Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 11-29-2006
Zetajazz44's Avatar
Zetajazz44 Zetajazz44 is offline
HiTek ReDnEcK
Zetajazz44 has a reputation beyond reputeZetajazz44 has a reputation beyond reputeZetajazz44 has a reputation beyond reputeZetajazz44 has a reputation beyond reputeZetajazz44 has a reputation beyond reputeZetajazz44 has a reputation beyond reputeZetajazz44 has a reputation beyond reputeZetajazz44 has a reputation beyond reputeZetajazz44 has a reputation beyond reputeZetajazz44 has a reputation beyond reputeZetajazz44 has a reputation beyond repute
Non-Linear vs. Linear Reverb
Can someone explain the differences between Non-Linear and Linear Reverb and how/why each would be used in particular applications?
I've searched this forum, as well as a few others, Googled it...etc., but I've found nothing. I'm just looking for some understanding in this area.
Thanks in advance,
Zetajazz44
"If the "Music Business" was a yard stick, 3 inches of it would be the music... The other 33 inches would be the business..."
Old 12-01-2006
Freudian Slip's Avatar
Freudian Slip Freudian Slip is offline
Source Of Confusion
Freudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond repute
I'll try to help some. Linear vs non-linear in the case of reverb refers to the decay of the reverb or the fading out of the reverb. linear decay would fade out in a very even manner lets just say for example maybe 3db per second untill it is gone.
non-linear could describe a couple things. A gated reverb is non-linear and would fade out to a point and then just vanish. So if you can hear the reverb clearly and then it's just gone it would be non-linear. Alot of people use gated reveb on snare drums. You may want a pretty strong reverb on the snare but not want there to end up being 10 snare hits triggering reverb and all those instances stacking up on each other and getting ugly.
Non-linear decay could also mean that you have strong late reflections (echos) in the fade out causing it to not fade evenly but to have pulses or surges in the fade out.
So linear = a straight line going diagonaly down to zero
Non linear = the line goes diagonaly down for a ways and then stops or it's not a straight line and has wiggles in it.
Hope that helps a little.
If anyone can describe it better please do
F.S.
"If Congress can do whatever in their discretion can be done by money, and will promote the General Welfare, the Government is no longer a limited one, possessing enumerated powers, but an indefinite one"
James Madison: the father of the Constitution
Old 12-02-2006
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
Originally Posted by Freudian Slip
If anyone can describe it better please do F.S.
Nope.
(this space intentionally >10 characters)
Comfort Reverb when direct Monitoring Surf's Up The Rack 6 12-16-2005 14:41
Using Reverb mr. torture Recording Techniques 11 08-12-2004 10:02
How do I use my 01v reverb on dry tracks in cubase? boze MP3 Mixing Clinic 4 03-29-2003 19:01
Reverb Plug-in Vs. Hardware dudleys100 The Rack 21 03-25-2003 16:20
Reverb Plugins - Multi-Track? barefoot Mixing / Mastering 3 08-21-2001 11:17
