Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 12-11-2006
BlackHawk2029's Avatar
BlackHawk2029 BlackHawk2029 is offline
Force of Nature
BlackHawk2029 has a reputation beyond reputeBlackHawk2029 has a reputation beyond reputeBlackHawk2029 has a reputation beyond reputeBlackHawk2029 has a reputation beyond reputeBlackHawk2029 has a reputation beyond reputeBlackHawk2029 has a reputation beyond reputeBlackHawk2029 has a reputation beyond reputeBlackHawk2029 has a reputation beyond reputeBlackHawk2029 has a reputation beyond reputeBlackHawk2029 has a reputation beyond reputeBlackHawk2029 has a reputation beyond repute
anyone use this mic mount?
anyone have any opinions on these?
mic mount
i just ordered one for my snare drum and i'd like to know what you all think of them.
Old 12-11-2006
dkerwood dkerwood is offline
Senior Member
dkerwood has a reputation beyond reputedkerwood has a reputation beyond reputedkerwood has a reputation beyond reputedkerwood has a reputation beyond reputedkerwood has a reputation beyond reputedkerwood has a reputation beyond reputedkerwood has a reputation beyond reputedkerwood has a reputation beyond reputedkerwood has a reputation beyond reputedkerwood has a reputation beyond reputedkerwood has a reputation beyond repute
My church uses these. I haven't moved them around, so I can't speak to that. But they seem to function and hold the mics where they belong.
Let's dispense with all the philosophical high-minded reasoning and well articulated thoughts and get down to some good old name-calling and insults!
Old 12-12-2006
Force of Nature
how about these stero mounts?
Old 12-13-2006
Senior Member
If you're on a super budget and need one stand for two mics, that will work, I suppose. I think you'll find a great deal more flexibility with two mic stands, though.
Old 12-13-2006
EdWonbass's Avatar
EdWonbass EdWonbass is offline
pull the goalie
EdWonbass has a reputation beyond reputeEdWonbass has a reputation beyond reputeEdWonbass has a reputation beyond reputeEdWonbass has a reputation beyond reputeEdWonbass has a reputation beyond reputeEdWonbass has a reputation beyond reputeEdWonbass has a reputation beyond reputeEdWonbass has a reputation beyond reputeEdWonbass has a reputation beyond reputeEdWonbass has a reputation beyond reputeEdWonbass has a reputation beyond repute
mic mount
I have them. You pretty much get one setting and not much flexibility. OTOH, if you like where they put the mic they aint going anywhere. The other drawback is that you have to mount them where you have a lug which can be trouble when trying to use one mic on rack toms. Also there isn't enough room on piccolo snares between the lug and the rim. I soon will be switching to just using stands.
I lost my pants in the fountain.
Old 12-13-2006
Force of Nature
well i dont have the inputs for close micing toms, so it'll only be on my snare, and im really hoping im ok with where the mic ends up.
Old 12-16-2006
dgatwood's Avatar
dgatwood dgatwood is offline
is out. Leave a message.
dgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond repute
If not, those things are really sturdy---touch as nails---so just screw a really firm flex gooseneck attachment on there and you should be set.
Originally Posted by Obi-Wan
If you mod me down, I will only grow stronger.
Old 12-16-2006
EdWonbass's Avatar
pull the goalie
They are quite sturdy. Almost tank like.
I think if you had the right length goose neck you could put the mount on the lower lug and bring the gooseneck up over the top rim and position it as needed. I have not tried this so I am not sure if it will work.
Old 12-16-2006
dgatwood's Avatar
I think the only real concern would be finding gooseneck that was tight enough that it wouldn't flex under the vibrations resulting from the impact of sticks hitting the drum. I don't have any recommendations on stiff goosenecks except to suggest that if you plan to do this, you should find a local music store and try a half dozen goosenecks until you find one that you think is stiff enough.
Old 12-18-2006
mattimus mattimus is offline
Junior Member
mattimus will become famous soon enough
trust me... a stiff gooseneck is key.. in most scenerios
Old 12-18-2006
EdWonbass's Avatar
pull the goalie
Good point.
I have one gooseneck and it is very floppy. The tom mics I have are pretty light but a 57 would bend it down.
  #12
Old 12-18-2006
Senior Member
Even more important than support via a gooseneck; you don't want the mics bouncing around while you're hitting the drums, especially the snare.
I passed on a gooseneck last week because it swung about 6 inches (with a 57) when I would hit the snare hard.
  #13
Old 12-22-2006
NegadivOne's Avatar
NegadivOne NegadivOne is offline
Alchemy slut
NegadivOne has a reputation beyond reputeNegadivOne has a reputation beyond reputeNegadivOne has a reputation beyond reputeNegadivOne has a reputation beyond reputeNegadivOne has a reputation beyond reputeNegadivOne has a reputation beyond reputeNegadivOne has a reputation beyond reputeNegadivOne has a reputation beyond reputeNegadivOne has a reputation beyond reputeNegadivOne has a reputation beyond reputeNegadivOne has a reputation beyond repute
Yeah I have that mic mount and I love it. I wouldnt really try to use it on anything other than snare though. Its kind of tall, so I clip it to the lower lug on my snare and then the mic ends up just above the rim, which is perfect for me. Its really sturdy too, I never worry about it moving around or rattling.
THATS RIGHT! MUSIC!!!
My Music Myspace
  #14
Old 12-26-2006
Force of Nature
yeah im actually liking this thing alot too really.
Help: Mic Decisions and My Trip to Guitar Center JohnnyMan Microphones 61 04-16-2006 22:38
nanocomp better than art tube mic pre? trdn1 Other Equipment and Reviews 2 03-11-2006 12:22
AKG mics part III- Condensers Richard Monroe Microphones 17 12-30-2005 07:57
Beginner's Mic Queries!!! Ma/T Microphones 4 07-28-2001 01:26
