Distorted Guitar Mixing
Hey guys. Well ive been learning all this recording stuff for a while now and am proud to say that I am getting alot better thanks to the readings of this forum!
The problem I continue to have is still with guitars. I finally learned some EQ techniques and making sure 2 guitars dont fight eachother on certain frequencies. It seems like in the mix, the distorted guitar parts are always very dull, non lively, far away and can hardly tell changes in notes. I know the source sound is good, because when I listen to the guitar tracks by themselves, the guitar sounds great. My vocals and bass sound fine in the mix. If I can just get those guitars mixing well, i feel my mixes would be where i want em. Are there any tips anyone has when working with distorted guitars in a mix that you guys have found successfull (recording, eq, etc)? I record direct with ToneLab....but dont think thats the problem since the recorded sounds are great....its just a problem in the mix. Also is it bad to record distorted guitar sound with reverb or should I record it dry and add reverb later or not at all? Note: I have the 2 different guitars (which is the same part, just different performances) panned out hard left and hard right and recorded in mono. |
Reverb later. Definitely! Get a good mix dry, if you can, then add effects for... well, for effect.
Also- how is your low end? Bass and low mids can get *really* muddy very fast. There is a lot of energy in those frequncies and they can build up and squash your clarity pretty fast. I tend to roll off everything below 100hz or so on guitars. Leaves more room for the kick and bass. You can probably cut all the way up to 240 if you have a good bass sound, but it will sound different when you solo it. If I recall, 240 is twice the frequency of the lowest note a guitar can hit in standard tunining- Low E. I know you like the sound of the guitars by themselves... but that doesn't mean the sound will work well in the mix. Could be that the bass and the guitars are fighting in the low mids and you're losing clarity. Try cutting the lows. Also, are you compressing those guitars? Are they *heavily* distorted? Distortion compresses things "naturally" and adding more compression on top, if done poorly, will suck the life out of the take. No dynamics at all- which sounds like what you are describing. Players who use heavy distortion tend to play very purcusively- they have little stops and starts in the playing to give the track more dynamics. They also tend to record with less distortion than most people think- try turning down the gain in the distortion a little. You'll usually find that TWO (or more) less distorted tracks sound more distorted than they are. Most people try to get that huge sound with one guitar then record it twice. That gets you mud. Try backing off that gain and see if you like it. Its a balancing act. Anyway, that's what comes to mind at the moment. Take care, Chris |
thanks Chris for those great tips.
I will try your suggestions a try and see what happens. The idea of less gain makes alot of sense and I will try rolling off those lows on the guitars and let the bass and bass drum take hold of those lowers. Another question about the reverb subject: Do people ever add reverb to the mix, instead of to each individual instrument? |
As far as the reverb thing, it depends on what you're going for. Think of reverb as a virtual room. What do you want to put in that room? Do you want the whole band in there, or just the guitars or snare or all the drums or just vocals? I say just experiment, its the fastest way to learn. |
Eck |
"Introduce a little anarchy. Upset the established order, and everything becomes chaos. I'm an agent of chaos. Oh, and you know the thing about chaos? It's fair..." |
They way reverb works if you have a mixing board or a DAW is as a send and return. Instead of setting up individual reverbs for each sound, you set up 1 reverb and send bits of your mix to it. You send only a little of your lead vocal, for example, but more of the backing vocals- makes the backing vocals sound further away. Its done with aux sends and either effects returns or busses. In Pro Tools I create an aux track and put the reverb insert on that track. Then I set the input of that track as bus 1&2 (stereo), for example. Then I can set up a volume and pan control for every channel that needs reverb and it becomes a "reverb knob". The volume of the aux channel with the reverb on it control the overall level of the reverb. A mixer is used the same way- you just use hardware channels and knobs to do it. So its like having 1 reverb on the whole mix, but you can control the level of each track going to it. Last thing- go *easy* on the reverb. Less is usually more unless you're going for some dreamy, gothic effect. Its main purpose in a mix tends to be defining how FAR away from you a sound is. Some folks use it because it makes things sound better- but the more you turn up the reverb the farther a sound get from you. Harder to hear. Long reverbs also fill the sonic space of a track FAST. With all that sound happening all over the place there is less room for the notes that are happening NOW to be heard. It might make an instrument sound great by itself, but it'll trash a mix faster than anything. Take care, Chris |
I don't know the type of direct injection your using, but usually if it isn't a high end box you can probably get a much better sound from a 57 or I5 on a speaker. I really don't believe the whole statment that "my solo;d track sounds great, but shitty in the mix". I think you should rewind and try some other tracking methods. |
I wouldnt say the guitar soloed will sound great if it doesnt fit in the mix right. Even without any mixing the guitars should sound ok in the mix. Eck |
I use VOX Tonelab too, mostly preset "carlos" without echoes and quite a little gain. someone has once complimented, my sounds....
