Mastering chain?
I wish to set up an external mastering chain going from a computer DAW to analogue external devices. I believe I have all of the hardware.
1. What hardware belongs in the chain? DA converter, preamp, equalizer, compressor, AD converter? 2. In what order, the external analogue devices? 3. What sort of analogue devices should I consider? I am sometimes striving to smooth a harsh digital sound. I would appreciate any advice in this issue. Yours, ES |
What do you need a preamp for? your signal is already at line level..is it just do add coloration? If indeed you do have the hardware, then what i would suggest is...
DA--->preamp--->comp--->EQ--->AD
There are 10 types of people...those who understand binary and those who don't My humble home studio! My Choons My DIY Broadband absorbers thread! Mbox2, MacMini (Intel), Mackie HR624, Focusrite Liquid Mix, Frontier Design AlphaTrack |
Preamp?
Thank you MD for your response.
I perceive that my signal often weakens by passing it through several analogue processing stages. I perceive that for whatever reason, my signal is often somewhat weak by the time I am ready to master. I have read that simply passing a signal through a good preamp at unit gain may add some good quality to a digital signal. Finally, I do not know; that is what I am asking. Yours, ES |
You need to find out what the "for whatever reason" is and fix that. You may also want to score a copy of Mastering Audio by Bob Katz http://www.digido.com/modules.php?na...showpage&pid=4
because the mastering stage is alot more than just having all the hardware.
have you considered impedance? how are you outputting to your signal path? as for the Mastering Audio book, it's frickin' amazing. I strongly suggest getting it.
In most cases I would put the EQ before the comp, and yes you shouldn't require a preamp. A preamp (mostly tube) is used to add color, not to makeup for an issue in your chain. Verify levels by running reference tones with all of the units set at unity gain through the chain to see where the issue is. If what goes in doesn't come out essentially the same, then I wouldn't use those pieces for mastering.
Tom Volpicelli The Mastering House Inc. www.masteringhouse.com MySpace: www.myspace.com/masteringhouse |
Throw a patchbay in there so you can reposition whatever you have (EQs, comps, etc.) in whatever order you like. Mastering houses typically have sometimes very highly customized consoles that do this, but if you don't mind patching cables, you can accomplish the same thing.
As for level, you should be able to set final level with the makeup gain on your compressor, if that is last in your chain. EQs often have a master level control too. |
Thank you again
Thank you again for your suggestions.
I will try the things you have suggested. Yes, a patchbay would help me, but perhaps lose some signal? Yes, impedance matching is somewhat of a mystery to me. I am sending my final signal through a Lavry AD converter. I purchased a Radial box just in case I need to match impedances. I need to really get myself set up and try our your suggestions. Yours, ES |
A patchbay won't effect a properly set up system much. |
| My Mastering Perspective | Autist | Mixing / Mastering | 27 | 07-26-2005 09:22 |
| Mastering guys... | bennychico11 | Mixing / Mastering | 10 | 06-19-2005 23:13 |
| My first mastering experience | MrLip | Mixing / Mastering | 17 | 05-08-2002 13:30 |
| Mastering - Oh no not again!! | John Sayers | Mixing / Mastering | 14 | 01-22-2002 00:08 |
| Mastering yourself with LOTS of time vs. Mastering House (couple of hours) | Dijoux | Mixing / Mastering | 11 | 07-10-2001 04:05 |
