Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 12-01-2006
hawk's Avatar
hawk hawk is offline
Senior Member
hawk is a glorious beacon of lighthawk is a glorious beacon of lighthawk is a glorious beacon of lighthawk is a glorious beacon of lighthawk is a glorious beacon of lighthawk is a glorious beacon of light
Need help installing pickup
I replaced the bridge pickup in my Strat with a Seymour Duncan JBjr humbucker. But now, there is bad noise (60 cycle hum,) in the bridge/middle position. There's even a little hum in the bridge position which should be totally quiet now due to the humbucker. I followed the instructions that came with it and wired it as follows:
red/white - taped together
black - soldered to switch
green - soldered to tone pot (ground)
Anyone know what the problem could be?
Old 12-01-2006
Light's Avatar
Light Light is offline
Born in the Light ofStars
Location: Creating saw dust at rapidly increasing levels
Light has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond repute
Not without seeeing it in person, but my first guess would be a bad solder joint.
Light
"Cowards can never be moral."
M.K. Gandhi
Old 12-01-2006
hawk's Avatar
Senior Member
Here's the way I wired it. Only thing that's different is that I didn't solder the red/white I just tied them together and taped them. I'll check the solder joints when I get home, maybe redo them.
The instructions said that if you have phasing problems reverse the black and green wires. Could that be the problem?
Old 12-01-2006
ggunn ggunn is offline
Crystal Flavolian
ggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond repute
I'm confused. The diagram shows the red and white soldered to the switch. Also it looks like there is a white wire with the green and another white wire with the red. Are there two white wires from the Duncan pickup? If so, how can you tell which is which?
Gordon in Austin
http://www.crystalflavola.com
Old 12-01-2006
hawk's Avatar
Senior Member
The pic shows the red/white soldered but to an empty spot on the switch, not connecting to anything. This *should* be the same as me taping them together. Not positive though. The tape is only temporary; I just wanted to make sure it works before soldering.
The other wire next to the green wire is actually a bare wire that the instructions say to connect with the green to the ground wire.
Old 12-01-2006
Crystal Flavolian
Ah, much clearer, thank you. You're right; twisting and taping should be good enough for a check.
Of course, putting a humbucker on a Strat is heresy, IMO.... ;^)
Gordon in Austin
Old 12-01-2006
timthetortoise timthetortoise is offline
MADE OF SANDALWOOD
timthetortoise has a reputation beyond reputetimthetortoise has a reputation beyond reputetimthetortoise has a reputation beyond reputetimthetortoise has a reputation beyond reputetimthetortoise has a reputation beyond reputetimthetortoise has a reputation beyond reputetimthetortoise has a reputation beyond reputetimthetortoise has a reputation beyond reputetimthetortoise has a reputation beyond reputetimthetortoise has a reputation beyond reputetimthetortoise has a reputation beyond repute
I would highly recommend soldering the red and white together. I'm assuming you stripped them back? If you do not short these or do not have them in a proper configuration, the pickup will not work. It's only a couple more seconds of effort to solder and tape this connection, and it pays off to follow the directions as exact as possible. According to the directions, that section of the 5-way switch is NOT just an empty lug. If it were, it would have told you explicitly to just solder and tape. It looks like the problem here is you have nothing on that section, not even a ground, which would behave like you're describing. I don't know the mapping of your 5-way, of course, but if the diagram is showing that connection soldered, I'd recommend you at least try it before assuming it's not the cause.
http://www.myspace.com/sundrone
Old 12-01-2006
Anfontan's Avatar
Anfontan Anfontan is offline
Banned by eurt
Anfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond repute
I agree, it looks like the humbucker needs that connection, the 2 wires soldered together, otherwise its only one single coil in operation. Thus the hum from also having no ground. This diagram is for a single tone control, but it might help you in your wiring.
Strat w/ 5way
Old 12-01-2006
hawk's Avatar
Senior Member
Strat w/ 5way
Anfontan, that's how I had it wired in the first place. But, I just now soldered the red and white to ground and half of the problem is now fixed. There is no more hum in the middle/bridge position. However, I'm still getting lots of hum from the humbucker. It's now wired as:
red/white - ground
green/bare - ground
black - switch.
Any other ideas?
Old 12-01-2006
ocnor's Avatar
ocnor ocnor is offline
Lord Of The Thighs
ocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond repute
You could wire it like this and it will not hum.
Old 12-01-2006
Light's Avatar
As I said, a bad solder joint. Or, in this case, NO solder joint. You gotta solder them.
By the way, in the schematic you posted, the red and white wires get conected to the ground wire in the bridge/middle possition, which taps the humbucker. This should give you two single coils in that possition, and if the middle pickup is reverse wound/reverse polarity, it will still be humcanceling in that possition.
Light
M.K. Gandhi
1982 Ovation Pickup Noise Cure? soundchaser59 Guitars and Basses 2 03-13-2006 23:46
Adjusting pickup height (Tutorial) enferno Guitars and Basses 0 02-06-2005 23:48
Guitar for installing Roland GR-20 Pickup riccol Guitars and Basses 3 01-21-2005 18:56
Installing a pickup in a Martin D-15 invisiblenemies Guitars and Basses 8 01-19-2005 06:23
Installing a pickup tom18222 Guitars and Basses 12 02-11-2004 21:25
