Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 12-05-2006
DM1 DM1 is offline
Senior Member
DM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond repute
Strategic approach to vocal delay
What's your philosophy for using delay effects on vocal tracks?
After reading Charles Dye's HDL, I started setting up every mix with 2 delay sends (a 1/4 note and an 1/8th note,) and routing tracks there to see what works. I really like this approach over my old style, which was basically just "randomly slap delay on things in the hope that something sounds good."
But it occured to me that even Dye's approach is still hit-or-miss, at least for me. While I've got a better chance of success with musically-timed delays, I still lack an overall strategy for choosing delays that suit the material I'm mixing.
So I'd appreciate any thoughts from the hive mind here about using delay on vocal tracks. How do you approach it? Do you have a structured method for setting up delay sends? How do you determine from the source material which vocal delay effects are appropriate?
Old 12-05-2006
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is offline
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
It all comes down to being able to mentally hear in your head what the production should sound like when it's done...before you even start. That'll tell you what you need to do.
It also means knowing in your head ahead of time what quarter- and eighth-note delays sound like. You gotta know the colors before you can paint the picture.
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
Old 12-05-2006
7string's Avatar
7string 7string is offline
Force of Nature
7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute7string has a reputation beyond repute
G.
If the picture has no "number = color" guide, I'm screwed.
That explains most of my mixes.
7
Friends don't let friends mix drunk...
You can lead a horse to water... but he has to put on his own scuba gear...
I'd give my right arm to be ambidextrous...
I like the tempo but I don't like the beat. I give it a 6, Dick...
Old 12-07-2006
DM1 DM1 is offline
Senior Member
Which is true of everything in music production.
But surely there are less esoteric elements to how you choose which delay will best suit a vocal.
As an analogy: When I choose guitar tones for a song, I do it based (obviously) on my knowledge of the the various effects available to me, and how they affect the sound. That's the stuff that, like you said, I have to know ahead of time.
But there's also some conscious, deliberate reasoning I need to do: "This is a lead part, so it has to cut through. Therefore I need more presence" or "this is one of 3 guitars, so I need a thinner tone" or "this part will be doubled, so ease off on the distortion."
That's the kind of thing I was trying to get at with the original post. Assuming you know how delays work and sound, what kind of questions do you ask yourself when deciding how to apply delay to a vocal?
Old 12-07-2006
HangDawg's Avatar
HangDawg HangDawg is offline
bUnGhOlIo
HangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond repute
Hmmm, maybe
"Does this sound like shit?"
http://www.garagerecording.com/images/lava22.gif
SELECT W.People
FROM tbl_world W
WHERE W.Clue = TRUE
NO RECORDS RETURNED
Old 12-07-2006
ecktronic's Avatar
ecktronic ecktronic is offline
Mr Mix and Master Man.
ecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond repute
G.
Such wise words (as usual) from Glen.
If you feel you arent sure what will work in a mix, even when its in the mix then you should listen to commercial CDs that have ideas you would like to put into your mixes. I mean REALLY listen to the CDs. Listen on a good pair of headphones to hear ALL the small background details that some songs have that make them sound better.
Eck
Million dollar ears.
CRYSTAL MIXING
MY BAND
Old 12-07-2006
ecktronic's Avatar
You ask yourself. Will adding delay to the vocal make it sound better. Is it necessary or will it just mess up my mix.
It is good to use bypass automation on the delay for vocals.
Set up your delay so its in time with the song you are mixing and then have it bypassed. Whenever you come across a part of a song that sounds a little empty. As in, there is a gap in intruments or the intruments kinda die donw or the energy dies down (even for a small amount of time) , then hit the unbypass button on your delay and see how it fits in. Try out different settings on the delay and if you cant get it to fit then maybe the mix is not asking for a delay on the vocals at that moment.
Eck
CRYSTAL MIXING
MY BAND
Old 12-07-2006
TuoKaerf's Avatar
TuoKaerf TuoKaerf is offline
Music To Punch Babies To
TuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant future
Well, it all depends on the style of music. That first off dictates if I will even use any effects in my vocal chain. Next is matching the delay time to fit the music. This might mean automating if you are using a plugin if the song was not tracked very tightly.
Think about how the delay will go with the lead melody of the song. A quarter note delay might not gel well on a song in 7/8.
In any case, try something and see if it sounds good. That's the best route to go in my world.
Digi Certified
http://www.protoolsforum.com/images/PTBanner.jpeg
Old 12-07-2006
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
How about beginning with breaking it down into it's basic chunks. Short panned for width, or centered for thickness, modulate for some movement/pitch. Mediums' centered (or spread) for tempo/rhythm or depth. Long ones.. pretty obvious.
Old 12-07-2006
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
And that would be right next to the 'any' key --- as in 'hit any key to continue'.
...now in HD.
Old 12-07-2006
austinm08 austinm08 is offline
rocker
austinm08 has a reputation beyond reputeaustinm08 has a reputation beyond reputeaustinm08 has a reputation beyond reputeaustinm08 has a reputation beyond reputeaustinm08 has a reputation beyond reputeaustinm08 has a reputation beyond reputeaustinm08 has a reputation beyond reputeaustinm08 has a reputation beyond reputeaustinm08 has a reputation beyond reputeaustinm08 has a reputation beyond reputeaustinm08 has a reputation beyond repute
Pressanykey.com!
simple question: what is the best vocal mic out there for recording and also wireless i and i Microphones 16 05-14-2005 18:55
NEWBIES - FINAL ARTICLE - VOCAL, ORCHESTRAL AND CHOIR recording tips. manning1 Newbies 0 01-07-2004 13:54
Music - please rip apart Greenshoe MP3 Mixing Clinic 20 07-29-2003 00:49
We Want Like The Devil To Believe groucho MP3 Mixing Clinic 22 07-16-2003 18:57
Vocal Delay, Reverb, and Compression Douhgy Mixing / Mastering 4 02-02-2003 22:01
