Old 12-25-2006
fraserhutch's Avatar
fraserhutch fraserhutch is offline
Flypaper for freaks
fraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond repute
TRS pin assignments?
Can someone please refresh my memory - foir a TRS connector, which pin is hot, which is cold, and which is ground? It's been a little while and I am drawing a total blank. I need to know cause I need to make TRS to XLR cables (otherwise I'd just make sure same color wire gets connected to the same pins on both ends).
Thanks!!!!
Merry Xmas and Happy Holidays!
The fact that no one understands you doesn't mean you're an artist...
Old 12-25-2006
Track Rat's Avatar
Total Gear Slut
It can vary from manufacturer to manufacturer so always check their documentation when you can. But convententional wisdom is for an XLR;
pin #1= Shield
pin #2= hot or +
pin #3= return or -
On the 1/4";
tip= hot or+
ring= return or -
shield is shield
Again a warning on the pin out of these connectors, especially the XLRs. Pin #1 is always shield but some folks swap 2 and 3.
Mike
Old 12-25-2006
Flypaper for freaks
Ah, thanks, I have the docs for the neutrik XLR connectors, but I found no such docs for the 1/4. That's what I seem to remeber... thanks for the info!
pin #1= Shield
pin #2= hot or +
pin #3= return or -
On the 1/4";
tip= hot or+
ring= return or -
shield is shield
midimonkey wiring frederic Studio Building & Display 7 11-25-2005 21:33
4 pin to 6 pin or 6 pin to 4 pin firewire conector? malabito Digital Recording & Computers 1 10-22-2005 21:30
Pin 3 hot on buss outputs Adam P Other Equipment and Reviews 5 06-03-2005 10:43
XLR vs. 1/4 TRS noground Newbies 10 07-30-2001 19:55
midi cable pin assignments crazyhorse MIDI Mania 3 12-19-1999 23:41
