Old 12-21-2006
thedude400 thedude400 is offline
Senior Member
thedude400 has a reputation beyond reputethedude400 has a reputation beyond reputethedude400 has a reputation beyond reputethedude400 has a reputation beyond reputethedude400 has a reputation beyond reputethedude400 has a reputation beyond reputethedude400 has a reputation beyond reputethedude400 has a reputation beyond reputethedude400 has a reputation beyond reputethedude400 has a reputation beyond reputethedude400 has a reputation beyond repute
robot sounding spdif problem
I'm having a problem lately with using my lexicon processor with my interface. I have had it working properly before but now when I set up the spdif connections i hear this metallic sounding robot-esque sibilince sound. I faintly hear the effect but the robot noise is so overpowering, using my processor in 24 bit/48khz with my interface has become pointless. I know using a normal rca cable isnt recommended but should still work. I doubt that is the problem though I suppose it could be.
I have the clock set to external and everything , I have switched the cords around and messed with the input levels etc. I made sure the bit rate and khz's all match up .I just don't know what to blame or what is causing this problem. I know getting actual spdif cables could be a step in the right direction but is that gonna solve this problem. Anyone able to help me out with this problem?
Old 12-21-2006
bigwillz24's Avatar
bigwillz24 bigwillz24 is offline
One Turd at a Time...
bigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond repute
Only one way to find out... buy a cable. Seems like you've done all the troubleshooting. But if you had it working perfecty before I'm guessing it has something to do with something you changed.
Old 12-21-2006
gtrman_66's Avatar
gtrman_66 gtrman_66 is offline
Dedicated Member
gtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond repute
A normal RCA cable and a coaxial digital cable are definately not the same thing. The spdif cable has a 75 ohm resistance whereas the audio cable is just straight "zero" resistance cable. I found out the hard way about using straight RCA cable when my spidif coaxial on one of my audio cards quit working after while.
I have some 75 ohm high quality video composite cable with RCA connectors I have been using with no problem on coaxial spdif connections. As far as I know, there isn't a whole lot of difference between the two.
Old 12-21-2006
SRR's Avatar
SRR SRR is offline
BAKOVAB
Location: Everywhere a computer is plugged in and operating.
SRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond reputeSRR has a reputation beyond repute
What lexicon and what interface are you using?
In a letter to his daughter, the MCP expressed unhappiness over the eagle as the symbol of America, he wanted the Tron guy.
Equipment
G.F.C.G. # 000 035
Old 12-21-2006
MOFO Pro MOFO Pro is offline
Opinions are like SM-57s
MOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond repute
I doubt the cable can be giving you that much of a problem... unless it's defective (you may want to try a different RCA cable... and if you're going to cheap out on a cable at least make it an RCA video cable, an audio cable's impedance is way off).
Sounds more like clock settings... like both devices are set as external/slave or internal/Master... it really sounds like a frequency mismatch... but you say you've checked and they agree... Do you have a feedback loop set up by mistake? Digital feedback can sound very robotic when it starts clipping. Does it occur with no audio source? Does it gradually build up as you add gain to the source... or does it pop up quickly at a certain gain level?
I doubt it's the cable... but you haven't given us alot to work with... what's the interface?
Edit: Obviously I got called away halfway through this one... answering this question for the third time
Old 12-21-2006
bigwillz24's Avatar
Did he bail? I'm kinda curious as to the interface.
Old 12-21-2006
SRR's Avatar
SRR SRR is offline
BAKOVAB
Sorry you have been misled, a metal coat hanger will work for passing spdif signals. However using a good quality shielded cable with RCA connectors might be better then a coat hanger in the long run. There is no such thing as a "digital" or "SPDIF" cable, as there was never a "CD ready speaker", remember that marketing slogan from the 80's anybody? You can use any coax wire for SPDIF connections, nothing will blow up if you use something labeled video, audio, digital audio, or any another label they want to put on the cable. Your audio card certainly did not stop working cause the cable you were using was labeled one way or another.
Equipment
G.F.C.G. # 000 035
Old 12-22-2006
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
It sounds to me like you might have your audio double routed through your SPDIF interface. In other words, the audio signal is going through it the first time, and then is somehow routed around and going through it again a second a split second later. This could cause the type of sound you describe, or something like it.
