Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 12-02-2006
Melsi's Avatar
Melsi Melsi is offline
Padawan
Melsi has a reputation beyond reputeMelsi has a reputation beyond reputeMelsi has a reputation beyond reputeMelsi has a reputation beyond reputeMelsi has a reputation beyond reputeMelsi has a reputation beyond reputeMelsi has a reputation beyond reputeMelsi has a reputation beyond reputeMelsi has a reputation beyond reputeMelsi has a reputation beyond reputeMelsi has a reputation beyond repute
cpu usage and mixing
i was wondering if anyone could tell me how i could improve my situation.
I have a dell dimension 8400 computer with 3.00ghz processor and 512ram 80gig hard drive with an ESI waveterminal soundcard.
and when im in sonar and im mixing my projects using mostly waves products my cpu goes over the roof!
also when im producing in fruity and i load a few plugins i get loads of cracking so i have to move my latency right up and that gives everything such a slow response!
do i just need to upgrade my ram? if so what would be suitable?
Thanks in advance!
Melsi
Old 12-02-2006
Melsi's Avatar
Padawan
sorry just to let people i know, i jus found out that cpu its takes up effects - reverbs etc... and ram takes up vsti plugins, but i have 3.00ghz cpu which i thought was pretty high? so why is my cpu overloading when i add lots of waves plugins?
Melsi
Old 12-02-2006
danny.guitar
Guest
Posts: n/a
I don't know what the ESI terminal soundcard is...
What plugins are you using of Waves and how many, on how many tracks?
This won't have much to do with RAM unless some of the effects you're running are MIDI VSTi's (Virtual Instruments). If they're just effects like reverb, compressors, etc., then it will be your CPU.
Old 12-02-2006
ez_willis's Avatar
ez_willis ez_willis is online now
Virtual Ninja
ez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond repute
Start with this article from Ethan Winer's site.
Originally Posted by 60's guy View Post
You win.
Old 12-02-2006
K.P. K.P. is offline
Junior Member
K.P. has a reputation beyond reputeK.P. has a reputation beyond reputeK.P. has a reputation beyond reputeK.P. has a reputation beyond reputeK.P. has a reputation beyond reputeK.P. has a reputation beyond reputeK.P. has a reputation beyond reputeK.P. has a reputation beyond reputeK.P. has a reputation beyond reputeK.P. has a reputation beyond reputeK.P. has a reputation beyond repute
you pretty much sums up the DAW workings. more specific info on track/plugin counts is needed
also, you could do with more RAM.
Some Amp Clips
Some More Amp Clips
Old 12-02-2006
Freudian Slip's Avatar
Freudian Slip Freudian Slip is offline
Source Of Confusion
Freudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond repute
What 3.0 processor do you have? p4, celeron?
Some waves plugs really suck up processor power. C4 is really bad and there are a few others as well.
I'm really wondering about that chip though. Like to hear what KP is asking too.
F.S.
"If Congress can do whatever in their discretion can be done by money, and will promote the General Welfare, the Government is no longer a limited one, possessing enumerated powers, but an indefinite one"
James Madison: the father of the Constitution
Old 12-02-2006
Melsi's Avatar
Padawan
its a pentium 4, and im using about 10 different vocal tracks each track has compression,eq,gate and reverb maybe antares mic modeller and autotune, and my cpu usage is just crazy!
Melsi
Old 12-02-2006
ecktronic's Avatar
ecktronic ecktronic is offline
Mr Mix and Master Man.
ecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond repute
Reverb will take up alot of your cpu since it is taking thousands of tiny samples of the wave like a delay does.
I would suggest using reverb busses to send tracks to so you dont need as many reverb plug ins.
Eck
Million dollar ears.
CRYSTAL MIXING
MY BAND
Old 12-02-2006
Junior Member
Eck
yep, learn to utilize Reverb Busses. for starters, set up a Short Rm, Med Room, Hall...
you can also buss common tracks like rhythm guitars, backing vox... and treat them as a unit.
treat as much as possible as a unit.
Some Amp Clips
Some More Amp Clips
Old 12-02-2006
ecktronic's Avatar
Yeah, good advice. Becuase I use 2 tracks for each guitar part I usually send those tracks to a channel so I only need half the amount of effects. And when you have like 20 guitar tracks this can save alot of cpu.
Eck
CRYSTAL MIXING
MY BAND
Old 12-02-2006
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is offline
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
You have more than enough CPU and RAM to run your projects. The problem is "sloppy" track management (I don't mean that in a perjorative way.)
