Old 12-15-2006
Atom Bomb's Avatar
Atom Bomb Atom Bomb is offline
Senior Member
Atom Bomb has a reputation beyond reputeAtom Bomb has a reputation beyond reputeAtom Bomb has a reputation beyond reputeAtom Bomb has a reputation beyond reputeAtom Bomb has a reputation beyond reputeAtom Bomb has a reputation beyond reputeAtom Bomb has a reputation beyond reputeAtom Bomb has a reputation beyond reputeAtom Bomb has a reputation beyond reputeAtom Bomb has a reputation beyond reputeAtom Bomb has a reputation beyond repute
Dropout frustrations...
I have Cakewalk Sonar 4.
I am trying to re-record tracks from an external Roland workstation into my cakewalk.
Ideally id like to get one stereo track into My laptop but for some reason i cant figure out how to do this so i have to plunk it track by track into my Laptop.
I doubt its my hardware themselves its a sturdy well built hp...the sound card is the built in one.... its just the mic jack.....ugh.
So after many bumps in the road and thought i had a nice way of doing it down...
I listend to the play back after lining up the tracks and near the end everything gets all out of sync phase and all that.
I am assuming im dropping out and something isnt keeping up with something else.
I played a little with buffer size and latency i am still getting some lag and stuff.
I used the wave profiler and jigged with a few things here and there but i am still getting bips pops and dropouts...
How can i fix this.
Or is it impossible to record more then 1 minute or two of digital audio?
How much of help would it be to switch from 44000hz to 22000hz ? how much sound quality am losing ...
Keeping this is a demo recording for a metal bands myspace.
Ill shut up now.
"turn up the good turn down the suck"
Old 12-15-2006
dachay2tnr's Avatar
dachay2tnr dachay2tnr is offline
One Hit Wonder
dachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond repute
You can't record a stereo track through a mic jack. Mic jacks are mono. You need to use the line in jack.
Depending on the output connections of your Roland, you should be able to feed a stereo mix from the Roland to Sonar via your sound card.
For example, if the Roland has L/R RCA outputs, you will need a Y cable that goes from two RCA plugs, to a stereo 1/8" plug (the line in port on your sound card). Radio Shack should have what you need.
Set up Sonar to record from Line In Stereo, and you should be good to go.
Old 12-15-2006
brzilian brzilian is offline
2.5K Gold Member
brzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond repute
How can i fix this.
Ill shut up now.
Get a better quality audio interface designed for recording which has low latency ASIO or WDM drivers.
Since you are on a laptop, you are limited either a Firewire or PC-Card audio interface. USB audio interfaces are a waste of money and are not reliable if you try and record more than 4 tracks simultaneously.
It would be easier for people to maket specific recommendations if you woud indicate how many inputs you would need.
Recording at 22Khz makes no sense whatsoever since that is below CD quality.
Old 12-15-2006
Atom Bomb's Avatar
Senior Member
ahhh i was on the right track. i have this cable ... but i am lacking an actual line in input.... that sucks.
As for the other guys comment... something like the m-audio fast track wouldnt help me in this situation?
and i didnt think the 22000hz thing was a good idea either but i thought id mention it.
Dropout and IRQs I can't change. Help iwantmypie Digital Recording & Computers 8 11-13-2006 13:23
dropout!!!! FALKEN Analog Only 24 02-16-2006 21:04
Droput Indication without Dropout? mark4man Cakewalk / Sonar Forum 6 12-01-2003 16:46
easy how to fix dropout problem sonar wfaraoni Cakewalk / Sonar Forum 4 02-19-2003 14:23
Dropout issues,, Help!!! Axeslinger Cakewalk / Sonar Forum 17 04-10-2002 15:10
