Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 12-01-2006
Chris Shaeffer's Avatar
Chris Shaeffer Chris Shaeffer is offline
Peavey ROCKS!!!!!!!!!!!!!
Chris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond repute
Shipping a drum kit?
Anyone have some insight into shipping a 5 piece kit to Hawaii?
I have a 70's Rogers kit that I want to get over to Hawaii but couldn't fit it on the boat shipment with the rest of the gear. So now I have to box and ship it. Expensive, but I'm trying to figure out the most efficient (i.e. cheapest) way to do it.
I was thinking of stripping everything off the shells, putting them inside each other, padding the crap out of it and putting it all in one box. All of the other hardware has already been shipped so I don't have to worry about stands.
Am I on the right track? Never done this before and I'd hate to screw the kit up because I don't know what I'm doing...
Thanks,
Chris
Old 12-01-2006
petermiller's Avatar
petermiller petermiller is offline
It is what it is
petermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond repute
that would be the way to do it if you want to send it in one box. just make sure to keep the bearing edges protected. Bubble wrap between shells would be fine.
Peter Miller
Old 12-02-2006
fritzmusic fritzmusic is offline
Senior Member
fritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond repute
Leave as much intact as possible and just use more boxes. It's the combined weight they charge for, not quantity of boxes. Assembled or not, tearing your drums down to fit in one box would only convenience the shipper more than yourself and won't change it's total weight.
Old 12-03-2006
PYRRHO PYRRHO is offline
Senior Member
PYRRHO has a reputation beyond reputePYRRHO has a reputation beyond reputePYRRHO has a reputation beyond reputePYRRHO has a reputation beyond reputePYRRHO has a reputation beyond reputePYRRHO has a reputation beyond reputePYRRHO has a reputation beyond reputePYRRHO has a reputation beyond reputePYRRHO has a reputation beyond reputePYRRHO has a reputation beyond reputePYRRHO has a reputation beyond repute
DO break down the kit...you're on the right track.
Sending 2 large and 3 medium boxes of moderate weight will cost more than sending 1 large, heavy box of the same total weight. Besides the more boxes you put into the system means the more likely you'll be faced with damaged and/or missing items.
And please...
When using bubble-wrap...the bubbles face TOWARDS the item being wrapped, not away. When wrapped with the bubbles out, you may as well use newspaper...it does nothing.
Looking for cheap, decent digital drum kit + keyboard KJI Newbies 3 11-16-2006 18:40
Drum kit on a tight budget - or better off with software? amonte Drums and Percussion 26 08-26-2005 19:52
Low Budget Drum Kit travelin travis Drums and Percussion 30 08-17-2005 02:56
New Toy need help. Roland Drum Kit inet-projects Newbies 2 09-11-2004 05:56
Electronic Drum kit as midi controller in Cubase jkstraw MIDI Mania 1 07-03-2004 07:42
