Old 12-19-2006
Nick_Black's Avatar
Nick_Black Nick_Black is offline
Mirthmaker
Nick_Black has a reputation beyond reputeNick_Black has a reputation beyond reputeNick_Black has a reputation beyond reputeNick_Black has a reputation beyond reputeNick_Black has a reputation beyond reputeNick_Black has a reputation beyond reputeNick_Black has a reputation beyond reputeNick_Black has a reputation beyond reputeNick_Black has a reputation beyond reputeNick_Black has a reputation beyond reputeNick_Black has a reputation beyond repute
Cardboard bass traps?
is it possible to get that thick packaging cardboard stuff. layer it so it's about 4" thick and use that as a bass trap? and/or could you use it for sound proofing?
edit: and use that cheep bed foam on top to prevent as many reflections
Old 12-19-2006
giraffe's Avatar
giraffe giraffe is offline
i love negative rep
giraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond repute
i'm sure if something cheep and avalaible like cardboard could be used for bass traping, it would be all over.
so probably not.
audio?
seriously, give me negative rep.
Old 12-19-2006
bigwillz24's Avatar
bigwillz24 bigwillz24 is offline
One Turd at a Time...
bigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond repute
Sounds like you're trying to create the world's biggest fire hazard.
Old 12-19-2006
Nick_Black's Avatar
Mirthmaker
yeah, I was thinking about the fire thing. but it's only for temparary usage.
plus there's absolutly no heat source around. infact I'd be more worried about it getting wet... but thanks for the concern.
and giraffe thanks for the reply. but I rather not assume, just becouse no one uses it that I've heard of (there's alot of things that work that no one "likes" using)
Old 12-19-2006
studiomaster's Avatar
studiomaster studiomaster is offline
MachWave
studiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond repute
Ask Ethan.
I don't think cardboard would help cause its density is too low. 703 is basically fluffy stuff packed and compressed to a certain thickness so it increases its density for absorption efficiently.
Old 12-19-2006
RICK FITZPATRICK's Avatar
RICK FITZPATRICK RICK FITZPATRICK is offline
Been Here, Posted That
RICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond repute
Hello Nick. In a nutshell, absorbers such as rigid fiberglass are called "resistance" absorbers. The fibers are compressed just enough to resist the movement of air molecules in between the "interstices" of the fibers. Too loose, and you have no resistance. Too tight and it will reflect. This resistance causess sound energy to convert to heat. But don't try to heat your coffee with it.
Another factor is thickness, as it is relative to 1/4 wavelengths. At 1/4 wavelength velocity of the molecular movement is maximum, but pressure zero. If a 1/4wavelength is equal to or less than the thickness of the fiberglass, absorption coefficients are higher. To give you and example, a 100hz wavelength is 11.3' long, with a 1/4 wavelength of 38.4". A 1khz wavelength is 1.13' with a 1/4 wavelength of about 3.8 inches. Thats why a 4" thick rigid fiberglass panel has a higher absorption coefficient at 1khz than at 100 hz.
Cardboard has no attributes to act as a resistance absorber. And it has very little mass, which means it is a lousy material to use for "soundproofing" applications.
One of the main things I use cardboard for is templates. Like my soffit panels. I get large sheets of 3/4" honeycomb cardboard from Sears. Some of their products such as refriderators and riding lawnmowers are packed using these panels. Sears usually just throws them away. Some are as big as 4'x6'.
fitZ
alright breaks over, back on your heads!
Old 12-20-2006
Dani Pace's Avatar
Dani Pace Dani Pace is offline
Why 2K?
Dani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond repute
Thanks Rick, I knew it wouldn't work (ive tried it) now I know the reason why.
The more I learn, the more I realize how much I don't know. http://www.soundclick.com/sixfeetover
Old 12-20-2006
Nick_Black's Avatar
Mirthmaker
Thanks for the very detailed discription. I knew about the diffrent wavelenghts thats why I wah planning to make it 4" tich (not even close to all the bass freqencies, but I hoped that it would do something)
but I did not know about the resistance absorbers, Thanks for explaining that too me I alway's wonderd why such, relitivaly thin matirial could absorb so much.
but, unfortunatly I can't get a hold of rigid fiberglass, but I'll look into something like rocksol or something.
Thanks again!
Old 12-21-2006
frederic's Avatar
frederic frederic is offline
frederic.midimonkey.com
frederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond repute
Using dead roosters stapled to the wall would be more effective than cardboard.
Old 12-21-2006
bigwillz24's Avatar
will roasting them first give a warm sound?
Old 12-22-2006
Nick_Black's Avatar
Mirthmaker
sweet, yeah, I've got the point... Where can you buy roosters?
is there any cheep methold using house products (mostly) that you can build a decent bass trap, or sound insoltion "hanging wall"?
  #12
Old 12-22-2006
Track Rat's Avatar
Total Gear Slut
Hmmmmmmmmmmmmm...........how many do you think I'd need?
Mike
  #13
Old 12-22-2006
gvarko's Avatar
gvarko gvarko is offline
The Boogie Man
gvarko has a reputation beyond reputegvarko has a reputation beyond reputegvarko has a reputation beyond reputegvarko has a reputation beyond reputegvarko has a reputation beyond reputegvarko has a reputation beyond reputegvarko has a reputation beyond reputegvarko has a reputation beyond reputegvarko has a reputation beyond reputegvarko has a reputation beyond reputegvarko has a reputation beyond repute
Thumbs up
Once you dispense all laws of acoustics, regard for personal safety and plain old common sense, there are many items you can use.
http://stores.ebay.com/WoodGuarden-Pickguards
Helping you sport Solid Wood . . .
Bass traps with a pitched ceiling...anyone want to take a crack at this one? Seeker of Rock Studio Building & Display 2 10-30-2006 09:51
Bass traps? NYMorningstar Studio Building & Display 8 09-28-2006 19:43
bass traps antispatula Studio Building & Display 5 12-06-2005 07:39
A little mix before my DMP3 & Bass traps jeff0633 The Rack 0 04-03-2004 01:45
Auralex LENRD bass traps mncheetah Studio Building & Display 1 04-07-2002 16:48
