Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 12-08-2006
djclueveli djclueveli is offline
Dedicated Member
djclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond repute
gain reduction on vocals
when someone says they get about 6 db gain reduction that means that the gain reduction meter stays on 6 or jus when peaks come? might be a confusing question but if you understand it please reply. What is yalls approach when compressing vocals? thanks
Old 12-08-2006
xstatic xstatic is offline
Been Here, Posted That
xstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond repute
I think that the answer varies form person to person. When I talk about how much gain reduction I am using I do not refer to the "peak" value but more to what the compressor is averaging in gain reduction. I find that peak values do not tell much or explain mush about how the comp is being used. Not to mention peak values are more dependant upon individual events that do not necessarily have any consistency. A more "average" value though tells me more about how the comp is being driven which allows me to use knowledge and experience to better guess how it may or may not function and/or apply to certain instances.
Dealer for Peluso Microphones, Blue Microphones and CBI cables....
http://www.myspace.com/xstaticstudios
Old 12-08-2006
Dedicated Member
thanks for the feedback. for the attack time, do vocals need slow attack time (100ms and above) since they dont have as much low end as say drums?
Old 12-08-2006
lomky lomky is offline
So much to learn
lomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond repute
Your going to hear this alot when talking about this stuff, but there are no rules for this stuff. But, I'm sure someone will correct me if I'm wrong, I find that faster attack times on vox gives me more pumping and breathing.
Old 12-08-2006
RedStone's Avatar
RedStone RedStone is offline
Booster
RedStone has a reputation beyond reputeRedStone has a reputation beyond reputeRedStone has a reputation beyond reputeRedStone has a reputation beyond reputeRedStone has a reputation beyond reputeRedStone has a reputation beyond reputeRedStone has a reputation beyond reputeRedStone has a reputation beyond reputeRedStone has a reputation beyond reputeRedStone has a reputation beyond reputeRedStone has a reputation beyond repute
you really do have to just play with it to make it work ... but if it's any help, here's what I do for pop stuff ...
Vocals aren't all that complex (say compared to a drum kit or an entire mix) - and for typical pop vocals, you want to tame those peaks that go over the threshold you set. Myself, I don't want to make my vocals too obviously compressed.
If you use a fast attack (say, 20 ms), it will clamp down more quickly than a slow attack (say, 100ms). How much it clamps depends on the ratio you set. For something like bass, if you use a fast attack, you'll lose all of the attack from each note you pluck and the back end of the note will be louder - which isn't usually desirable unless you want a sustained effect (in which case, you would set a low threshold along with a slow attack and release).
For vocals, a fast attack will tame bursts of volume that make the vocalist sit unevenly in the mix. The release will give you more or less of the compressor's sound - for transparent compression on vocals I try to set the release and threshold to be just enough so that the quiet notes are *just* allowed to go through without any compression being applied. Typically, I'll watch the meter to see how long it's taking to get back to 0 before the next syllable comes. If it's not all the way up to 0, then the release might be too long. If it reaches and stays at 0 for several ms, then it might be too short.
Here's the catch - depending on the music, and the threshold/ratio you set, nearly any combination might work.
Click.Listen.Enjoy
Old 12-08-2006
NYMorningstar NYMorningstar is offline
Recording Modus Operandi
NYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond repute
Another consideration is taking the compressor right out of the recording chain to avoid signal degradation. Vocals usually are pretty easy to track without one and the compressor should be removed unless you are using it for sound enhancement.
Get a whip and tame the vocalist instead.
Originally Posted by chessrock
There's this thing on our site ... called "the Newbie section." And it's really cool. And even if your name isn't NYMonrningstar, you can still get a lot out of it. .
Old 12-08-2006
FALKEN's Avatar
FALKEN FALKEN is offline
FALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond repute
I think the whole cutting the attack off on bass can sound cool given the right song. I think with instruments like bass and drums the tempo of the song plays a huge role. with vocals its sort of based on style. when I think of "gain reduciton" I think of the peak gain reduction. for me, it makes it easier to recall settings.
Old 12-08-2006
Grilled_Cheese's Avatar
Grilled_Cheese Grilled_Cheese is offline
Everyone loves cheese!
Grilled_Cheese has a reputation beyond reputeGrilled_Cheese has a reputation beyond reputeGrilled_Cheese has a reputation beyond reputeGrilled_Cheese has a reputation beyond reputeGrilled_Cheese has a reputation beyond reputeGrilled_Cheese has a reputation beyond reputeGrilled_Cheese has a reputation beyond reputeGrilled_Cheese has a reputation beyond reputeGrilled_Cheese has a reputation beyond reputeGrilled_Cheese has a reputation beyond reputeGrilled_Cheese has a reputation beyond repute
I've never met a vocalist who could go from soft quiet parts, to screaming loud parts all at the same volume.
I guess I should keep whipping him and see if that helps?
Old 12-08-2006
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is online now
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
Who says they need to be at the same volume? A soft, quiet part is a soft quiet part. It should not be coming across in the final mix at the same level at the loud screaming parts anyway.
Leave it au jus. One can always compress the gravy in post.
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
Old 12-08-2006
G.
Well, obviously I didn't mean the exact same volume.
Old 12-08-2006
This can be tamed quite a bit by good mic technique and kept in check by proper gain staging. A compressor is not necessary. At all times if you are clipping your converter than you just have the gain set too high.
Dynamic Mics and Gain, and more Gain Phinney Microphones 4 06-13-2005 15:50
The Mic Test Thread! Rhythmschism Microphones 41 04-30-2004 12:23
Okay, you songwriters...feedback Greenshoe Songwriting, Singing & Vocals 20 08-13-2003 13:11
when im recordin vocals and stuff um, what would i need to do to cut out all backgrou jugalo180 DJ & Hip Hop Production 2 10-21-2002 09:03
