Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 12-23-2006
digmudvayne4lif's Avatar
digmudvayne4lif digmudvayne4lif is offline
Senior Member
digmudvayne4lif has a reputation beyond reputedigmudvayne4lif has a reputation beyond reputedigmudvayne4lif has a reputation beyond reputedigmudvayne4lif has a reputation beyond reputedigmudvayne4lif has a reputation beyond reputedigmudvayne4lif has a reputation beyond reputedigmudvayne4lif has a reputation beyond reputedigmudvayne4lif has a reputation beyond reputedigmudvayne4lif has a reputation beyond reputedigmudvayne4lif has a reputation beyond reputedigmudvayne4lif has a reputation beyond repute
Using computer as a drum module
Im putting together a homemade electronic kit and i was wondering if id be able to plug the triggers into this trigger to midi interface http://www.musiciansfriend.com/produ...ace?sku=449754 , go throught the usb to my computer, and then fire up drumagog (or other drum replacement program) and be able to hear those incoming midi signals come out as sampled drums? or in other words, could i use my computer as a drum module? thanks
Old 12-23-2006
travelin travis travelin travis is offline
Banned
travelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond repute
yes, you can use your computer as a drum module. i don't know if drumagog will fit into that though.
Old 12-23-2006
Senior Member
how would you go about doing it then? What program would you use?
Old 12-23-2006
Banned
take your pick i suppose. if you're shooting for acoustic drum sounds, dfhs, bfd, ezdrummer, and addictivedrums would all be worth checking into.
Old 12-23-2006
Banned
i haven't tried that alesis module but it looks like a good idea to me. actually, that module comes with bfd lite. that should get you going and might be all you want in the end.
Old 12-23-2006
Senior Member
I thought those were all for creating loops on your computer. Im talking about replacing the module youd use in a regular electronic drumset and instead having the triggered midi signals running through your computer, or can you do that with ezdrummer?
Old 12-23-2006
Banned
all the above software that i mentioned are proprietary drum samplers. each comes with it's own set(s) of multi velocity samples. each can be controlled via a midi input device such as electronic drums, keyboard, drum pad, etc. each also comes with a midi loop library for quickly throwing together drum tracks without a midi input device. you can use your triggered drums to trigger the samples or midi files.
Old 12-23-2006
Senior Member
oh cool, thanks. thats what i was looking for. but i looked through the ezdrummer pdf and i cant find how your suppose to set it up for being controlled with the midi input. Does anybody know how this is suppose to be done?
Old 12-23-2006
Banned
in your recording software, insert the plugin (ezdrummer for example) on a track. select your midi device (alesis usb i/o for example) as the track's input. take a look at your plugin's manual and find the drum map. it will tell you which note each drum is assigned to. if you need to, and if the plugin allows, change the drum/midi note assignments as you need to get the right drum/midi note relationship for your setup.
Old 12-24-2006
Senior Member
awsome, thanks.
Old 12-25-2006
TragikRemix's Avatar
TragikRemix TragikRemix is offline
I am NOT a Gear Whore. ;)
TragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond reputeTragikRemix has a reputation beyond repute
any softsynth/midi program would work. DFH superior has the best samples IMO as far as drums go. reason, sampletank etc would all work too.
GFCG Member: 000 029
F**k Your Scene.
Help with Computer Drum Tracks ido1957 Newbies 2 05-08-2005 19:45
Bass Drum Trigger Module primopyro Drums and Percussion 1 03-17-2005 05:36
Which drum module to buy? imanogre Keyboards and Sound Modules 6 01-11-2005 08:12
pads, triggers for alesis drum module or roland spd series? pseudosun Drums and Percussion 1 06-13-2004 13:20
