show. I've got a few shure microphones (57s or 58s) but I've also got a few condenser microphones. I have 4 mic cables and only 2 of them seem to be working with the condensers.
To use the condensers (with 48v phantom power on the mixer), do I need a specific type or just a high quality cable? I was switching on the phantom power on the board and the condenser would work for a little while and then the volume would begin to fade out until there was nothing. After I switched to a different cable -- the phantom power now stays on.
Old 12-26-2006
scrubs's Avatar
scrubs scrubs is offline
Not of sound mind
scrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond repute
First off, no, all cables are not created equal. Secondly, it is possible for a cable to fail/short/go bad. Thirdly, some cables are wired differently for certain types of routing purposes.
You should be looking for XLR-XLR mic cables (cables with 1/4" connections will not carry phantom power). If you're having problems, test the cables and/or replace them. If the new cable is working, the other one probably was bad.
A good source for cheap, durable mic cables is Audiopile.
"That was so terrible, I think you gave me cancer!"
My tunage
Old 12-26-2006
hairylarry hairylarry is offline
Force of Nature
hairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond repute
GLS? Musicians Friend?
Hi,
Speakerrepair on ebay sells 10 GLS 25' XLR cables for $50. Has anyone used these? Are they as good as he claims? Here's his home page.
http://speakerrepair.com
Then I noticed Musicians Friend now has 10 20' XLR cables for $50. Same questions.
http://www.musiciansfriend.com/produ...ck-?sku=360433
and here
http://www.musiciansfriend.com/produ...ack?sku=338006
And finally I was checking the Musicians Friends guitar strings and I noticed they had the exact spec and description as Ernie Ball Earthwood's that I love. Do you think Ernie Ball makes Musicians Friend strings?
Thanks,
Hairy Larry
http://deltaboogie.com/hll/72_hairy_larry_wild.jpg
I've been making a video a day - http://archive.org/details/vidpods
Promote your act at Delta Boogie - http://deltaboogie.com
Share your media at MixRemix - http://mixremix.com
Old 12-26-2006
MCI2424's Avatar
MCI2424 MCI2424 is offline
1K Silver Member
MCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond repute
Open up the cable connectors and visually inspect the soldering. Also, old XLR connectors tend to oxidize. Look at the pins very carefully under magnification. If you see black crud, you will have to clean them with a de-oxidizing spray. Both female as well as male pins suffer. Resoldering is a good idea anyway. The worst case is if any one of the 2 signal pins gets shorted to ground. Your mic diaghram can go poof.
"Tascam, Fostex or Studers don't make hit records...........people do"
MCI2424 - 2007
Old 12-26-2006
travelin travis travelin travis is offline
Banned
travelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond repute
Originally Posted by hairylarry
Hi,
and here
Thanks,
Hairy Larry
Hairy Larry, the GLS cables are very decent but the connectors fit a little tighter than I'd like them to. I think they're a hell of a deal for the price though. I cut some of them up to make 1/4" and phono cables using some Neutrik plugs that I got from Mouser for about a buck a piece. I ended up with a bunch of good cables for very little money.
The Musicians Friend cables are typical ultra cheapo cables. They are the same quality as the mic cables from wally world. The cable is thin and the connectors are light.
Old 12-26-2006
cusebassman's Avatar
cusebassman cusebassman is offline
Freakin' sweet
cusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond repute
Yeah, the musiciansfriend cables are dirt cheap. I've bought those 10-packs before for doing some non-critical cable runs during shows, and honestly, they have always worked for me, but they are pretty light and have low-end connectors. Anything better would probably be a big step up, hehe
Old 12-26-2006
Banned
No problems with them here either. I wouldn't take them to a gig but for using around the house I have no problem with them.
Old 12-26-2006
Force of Nature
Thanks
Hey guys,
I think I'll try the GLS cables. At least if they go bad I've got good wire.
Besides 20' cables are always five feet too short.
Thanks,
Hairy Larry
Old 12-26-2006
Banned
Harry Larry, the connectors and cable are very decent. I don't think you'll be disappointed, especially for the price.
Old 12-27-2006
Newbie
Oh man do I feel like a dope. It wasn't the cables at all. The phantom power switch on the mixer is deeper than a pen point. I used a thin allen key and was able to push the thing deep enough to stay engaged.
It's amazing how stupid some of my questions can be.
Old 12-27-2006
up-fiddler's Avatar
up-fiddler up-fiddler is offline
Taming the World--for now
up-fiddler has a reputation beyond reputeup-fiddler has a reputation beyond reputeup-fiddler has a reputation beyond reputeup-fiddler has a reputation beyond reputeup-fiddler has a reputation beyond reputeup-fiddler has a reputation beyond reputeup-fiddler has a reputation beyond reputeup-fiddler has a reputation beyond reputeup-fiddler has a reputation beyond reputeup-fiddler has a reputation beyond reputeup-fiddler has a reputation beyond repute
Everyone here has been equally stupid at times. We just aren't crazy about admitting it. Good luck with the radio show.
Studio
Dave's Blog
  #12
Old 12-27-2006
Force of Nature
Thanks
Hi,
When I finally figured out a computer problem that in retrospect seemed obvious I would say.
It's not that we're stupid for missing that. We're smart for finally figuring it out.
Plus I got a lot of good info about an important question.
Thanks,
Hairy Larry
  #13
Old 12-27-2006
Newbie
Hi,
Thanks,
Hairy Larry
Good point -- I've always been one of those people that never admits a mistake, typically because i figure it out ahead of time and fix it before anyone notices.
Well I'll continue to share my little discoveries as I find them.
  #14
Old 12-27-2006
TragikRemix's Avatar
TragikRemix TragikRemix is offline
I am NOT a Gear Whore. ;)
TragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond repute
i have quite a few MF cables. they arent all taht bad, or that good.
when you get the cables, just rip the connectors off and resolder them right from the beginning, as they all go eventually.
they are just cables.. good enough. i'm making some cables with mogami and neutrik parts, should get the shipment in a few days now. i'll let you know if i can notice any difference, although i really really doubt i will hear anything.
GFCG Member: 000 029
F**k Your Scene.
A really dumb copyright question loserfer Newbies 2 12-08-2005 14:24
Ok Dumb question about SP C4's kats Microphones 19 04-10-2005 15:43
Dumb EQ Question I'm Sure, But... hookiefree Mixing / Mastering 27 08-20-2004 20:58
Probably a dumb question about USB. 5c0tt Digital Recording & Computers 3 10-08-2002 15:47
A dumb question about A/D converters geekgurl The Rack 6 02-28-2002 14:13
