457 for Tascam 22-2?
Quantegy 457 is good to go with a Tascam 22-2, right?
As long as it's aligned for that tape, yes.
It's even more than you need, but will work well.
407 is probably optimum if you want your meters to read 0 VU at the designated flux. The 22-2 was designed for use with a wide range of tape, specifically marketed to home recordists using readily available hi-fi tape, at the time found at most stores including Radio Shack and K-Mart. Thus the flux level is around 200 nWb/m the same as commonly found on a hi-fi unit, rather than the 250 nWb/m of the 32. The recommended tape was Ampex 407, Maxell 35-90 and 35-90B, TDK Audua… even Radio Shack “Studio Quality Tape” will work. With 457 you can push the levels to your heart’s content. You can also calibrate the unit to 250 nWb/m as I did mine. I still use 407 though. Tim ![]()
«:: «::B::» «::E::» «::C::» «::K::» ::» "Where in the hell are the red M&M's?" ~My Lil' Sister, 1976 |
Thanks, Beck!
| FS: 2 Brand New Reels of Quantegy 457 1/4" tape - $25.00 | taperocket | Free Ads for Music / Recording Equipment | 4 | 08-28-2006 02:00 |
| Baking Ampex 457 1/4" Tape? | nickdahl | Analog Only | 4 | 05-28-2006 10:44 |
| 457 Source? | MULEFAN | Analog Only | 2 | 03-02-2006 05:17 |
| Question about Fostex A2 and 457 Tape | PHILANDDON | Analog Only | 2 | 02-28-2006 13:59 |
