Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 12-02-2006
ecktronic's Avatar
ecktronic ecktronic is offline
Mr Mix and Master Man.
ecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond repute
DrumaGog
I tried out Drumagog for the 1st time last night and couldnt seem to get the results I thought I would be able to acheive.
I am using the advanced version V4.
I am thinking that either its the bad gogs I am using or my lack of knowledge of this programme.
Does anyone have any tips on how to use Drumagog so it sounds like a real drummer hitting the drums? I am trying to replace quite technical and dynamic snare work.
Cheers.
Eck
Million dollar ears.
CRYSTAL MIXING
MY BAND
Old 12-02-2006
K.P. K.P. is offline
Junior Member
K.P. has a reputation beyond reputeK.P. has a reputation beyond reputeK.P. has a reputation beyond reputeK.P. has a reputation beyond reputeK.P. has a reputation beyond reputeK.P. has a reputation beyond reputeK.P. has a reputation beyond reputeK.P. has a reputation beyond reputeK.P. has a reputation beyond reputeK.P. has a reputation beyond reputeK.P. has a reputation beyond repute
can you be more specific about what's not right?
Some Amp Clips
Some More Amp Clips
Old 12-02-2006
metalhead28's Avatar
metalhead28 metalhead28 is offline
Hates Raymond
metalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond repute
Hey, eck
After working on your track myself, I'm telling you - nothing is going to be easy about replacing the snare on that track. Your drummer hits very dynamically....I could barely hear some of the hits...they hardly registered above the noise floor and the bleed from other drums was often louder than those soft hits....that's going to make drumagog alot more complicated. You're definitely going to have to do quite a bit of manual work. You'll probably need to break the track up into sections, filter it, limit it, probably copy and paste some shots to get it to replace all the hits...or you may not even want to replace all the hits. You'll definitely need a big sample set to replicate those dynamics. Alot of the samples that come with Drumagog won't cover it.
I've used drumagog alot, and when I was working with your track I ended up converting it to midi and running it through a sampler instead....it was easier. I was able to set my sensitivity really high when scanning the track, and then delete the false hits.
Some of my music
Old 12-02-2006
NL5's Avatar
NL5 NL5 is offline
Unpossible!
NL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond repute
I always use "advanced triggering" with a good gog that fits the song well. I've faked out 99% of the drummers I've gogged.
edit - after reading Metalheads post, you may be screwed a bit. I've had some pretty dynamic snare tracks before, but I kept the bleed pretty low - and, most of the quiter snare parts were when the entire drum track was pretty quiet.
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F.
Old 12-02-2006
ecktronic's Avatar
Cheers all.
Dang, I aint sure what to do, as I really want to change my snare sounds for most of the album. I suppose Ill have to do some things manually.
Cheers,
Eck
CRYSTAL MIXING
MY BAND
Old 12-02-2006
NL5's Avatar
NL5 NL5 is offline
Unpossible!
Originally Posted by ecktronic
Cheers all.
Cheers,
Eck
Are the drum tracks still up somewhere?
Old 12-02-2006
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
Use the mix control. That way the quieter ghost strokes will be heard even if they don't trigger a sample.
Another thing I do is use two mics on the snare (top and bottom) I use the top to trigger Drumagog and use the bottom mic to pick up anything that Drumagog just won't get. It tends to sound more real that way.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 12-02-2006
Hates Raymond
That's probably the best and easiest thing to do, have you tried getting away with that eck?
Another thing to consider, I bet alot of those ghost notes can't be heard in the mix anyway. It might not matter if you replaced them or not. I don't know what the rest of your tracks are like..that may be a problem.
Some of my music
Old 12-02-2006
ecktronic's Avatar
Cheers.
I am using the bottom snare track since there is less spill.
I suppose I could use EQ filter to get snare on top track.
The drum tracks are not up anymore sorry.
Ill give it a blast and hope for the best.
Eck
CRYSTAL MIXING
MY BAND
Fs: Drumagog Pro Discounted Drummerbones Free Ads for Music / Recording Equipment 5 04-13-2006 11:07
Drumagog Question NL5 Mixing / Mastering 11 02-27-2006 16:25
Drumagog Help ryanformato Drums and Percussion 3 10-20-2005 13:19
Drumagog Freezing Up N-track Drummerbones Digital Recording & Computers 5 07-26-2005 07:38
Drumagog freezing up N-Track Drummerbones Digital Recording & Computers 4 06-20-2005 10:33
