Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 12-18-2006
TelePaul's Avatar
TelePaul TelePaul is offline
J to the R O C
TelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond repute
Question for SSScientist...
...or anyone else who wants to help me out. I have two questions about sequencing Midi in Cubase; I mosty track audio and have a few queries.
Firstly, do Midi tracks have a propensity to peak more than audio tracks? I seem to be hitting the red alot and having to adjust and ending up with an overall mix that isn' t that loud. Any thoughts on this?
Seocndly, because of the VSTs I'm using I'm running my 512 MB pretty close to the bone. I plan to add a few Audio tracks and want to avoid popping. This is a silly question, but is there any way to kinda disable midi while I track Audio? Obviously I'd still need to hear it in the background.
Any help would be great.
Originally Posted by Gummblefish
Went out yesterday all day long and spent 125 quid on a bender (not literally a bender )
Old 12-18-2006
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
The metering in a midi track is showing you velocity values only. There's no way to cause distortion or any other artifact traditionally associated with overloading an audio track. If you have the master level of the plugin associated with the track set too high then you can cause distortion, both at track level and at mix level.
There is, and it's called 'track freezing'. The last version of Cubase that I used seriously didn't offer it, but they may have introduced it in the last few years. I know Tracktion and Reaper both have it, and LIVE has an especially flexible implementation in which you can still move and edit (to a point) tracks that are frozen.
Upgrading your computer's memory is one of the best thing you can do for your system. Before you spend money on that next softsynth you've got your eye on, think about sinking the dosh into a less sexy but ultimately more useful memory upgrade.
...now in HD.
Old 12-19-2006
TelePaul's Avatar
J to the R O C
So you're saying that so long as the plug in master isn't too high, its okay if the midi hits the red? Or should it be hitting the red?
I'll look up track freezing in Cubase, thanks. And yup you're right about the computer, I'm working on it.
Old 12-19-2006
lasagne lasagne is offline
I fancy Fancy
lasagne has a reputation beyond reputelasagne has a reputation beyond reputelasagne has a reputation beyond reputelasagne has a reputation beyond reputelasagne has a reputation beyond reputelasagne has a reputation beyond reputelasagne has a reputation beyond reputelasagne has a reputation beyond reputelasagne has a reputation beyond reputelasagne has a reputation beyond reputelasagne has a reputation beyond repute
Hi Telepaul. This is probably an inefficient way of freeing up ram, but what I have done is convert the midi track to an audio track ie export only the midi track as an audio file, then reimport it into cubase.
That way, you are not using the VST anymore.
"I'm here all week"
Old 12-19-2006
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
thats exactly what the freeze function does
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 12-19-2006
Info you can use...
Yes.
To clarify, what I'm saying is the function of the meters changes when you are recording either an audio track or a midi track.
When recording an audio track they show the input level of the signal.
When recording a midi track they show only the velocity of the incoming notes which is one of the three main things that midi tracks records -- what note is played, how long it's held and how hard it's struck.
The 'how hard' part is what's reflected on the meters, and it's actually preferable to have at least some of the notes hit the top velocity. Many soft synths have velocity sensitive EVERYTHING that can be programmed, not just the amplitude (volume) related parameters, so a monitor of the incoming velocity info can be very useful.
...now in HD.
Old 12-19-2006
TelePaul's Avatar
J to the R O C
Fellas, thats a great idea!! Agh I'm pretty mentally challenged these days, sorry. I'll definetely do that when I have the backing tracks I want, I'll sacrifice a bit of flexibility any day. Great call. Thanks.
Alan... No Stephen Paul Mic? DJL Microphones 249 07-27-2007 23:47
question about mixer matt's bedroom Newbies 3 05-04-2006 05:24
First Post: Ultimate Question!!! HyperSpace Recording Techniques 19 04-25-2005 08:29
Delta 1010 output question? henry_mullis Digital Recording & Computers 1 12-28-2002 11:12
stupid question about compression deathofamind Mixing / Mastering 10 12-13-2002 21:10
