Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 11-30-2006
VGreen VGreen is offline
Newbie
VGreen has a reputation beyond reputeVGreen has a reputation beyond reputeVGreen has a reputation beyond reputeVGreen has a reputation beyond reputeVGreen has a reputation beyond reputeVGreen has a reputation beyond reputeVGreen has a reputation beyond reputeVGreen has a reputation beyond reputeVGreen has a reputation beyond reputeVGreen has a reputation beyond reputeVGreen has a reputation beyond repute
Help with midi setup
Hi,
I've recently bought a yamahe dgx-505 and need help with getting the midi setup. I've installed the driver, have connected the instrument to my computer via a usb cable, and am using protools 6.4 to record.
1. In the protools mix window there's an input and output panel. I've selected "ALL" as my input, and "yamaha usb-out channel 1" as my output. To be quite honest, I'm not sure what I'm doing. When I record, nothing comes up. However, at one point I was able to get all the notes coming up but no sound when I played it back.
2. On this yamaha, there's three options for the computer - pc mode, pc1 and pc2. Which one should I use?
I'd appreciate any feedback. Thanks.
V
Old 11-30-2006
peopleperson's Avatar
peopleperson peopleperson is offline
I'm so sorry.
peopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond repute
Make sure you're creating a midi file for the input, not an audio file.
Here a douche, there a douche, everywhere a douche douche.
Old 11-30-2006
carelessorc carelessorc is offline
Dedicated Member
carelessorc has a reputation beyond reputecarelessorc has a reputation beyond reputecarelessorc has a reputation beyond reputecarelessorc has a reputation beyond reputecarelessorc has a reputation beyond reputecarelessorc has a reputation beyond reputecarelessorc has a reputation beyond reputecarelessorc has a reputation beyond reputecarelessorc has a reputation beyond reputecarelessorc has a reputation beyond reputecarelessorc has a reputation beyond repute
On most Yam products correct setting is PC 2 (although the choice is usually 'Mac, PC1, PC2).
Orc
Old 11-30-2006
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
If you're using the Universal Serial Bus (USB) connection, those 'PC1' and 'PC2' designations don't matter.
First, go into your keyboard and look in the utility or global page for a 'Local on/off' parameter. Set this to off. This will break the connection between the keyboard and the sounds inside, giving you the virtual equivalent of a midi controller and an XG module.
Then start with a blank midi track, and in protools 'midi preferences' or 'options' or whatever they call it select the Yamaha keyboard as both your input and your output.
Then play the keyboard. If you hear it but there's a delay try installing ASIO4all according to the directions, assuming your computer is a PC.
...now in HD.
Old 12-01-2006
Newbie
Thanks for everyone's help.
I've managed to sort out some of the problems. I tried using the PC "off" function which automatically sets the parameters to local on, external clock off, keyboard out on, style out off, song out NA, and this works. However, I'm now having problems with recording a style, i.e. a drum rythmn. This has to be done through PC2 as this allows for the style on parameter. I eventually realized I had to record it through channel 10 (the keyboard can be recorded through channels 1-9), but when I play it back it sounds really weird; in other words it doesn't play back through the Yamaha as it did when I recorded the keyboard track.
Any suggestions?
V
Old 12-01-2006
Info you can use...
Originally Posted by VGreen
Any suggestions?
You are trying to use the consumer oriented, auto accompaniment features of your Yamaha keyboard with semi-pro protools software.
That's not going to work.
You need to either:
  1. Record the auto accompaniment into a stereo recorder.
  2. Ditch the dependence on the auto accompaniment and strike out on your own using the voices in your Yamaha to create you own original compositions.
Find a very useful freeware stereo editor/multi track recorder here.
...now in HD.
Potential 3 way MIDI setup doing my nut. Smoulders MIDI Mania 9 04-13-2006 07:19
Setup up MIDI (software and hardware)? Buddy Lee Newbies 6 05-25-2005 08:12
Need serious midi help whats the best way to do this? puppethead MIDI Mania 3 10-09-2003 15:59
Midi drum stuff for the hard of thinking: Alan McGuinness Cakewalk / Sonar Forum 3 12-12-2002 12:03
Midi and PSR 330 Gumbylives Recording Techniques 0 07-04-2001 18:24
