Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 11-29-2006
lttoler lttoler is offline
Senior Member
lttoler has a reputation beyond reputelttoler has a reputation beyond reputelttoler has a reputation beyond reputelttoler has a reputation beyond reputelttoler has a reputation beyond reputelttoler has a reputation beyond reputelttoler has a reputation beyond reputelttoler has a reputation beyond reputelttoler has a reputation beyond reputelttoler has a reputation beyond reputelttoler has a reputation beyond repute
EZDrummer problem!!
I recently bought the Toontrack EZdrummer software under the impression that it is a standalone program that I can use to create drum tracks. After installing it and not being able to get it to work, I find out that I need something else like ProTools or Acid Pro to be able to use this thing as a plug-in. I really don't have the extra money to invest in all this right now and I can't return my software. Can anyone give me any suggestions on what to do??? Thanks!
Old 11-29-2006
warble2's Avatar
warble2 warble2 is offline
Not an expert
warble2 has a reputation beyond reputewarble2 has a reputation beyond reputewarble2 has a reputation beyond reputewarble2 has a reputation beyond reputewarble2 has a reputation beyond reputewarble2 has a reputation beyond reputewarble2 has a reputation beyond reputewarble2 has a reputation beyond reputewarble2 has a reputation beyond reputewarble2 has a reputation beyond reputewarble2 has a reputation beyond repute
On the product page for EZ Drummer, it states a plug-in host is required:
http://www.ezdrummer.com/prodinfo_ezd.asp
It also lists supported applications.
Purchase a supported application to use it with is the option you have.
Old 11-29-2006
danny.guitar
Guest
Posts: n/a
You can use Reaper. Unexpiring shareware and has almost all the features most recording software have.
But I think a better option for you would be:
Cantabile (Free)
or
MiniHost (Free but with nag screen until you donate)
Using reaper or Cantible, you can load MIDI files and run them through EZDrummer to create your drum tracks. Cantible and MiniHost both support MIDI keyboards, so if you have one of those, you can also create them that way.
They have built in WAV recorders.
But I personally use Reaper and EZDrummer because I usually use MIDI files and not a keyboard.
Old 11-29-2006
Senior Member
I have midis of my drums already mapped out. How would I go about using EZdrummer through Reaper?
Old 11-29-2006
danny.guitar
Guest
Posts: n/a
Open Reaper
Click the Insert -> Media File... menu
Select your MIDI file
This should add a new track to the project with the MIDI file on it
Set the project's tempo by typing it in where you see "120.00"
Now, there is a small bug in EZDrummer/Reaper, so in order for it to load the drumkit you have to do this:
Arm the track for recording by clicking the red button on the track
Now, in the track list at the bottom of the screen, to the right of the "Master" track, select your MIDI track, and find the "Record Monitoring" button. Click this so gets turned on.
Now you can assign EZDrummer to the track as an FX.
Click the FX button on the track, and select "VSTi" in the left menu, find the "Dfh Sampler (Toontrack)". This is EZDrummer.
Click OK, and then it should load EZDrummer and the drumkit. Once the drumkit is loaded you can play/render the track as a WAV file.
Hope that made sense...
Old 11-29-2006
warble2's Avatar
Not an expert
Originally Posted by danny.guitar
Open Reaper
While this may be a free solution, will it be stable? Just curious.
Old 11-30-2006
danny.guitar
Guest
Posts: n/a
Works for me.
Old 11-30-2006
Senior Member
This seems to be exactly what I needed. Thanks a lot!
rack with legs so i can tilt back walters The Rack 43 08-17-2007 20:35
Sonar 4-5 "Random" problem (tough one) Thrawn Cakewalk / Sonar Forum 2 08-20-2006 14:18
Yamaha FS1-R Problem rjt Keyboards and Sound Modules 2 01-26-2004 17:46
LD Condenser Mic Problem micr0s Microphones 5 01-09-2004 00:24
Unwanted distortion in amp; possible preamp tube problem? Whoopysnorp Guitars and Basses 11 09-16-2003 13:06
