volume attenuator? -10dbV consumer level signal to a +4dbu input ASP8's
Hey all, I brought home a sweet pair of Event ASP8's.
I'm still running my trusty fresh-out-of-the-shop 388, and mixing to a Harman-Kardon CDR-20, consumer grade burner (24/96). The problem is, the CDR-20 is -10dbV consumer level outputs. I have it fed directly to the ASP8's. I have the monitor input trim all the way down, and they still crank out over 80db. (no sh*t, huh..) So, is there any simple, effective, and affordable device which will lower the signal before it hits the Monitors???? (and keep the sound true)? I know the 388 has balanced outs, which would be soooo simple to run to the monitors, but... I like to add a touch (or more) of compression before hitting the converters in the burner, and I wouldn't get to here that through the Montiors. Also the fact that to get to know the monitors, I need to spend some time listening to major release stuff... Lost, Goldenvoice ![]()
Newbie here - but not there... |
something isn't right. -10 should be lower than +4 to begin with. running directly from the +4 outputs should make it even Louder!
Yes, that was my thinking. So?
-10 is truly hotter than +4 ? ![]()
Could my problem also be related to the fact I'm plugging a 1/4" TS un-balanced into a 1/4" TRS balanced input, even though Event says that should be fine?
to the first question: no. -10 is .316 V and +4 is 1.23 V
to the 2nd question: maybe but in my guess probably not the problem. I run balanced +4 and unbalanced -10 signals to the same powered monitors with no problems. I think either you are too close to the monitors or what you think is the lowest volume setting is actually the highest. my monitors if you take them to full attentuation are off. |
A variable pad could just be a stereo 10 Kohm potentiometer, again in a box with input and output jacks, though a cheap one may not be as accurate between channels as you might like. With a pot, connect the line output across the two ends of the pot and take the monitor input signal off the wiper. I happen to use a Shallco stepped attenuator with 1 dB steps and calibrate 0 dB (all the way on) to the RP200 monitor standard (a -20 dBFS pink noise file produces 83 dB SPL at the mix location with one channel driven. The Shallco pot will run you about $140. Cheers, Otto |
I was looking at the owner's manual for the 388 and on page 24, there's a picture of the rear jack panel; and there is -10db set of Monitor out jacks to feed your powered speakers and there is also a -10db set of stereo outs to feed the HK CD recorder directly without the need to connect it through the speaker's feed.
Use the independent feeds that the 388 provides you with. Cheers! ![]() |
Cheers! ![]() |
Here's what your manual says about input sensitivity:
"Input Sensitivity This control is used to compensate for different signal levels that appear at the input. The control has a 20dB range; when set at maximum (MAX), 1.1V RMS input at the balanced ins will produce full amplifier output. Note that when the signal appearing at the input is too hot, the amplifiers may overload, causing distortion. If this occurs, attenuate (decrease) the Input Sensitivity by turning the control counter-clockwise." So, once you've established that full CCR doesn't attenuate enough, you will need to attenuate the signal in some way. Let me know if that is still the case. I can't imagine another 20 dB wouldn't do the job, so a fixed 20dB pad should get the job done, or you could use a stereo pot. I'm not sure what the specs are on the linked Shallco pot. They do custom pots where you tell them what steps you want and Paul the engineer calculates all the components and they make it. The stepped attenuator is only needed if you are going to use a calibrated monitoring system which I highly recommend. Cheers, Otto |
Oh, thanks so much for all of your help!
Yes, the 388 even has the balanced outputs, which I could hook directly to the monitors, but not being able to hear the compression or any digital clipping would not be a comfortable situation. The HK's Analog Audio Output is rated at 2V RMS, +- 2 dB. The stepped pot sounds like a very workable senario. My mind has also been toying with the following, and your input is greatly valued. Picking up a used P4 or so, decent sound card, and software, from which I could master. Have also been considering going ahead an getting something like a firepod 8 channel, so I could dump all 8 388 tracks, then add synth, etc. Then mix, bla bla bla. I have a fear here, though, about loosing some of the goodness the 388 contains, but probably not a big worry so long as I stay away from the cheapest converters...? Thoughts? I do have a jingle project nearing studio time, and for that will possably have to punt! I do have a Mackie 1604 sitting in the top rack... could I run the HK outputs into that, and use it to attenuate the signal???? G ![]()
#12
yes. .
#13
I happen to be using a stereo graphic eq unit for a purpose kinda like this: just running a signal through it to adjust the gain, but with the eq part switched out. If you have a stereo unit such as that, with a level adjust, it should also do the trick in setting the gain into your monitor inputs as long as you have enough range of adjustment. Cheers, Otto |
#14
Mackie CR 1604. I've had it since the early 90's maybe?
What do you mean by w.r.t.? I have the 1604 handy for more elaborate effects routing if needed, but seldom use it as such. It may also be put back into service for live work, as my current mixer has just failed me. In your thinking on using the 1604, I'm a little lost as to which ins/outs you are recomending. Aux out (ie:basic effects routing) - but in where? Would this leave the 'main' workings of the board for effects durring mix-down? (I don't "mix" on the mackie, but have run the 388 buss to/through it)... I do have an old Soundtech stereo graphic, which could be used as you described. (I have 8 channels full parametric if needed) Would probably be my easiest fix. Why didn't I think of that? Thanks so much Otto! Goldenvoice ![]()
#15
Sorry, "w.r.t." is shorthand for "with respect to". An old habit from physics homework. The graphic is worth a try, especially if you can bypass the actual EQ part of the thing. And, you're most welcome. Cheers, Otto |
| Running an amp at Max?? | Disco_Dave | Other Equipment and Reviews | 12 | 09-15-2007 09:18 |
| ULTRA low input volume levels driving me insane! Please HELP! | Xpred | Digital Recording & Computers | 56 | 01-23-2006 03:20 |
| Let's talk about normalization. | Eurythmic | Digital Recording & Computers | 18 | 04-07-2000 14:50 |
| ART Tube MP Input Level | Raj | Microphones | 12 | 02-28-2000 09:16 |
| Auto Gain on AWE64 Value at low input level | Eben van der Merwe | Digital Recording & Computers | 1 | 09-10-1999 00:27 |
