Bus sends?
Does anyone know of a way to buss tracks to a channel so that the original tracks arent heard, but the bussed track is?
Is this even possible? Im wanting to do this so I can send 2 guitar tracks to the buss channel and apply effects to the buss channel so I only hear the effected guitars and not the un effected guitars. Cheers, Eck |
pre fader aux send. then mute the other tracks.
are we talking software or analog mixer?
www.redlabaudio.com |
Oops.
Im using Cubase. ![]() Eck |
I now have to use the aux sends as my guitar volume controls which isnt the best, but as long as Im not using volume automation then I should be fine. Cheers. Eck |
Have you considered just copying the original tracks to new tracks, processing the new ones, and muting the originals?
G. |
7 Friends don't let friends mix drunk... You can lead a horse to water... but he has to put on his own scuba gear... I'd give my right arm to be ambidextrous... I like the tempo but I don't like the beat. I give it a 6, Dick... |
Just buss your channels to a group, and then insert the effect you want on that group with the effect being 100% wet.
Dealer for Peluso Microphones, Blue Microphones and CBI cables.... http://www.myspace.com/xstaticstudios |
I guess different programs do it different ways. Prefader send should be before mute/solo. I guess just pull the fader down instead.
Actually, prefade should normally cut when the channel is cut as well. At least if you are assumoing it will act like hardware.
pushing mute on a channel that has it's send to prefader should NOT affect what's going to the send. This is the whole reason for the pre fader. So no mute, solo, fader, even pan changes affect what's going to the aux send...typically a cue mix (therefore the engineer can solo tracks in the studio to listen to without effecting what the band is hearing) Example: From the Mackie 32-8 Manual With the PRE switch depressed, Aux Sends 1&2 receive their input from a point before the channel fader and MUTE switch, and are not affected by changes in these controls. This is the normal setting for creating stage monitor and/or cue headphone sends. This is the way it works in Pro Tools too. I can't think of any logical reason to make it so the mute button still affects a prefader send. Makes the prefader send pointless.
Eck |
#12
easy: set up your buss output and input, then take whatever tracks yer bussing out of the stereo buss!
or have it so that the tracks you don't want to hear don't have an output.
There are 10 types of people...those who understand binary and those who don't My humble home studio! My Choons My DIY Broadband absorbers thread! Mbox2, MacMini (Intel), Mackie HR624, Focusrite Liquid Mix, Frontier Design AlphaTrack |
#13
.But yeah, you could create a stem file, a sub mix of your guitars and run the effects on that while keeping the source tracks muted. G. |
#14
You don't need to set up sends...
Just set the output of the individual tracks to a stereo bus and apply your effects there. Route the resulting "guitar" bus to your master. Why would you need to mute anything?
Some of my music |
#15
many different ways to do one thing ![]()
#16
With DAW software however I would imagine that there is an option for how prefade sends are treated. Even on actual consoles there are sometimes options. Usually this option is whether or not the EQ tracks to the prefade sends. As a point of reference, I would not assume that just because Mackie implemented something that it is standard for all consoles. I have consoles by Soundcraft, Yamaha, Midas, D&R, Allen Heath and even a couple little Mackie's. NONE of them leave a channel's prefade send open when the channel itself is muted.
#17
You're right. It looks like this varies from console to console (particularly found in larger format). I'm just looking at the Allen & Heath ML3000 model and it offers post mute send...although they offer you the choice of also setting it pre-mute via an internal jumper.
It's been awhile since I've worked with larger format consoles that offer every option under the sun. I'm mostly all in the computer now. I guess it depends on the manufacturer and what they want to put on their mixer/console. I just wouldn't ever want to mess up a headphone cue mix because I hit the mute button when trying to listen to something.
#18
I have an ML5000... I am not sure which jumpers it allows, but pre fade sends still mute when the channel is muted. This is a stock setting. In fact, they do on the ML3000 as well. I understand not wanting to accidentally mute a portion of the mix, but being able to mute something in a hurry is actually a much better option. This is especially true when dealing with live stage monitors which really surprises me that Mackie would say that a prefade send not being affected by a channel mute is standard. That in my opinion would be plain old wrong. I do like the option though of being able to do that, but I like it better as an internal jumper or at least a recessed button that can not accidentally be depressed. In my opinion this needs to be something that a person only activates when they are fully aware of all the ramifications.
#19
Eck |
#20
You need to set up a group channel. Set the output of the guitar channels to route to the group channel. Done.
Don't use the AUX, don't use FX channels.
#21
See my post from earlier... (#7)....
Several people since have given you the exact same recomendation.... That might be a good place to start ![]()
#22
Im sure in Cubase SX3 it doesnt work like that. Seems that the group and FX channels are the same, just a different colour and a way of seperating your busses to avoid confusion. Cheers all, Eck |
#23
#24
Open a channel by hitting the 'e' button. Above the fader, the pan control and the trim control and below the input selection, there is a box that selects the ouput of that channel. Set that to the group you want to send it to. This is exactly how cubase SX works. The difference between groups and fx channels is that the fx channels can't be bussed anywhere but the outputs.
#25
| Soundtracs Topaz Project 8 | Nick The Man | Other Equipment and Reviews | 30 | 04-08-2008 14:02 |
| bus pan question | dctoms | Cakewalk / Sonar Forum | 3 | 01-14-2004 12:50 |
| Overclocking. | tonester | Digital Recording & Computers | 7 | 10-16-2001 14:49 |
| overclock lock | twist | Digital Recording & Computers | 5 | 02-22-2001 20:21 |