I suggest you take a close look at all your audio pathways, both in hardware and software.
http://www.misterpotts.com
Old 12-22-2006
Senior Member
it's an mpx 500 and an aardvark q10. Could be the Aardvark but I really doubt it. Aardvark might be no longer in business for strange and undisclosed reasons but the q10 has been very solid for me thus far. I've been using one on and off for just under 2 years. The cable I'm using is just a radio shack cable.
The one thing I did change recently was a hard drive reformat which isn't anything that would affect processor /interface compatibility. I will have to really take a closeup look at my signal chain . I'm basically positive everything's set up correctly but who knows maybe it is just a silly mistake. I have a guy coming in to finish up a 5 song demo tomorrow morning and we have been anxious to use the lexi so hopefully I can troubleshoot successfully by then. I will post my resolution if I ever get one.
Old 12-22-2006
Particularly check the audio routing in software, as it can be really easy to double the signal somewhere along the line. If you are somehow monitoring signal from two different points in the path then you could get that sound.
I thought Aardvark made excellent products, it's too bad they disappeared. You could see it coming though. At the NAMM show their booth basically got deserted the last couple years. You'd see one or two lonely guys standing there but no one stopping in to check their gear. Somehow they lost the buzz and people went elsewhere.
Old 12-22-2006
RezN8's Avatar
RezN8 RezN8 is offline
Blick-um, blick-um...
RezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond repute
Not sure if this was what you were saying earlier about setting the clock to external, but with some products, the "SPDIF device" has to be chosen as the clock source. For instance, a few years ago when tracking with the Yamaha DG Stomp SPDIF through a Delta 1010, we had to set SPDIF as the masterclock in the Delta 1010 control panel.
Does the Aardvark have an option for this, or is external the only option?
I have used the Lexicon MX with SPDIF too, and I think I remember something about a setting in the Lexicon to set to digial out vs. analog. Don't quote me on that, but it's worth looking into as well.
Hope this info helps! Cheers, Rez
  #12
Old 12-22-2006
Another possibility is that you have your Lexicon set to pass both the dry signal and the wet signal. If you have the unit set to less than 100% wet this could also cause a sound which is possibly the one you are describing. There would be a slight delay between the two.
  #13
Old 12-22-2006
MCI2424's Avatar
MCI2424 MCI2424 is offline
1K Silver Member
MCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond repute
It would also cause phasing (like a flanger type of sound)
I guess it could sound "robotic"
"Tascam, Fostex or Studers don't make hit records...........people do"
MCI2424 - 2007
  #14
Old 12-22-2006
Right, that's what I think he is describing. Not quite a phasing or flanging sound, but a doubled signal that is just a few milliseconds apart.
  #15
Old 12-22-2006
Robert D Robert D is offline
Close to the Edge
Robert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond repute
Originally Posted by SRR
Sorry you have been misled, a metal coat hanger will work for passing spdif signals. However using a good quality shielded cable with RCA connectors might be better then a coat hanger in the long run. There is no such thing as a "digital" or "SPDIF" cable...........
Reflections and sloppy edges from poor digital transmission line impedance control are real, and easily demonstrated. Any 75 ohm cable is fine for S/PDIF, you don't need anything exotic, but use 75 ohm cable.
Regards,
RD
http://www.myspace.com/twentysevenmoons
  #16
Old 12-22-2006
RAK's Avatar
RAK RAK is offline
Manufacturer - Shure, Inc
RAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond reputeRAK has a reputation beyond repute
Yeah, what he said.
While it is recommended that for S/PDif or "Coaxial" connections you use an RCA cable rated at 75 Ohms, it's stil an RCA cable. Just like how the XLR cable you use between your microphone and your mixer for an analog connection, is the same XLR cable you use for a digital AES/EBU connection.
Originally Posted by jimmy2sticks
For the record, I am smarter than Einstein.
  #17
Old 12-22-2006
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
I know the clock and data connections are pretty lenient in that respect but where or at what point does that spec apply then? Presumably it's just a set amount of capacitance for 75 ohms at some radio frequency right?
Cubase LE or PreSonus Firepod Problem? Confusitron Cubase User Forum 2 10-31-2005 18:44
a problem with bass guitar signal trispectrum Recording Techniques 11 02-04-2005 12:51
soundcard device config problem guttadaj Digital Recording & Computers 0 11-16-2004 09:51
Seems like I got a soundcard problem... Beathoven Other Equipment and Reviews 2 12-11-2001 07:56
Problem monitoring SPDIF out - Cubase / DiO 2448 Brad Digital Recording & Computers 0 12-07-2001 17:55
