Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 11-29-2006
BRIEFCASEMANX's Avatar
BRIEFCASEMANX BRIEFCASEMANX is offline
Winner chicken dinner!
BRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond repute
getting a classic 30, want new speaker.
i'm buying a peavey classic 30 and I want to buy a new speaker for it. I'm thinking of getting an eminence gb12. I don't know SHIT about guitar, so I need some help. It comes in 8ohm and 16ohm versions, am I correct in thinking I should get the 8ohm, because it's going to be louder? Or is my understanding of ohms off base?
Also, what other speakers would you recommend? I was also thinking about a celestion g12h but those are hella expensive compared to the eminence, homey.
help plz.
Be true, gentle warrior. Stay with me through the night, my fine stallion, you incredible and powerful beast.
Wild Hogan Recording
Old 11-29-2006
AGCurry AGCurry is offline
Force of Nature
AGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond repute
I can't tell you which speaker to buy, as I don't know the sound you have in your head.
But... I have a Delta Blues, which I believe is pretty much the same amp. It wants a 16 ohm speaker. Yes, it will work with an 8 ohm speaker, but it won't be significantly louder, and you run the risk of damaging the output transformer.
For grins, I tried an old JBL D130F in the Delta Blues. It didn't sound as good as the stock speaker. So maybe Peavey knows what they're doing...
Old 11-29-2006
soundchaser59's Avatar
soundchaser59 soundchaser59 is offline
Reluctant Commander
soundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond repute
Why do you want a different speaker? What is wrong with the Blue Marvel that came in it when you bought it? I'm not sure, but that Blue Marvel may actually be a Sheffield. Peavey used Sheffields for a long time. Not bad, not great, so so, just increases their profit margin cuz they can get them cheap in volume.
What kind of music? What kind of sound? Probably not metal or you wouldn't have bought a C30. Do you like it to cut thru and be extra loud? Or do you want it a bit smoother and more controlled? Do you like more low freq or midrange in the sound? Or do you like a more cutting or piercing hi freq sound?
The thing I've heard most about Peavey amps is it is very hard to find a speaker that matches the amps sound well. I have gone thru a dozen different Eminence speakers in the last year or so, and I can tell you in no uncertain terms that the loudest and most cutting brute force Eminence speaker is by far the Tonker. Second might be the Swamp Thang. If you want crisp and dirty try the Legends 125 or V12. If you want clear and smooth and not as cutting, the smoothest Eminence imo is the Cannabis Rex. The C.Rex is like no other Eminence speaker, and I absolutely love the ones I have.
With the brighter and edgier sound of the C30, I would shy away from any Celestions. But if you must try them, try the Vintage 30 or the G12T-Hot100, both can be found on eBay for well under $100 bucks. But Celestions are extra bright and on the thin side, me thinks.
I have never been let down by Weber Speakers. The best and most versatile Weber is the Michigan, followed by the California, the Chicago, and the Blue Dog.
If you have money to burn, look at Tone Tubby first, then EV and JBL.
One thing you might do is take your amp to the guitar stores and pretend you want to buy a cab. They will most likely let you plug your amp into their cabs. If they are worth a nickel, they will be able to tell you what kind of speakers are in the cab. For example, if you want to hear Vintage 30's, try an Orange cab. Or plug the speaker cable from a Fender amp into your C30 and play thru the Fender's Eminence speakers, a lot of the current Fender amps are coming with Emi's in them. Try several different cabs, when you find one you love the sound of, find out what's in it and go buy that speaker. Just understand that the sound of one lonely speaker in your amp will never sound as good as the sound of two or four speakers in a cab, even if you buy the same speaker as what's in the cab.
Most important, if your amp says it expects an 8 ohm speaker, then make darn sure your speaker (or your speaker cab) is 8 ohms. Match them.
Just think how good you could play if you were sober!
My Little Corner Of The World
SC's MySpace
Old 11-29-2006
Thurgood Thurgood is offline
Force of Nature
Thurgood has a reputation beyond reputeThurgood has a reputation beyond reputeThurgood has a reputation beyond reputeThurgood has a reputation beyond reputeThurgood has a reputation beyond reputeThurgood has a reputation beyond reputeThurgood has a reputation beyond reputeThurgood has a reputation beyond reputeThurgood has a reputation beyond reputeThurgood has a reputation beyond reputeThurgood has a reputation beyond repute
I have a classic 30. I like the amp, it has a nice clean and smooth distortion in the regular mode. Not so keen on the boost mode but I do use it. As to your speaker question I believe the speaker is 16 ohms. You should buy (speaker of your choice) at 16 ohms. Listen to the amp first, then after some time (mos/weeks) make your decsion then. I agree with soundchaser59, listen to the amp first. True, the amp is a bit dark but they sound good. I loaned mine to a friend, who is a fantastic gtr player and barely got back from him, he loved it. Note: he had my Mesa for a month prior to that loan. Also I believe the vintage 30 to be a bit "crisp".
Go to the "blue guitar" website as it has a million mods and sugesstions for the classic 30. Sorry I do not have the link, just google. Also, research EL 84 tubes that are not prone to microphonics as the Classic 30 can really rattle the tubes. Good luck hope this helps.
Old 11-29-2006
Big Kenny Big Kenny is online now
Been Here, Posted That
Big Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond repute
The delta series rox, the classic 30 already has great speakers in it, leave 'em. If you want a different sound get a different amp.
In His Name
Big Kenny
Amp Power vs Speaker Clive Hugh Guitars and Basses 18 02-21-2006 05:43
Hey Everyone: PA System??? IronsideMessiah Other Equipment and Reviews 32 02-19-2006 10:28
Long speaker cable runs Adam P Other Equipment and Reviews 4 11-16-2005 14:52
Higher wattage speaker character and balancing my rig Alanfc Guitars and Basses 0 04-23-2004 17:37
Computer Speaker Subwoofers... ghetto3jon Digital Recording & Computers 6 04-13-2004 23:05
