Old 12-26-2006
zzfdvz zzfdvz is offline
Newbie
zzfdvz is a jewel in the roughzzfdvz is a jewel in the roughzzfdvz is a jewel in the roughzzfdvz is a jewel in the rough
flooring in basement studio
is it possible to just lay hardwood floor down on a concrete slab, or will that act like a poorly contructed "floated floor" and just cause more problems? and for the record, since i know NOTHING about contruction methods, i do have a contractor doing all of my installs, so it would be properly done it if could be beneficial. thanks.
Old 12-26-2006
apl's Avatar
apl apl is offline
Stand Up Comity
apl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond repute
I would think so. I know linoleum is glued directly to the concrete, so I don't see why a wood laminate couldn't be. That will be a sweet floor.
Be sure to review www.ethanwiner.com/acoustics.html
The fabulous Naiant Mics, perfect for acoustic instruments!
If you don't have DavidK's CD, you are a loser.
My tunes. Thanks!
NB
DA BEARS!
Old 12-26-2006
battleminnow's Avatar
battleminnow battleminnow is offline
What's this button do?
battleminnow has a reputation beyond reputebattleminnow has a reputation beyond reputebattleminnow has a reputation beyond reputebattleminnow has a reputation beyond reputebattleminnow has a reputation beyond reputebattleminnow has a reputation beyond reputebattleminnow has a reputation beyond reputebattleminnow has a reputation beyond reputebattleminnow has a reputation beyond reputebattleminnow has a reputation beyond reputebattleminnow has a reputation beyond repute
Nope. Don't waste your money. If you want density for sound transmission/blockage/acoustics than go with an engineered wood floor.
Besides, solid wood on concrete is a bad idea for moisture/mold issues.
If you have any other questions, leeme know. Floors are my specialty
Pete
Old 12-26-2006
Newbie
so by enginnered floor you're speaking of the stuff that's pretty much identical to hardwood floors, or are you talking about building a whole floated floor? a whole floated floor is not an option at all due to ceiling height restrictions and overall cost to make something dense enough to not resonate. also, i'm less concerned about the transmission loss as i am acoustics and astetics (let's face it, a studio with eye candy can pull in an extra client or two). i apoligize for being dumb, i've done my homework and have rod gervais's book, they just don't cover anything aside from doing nothing, or floating a floor when you're dealing with concrete slabs. thanks again.
Old 12-26-2006
apl's Avatar
apl apl is offline
Stand Up Comity
The basement floor is already concrete going into dirt. Lots of dirt. There will be no transmission through the floor into anywhere else. Floating the floor for moisture is a different consideration.
If it were me I'd get some wood looking 12 x 12 tiles and just stick them down. Value City used to sell them really cheap, something like $10 a box.
My tunes. Thanks!
NB
DA BEARS!
Old 12-26-2006
Obi-Wan zenabI's Avatar
Obi-Wan zenabI Obi-Wan zenabI is offline
Force of Nature
Obi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond repute
moisture is the main consideration
I would think that engineered floors would tend to soak up more moisture-- like an old radio shack speaker left out in the rain-- like a sponge!
Cheap vinyl tile makes sense in a bsmt..
Joe
Old 12-26-2006
punkin's Avatar
punkin punkin is offline
Univalve & Avatar Speaks
punkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond repute
Pete
Check your local codes...he's got a point there. Also, in some area the soils are considered expansive and you may not want ridgid materials in direct contact with the concrete floor.
She's not the boss of me
Old 12-28-2006
Innovations's Avatar
Innovations Innovations is offline
1K Silver Member
Innovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond repute
laminate flooring is going to want a foam padding and a moisture barrier. Laminate is not intended to be direct-glued to anything. I will agree that you aren't that concerned with sound transmission through a basement slab but moisture is a significant concern.
Old 12-28-2006
ridgeback's Avatar
ridgeback ridgeback is offline
DARN LOSER
ridgeback has a reputation beyond reputeridgeback has a reputation beyond reputeridgeback has a reputation beyond reputeridgeback has a reputation beyond reputeridgeback has a reputation beyond reputeridgeback has a reputation beyond reputeridgeback has a reputation beyond reputeridgeback has a reputation beyond reputeridgeback has a reputation beyond reputeridgeback has a reputation beyond reputeridgeback has a reputation beyond repute
Pete
Bingo!!! Density kids!
Got any Irish in ya? Want some? http://i40.photobucket.com/albums/e2...shedvsmall.jpg
Whats The Best Studio Basement Setup chestwick91 Recording Techniques 29 02-16-2006 01:59
Underground Studio Mikey likes it! Studio Building & Display 11 08-14-2005 09:45
Building a Hobby Studio in My Basement JohnnyMan Studio Building & Display 13 10-17-2004 12:42
Need help/advice on turning basement into studio thill Studio Building & Display 2 09-27-2004 10:40
Basement Studio Humidity + Air Quality Dan Merrill Studio Building & Display 15 09-17-2001 16:01