They vary from mix to mix, and the settings are always the same on tonelab.. I eq the shit out of them guitars, main eq being: (7-band) 60hz rolled off plus4db in 150hz minus 5Db at 400Hz plus 4db at 1000hz 2400 flat plus 5db at 6000hz minus 10 at 15000hz That's mostly for color... at some point I end up usually killing everything under 400hz.(guitar) then usually tend to drop something from 400hz from the readily-made mix to remove mud. bassline eq also drops something from 400-1000hz, but I give a slight boost lower and at 2400hz and 6000hz.. read, memorize and print out: http://www.badmuckingfastard.com/sou...perman.html#EQ "slipperman's recording distorted guitars from hell" -good reading. ![]()
\m/ WAR OUT!! \m/ |
#12
abide by this rule... record the guitars brighter than you think...
#13
The few times I mix with distorted guitars, I find myself doing a lot of tracking and very little EQ at the end.
Use the EQ on your amp (or POD or whatever, if it has one), and try to get all the settings right on that first (turn the gain down, etc.). Keep retracking until it sounds good in the mix, and then apply a little EQ if you need to, to give the other instruments room. (I"ve retracked 20+ times before). I find it's a lot better to spend the time tracking than applying invasive EQ cuts that you'll end up not liking the next time you listen to it. Or keep trying to EQ the guitars and never getting a sound that you're happy with. Eventually, you'll learn how to get the right sound of the amp for the mix and it will save you a lot of time on future mixes. That's just my 2˘ |
#14
people hate what I say here, but I'm gonna add my one thing, and that is record with less distortion then you'd use for a 'live' distorted sound. That is all.
#15
I won the internets...... |
#16
Yep, if you get it right at the amp you'll need little to no eq in the final mix. Knowing how to track dirty guitars makes mixing them insanely easy. |
#17
Eck |
#18
What if you already recorded guitars with too much distortion?
I have projects that sounded great being tracked, but when mixed with other guitars and pushed up in the mix turn nasty. Anyway to fix those? I found that some Q Filters tend to remove some sizzle. Im just wondering if theres any good way to clean it up and still use it. And another question.... When backing down on the gain I definately see the great results for rythm work, but how do you record keeping good gain for leads and harmonics? Is it better to turn the gain down and throw in a Tube Screamer or Overdrive then to turn the gain back up to pull out some Zakk Wylde Pinch Harmonics or good lead saturation? Thanks.... |
#19
Not sure what the reason for this is. If anyone knows then please explain. Eck |
#20
#21
#22
![]() Sorry, that one has been impatient waiting to get used... G. |
#23
Simple, people use more distortion then is really needed and tend to record their guitars that way too. I'm not a guitar player so I can't tell you scientifically what's going on but turning down the gain was one of the first lessons I learned and has made recording distorted guitars much easier. |
#24
#25
| Best Mike and Preamp for distorted guitar | jamtheguitarman | Microphones | 38 | 12-05-2006 18:41 |
| mixing screw up between piano and guitar | bball_1523 | Newbies | 2 | 01-27-2006 23:40 |
| Mixing Bass Guitar | 7string | Mixing / Mastering | 12 | 03-09-2005 23:39 |
| Best method to record distorted guitar... | rweiss | Recording Techniques | 21 | 11-28-2004 23:53 |
| Condenser choices on Distorted guitar | mr. torture | Microphones | 21 | 06-29-2004 17:03 |