What you need to do is "lock" or "freeze" or "pre-render" (whichever it's called in Sonar) the tracks that you are not currently working on. and leave only those tracks that you're currently working on to real-time processing.
If you need to go back and modify previously locked tracks, no problem; you can just "unlock" them and they revert to their unrendered, real-time conditon.
Use this feature and on a 3GHz CPU with a half-gig memory you can run and work on more tracks than you'll even need in one project without hvaing to spend a penny on hardware upgrades or having to spend hours chasing a bunch of esoteric driver and memory resource settings.
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
  #12
Old 12-02-2006
Source Of Confusion
Ya it's a freeze in sonar and it's un freezable just like SouthSIDE Glen said.
Like others said P4 you should not have an issue if you change the way you are doing things in either of the ways described, you could also create a sub and place your verb on that and run your vocals threw there and loose all those seperate instances of verb. It's a lot less work too than setting up all those plugs.
F.S.
  #13
Old 12-02-2006
ecktronic's Avatar
Freezing is the shizny.
CAn be annoying when moving a number of tracks if you forget some tracks you are trying to move are frozen. Can mess up a whole session!
Also can take a while to render a number of tracks.
I usually freeze the kick and snare tracks once I am happy with them. That freeze (pardon the pun) up alot of cpu for me to work with.
I find my cpu gets slow and jerky after around 30-40 tracks with at least 2 plug ins on each. (usually RComp and REQ).
Eck
CRYSTAL MIXING
MY BAND
  #14
Old 12-02-2006
Source Of Confusion
Eck
*shakes his head*
F.S.
  #15
Old 12-02-2006
Melsi's Avatar
Padawan
ok thanks for the tips guys, so what about in fruity loops when i have lots of different plugins-instruments open and it gets all crackly? how can i solve this?
Melsi
  #16
Old 12-02-2006
haarisa haarisa is offline
Newbie
haarisa has a reputation beyond reputehaarisa has a reputation beyond reputehaarisa has a reputation beyond reputehaarisa has a reputation beyond reputehaarisa has a reputation beyond reputehaarisa has a reputation beyond reputehaarisa has a reputation beyond reputehaarisa has a reputation beyond reputehaarisa has a reputation beyond reputehaarisa has a reputation beyond reputehaarisa has a reputation beyond repute
Try to seee what your latency is at. That happens only when I have too much VST instruments running. Try to render some to wave [particularly Legacy Cell as that takes up TONS of RAM and cycles]. Hope that helps. If not, turn up the latency to 512 ms.
  #17
Old 12-03-2006
ecktronic's Avatar
Originally Posted by Freudian Slip
*shakes his head*
F.S.
I know.
Eck
CRYSTAL MIXING
MY BAND
  #18
Old 12-03-2006
IronFlippy's Avatar
IronFlippy IronFlippy is offline
Dedicated To My Member
IronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond repute
Regarding busses: If you bus the reverb, it'll give the whole song more of an effect of being in the same room since you're using the same exact settings for each track.
I can't listen to that much Wagner. I start getting the urge to conquer Poland.
  #19
Old 12-03-2006
Agreed, it can add a nice "glue" to the mix.
I'd like to add a caveat to that, though; be careful of verbing the mix buss if you already have verb happening on any of your individual tracks. Stacking verb like that can build up to a lot of mud real quickly if not done carefully. Just a hint of verb on the buss may be all that's needed in such cases - if that.
But then again, that then goes against the jist of this thread; verbing the tracks *and* the buss is adding more CPU load, not removing it .
G.
Glen J. Stephan,
  #20
Old 12-03-2006
danny.guitar
Guest
Posts: n/a
I've used GlaceVerb for that "glue" effect.
I just set a small room size, small decay, and turn the dry to 100%, wet to 0%. Turn up the wet gain until I can hear it, and then turn it back down a little.
Very subtle but it does have a nice effect.
Control Surface vs. Analog Board for Mixing fluxburn Mixing / Mastering 5 05-27-2004 11:10
Will upgrading to 256MB RAM help plugin usage? 4-Man Takedown Digital Recording & Computers 15 02-24-2004 14:17
question about usage of tracks (MR-8) kesterdevine Fostex Forum 6 12-09-2003 05:22
recording a ska band... mic usage? Rocket Boy Microphones 4 12-03-2003 03:12
Recording Software RAM Usage KingstonRock Digital Recording & Computers 7 07-02-2003 03:27
