Hi everyone. I'm having some problems with my Tascam 38, the reel on the right doesn't turn when I start it. Same problem when I try to run it without the tape by holding the tension rollers up. Most importantly, the tension roller on the left is a lot more loose than the on the side that is dead.
What could it be? Is the belt off or broken? I'm sorry if it's a stupid question. I'm not a pro. But I'm hoping it's not the motor. It used to work perfectly, before being stored for several years. |
The 38's have been semi-notorious for failing reel motors.
I own a 38 and had the same problem. I had the motor changed and the problem was solved. There are no belts for the reel motors. Only the capstan drive runs with a belt. The other possibility is to have the motor disassembled and cleaned but the added labour charges of doing this usually doesn't pay off as you'll spend the same amount of money or more because of the added bench time. If TASCAM doesn't have the motor in stock, then the reconditioning/cleaning of the motor's bearings and brushes is your only course of action. Cheers! ![]() |
Thanks!
Would I need something like this? http://cgi.ebay.com/TEAC-TASCAM-38-R...QQcmdZViewItem Is it hard to change the motor? |
Changing it yourself and the difficulty of doing that largely depends on your DIY skills. Having the full manual which offers all the exploded diagrams and parts numbers would be invaluable! The price in the auction is also a good one as I paid $110 + tax for mine, though mine was a new one from TASCAM/TEAC Canada direct. Buying used motors may come with their own perils. Cheers! ![]() |
Thanks again! I'll try my best to fix it!
It would also be prudent to check the fuses first as it may be something as simple as a blown fuse on the motor circuit.
Keep in mind though that fuses blow for a reason and the reason may well be that the motor's grease has hardened and turned to sludge which would jam up, draw too much current from the power supply and blow the fuse. Cheers! ![]() |
I'll take a look at that as well.
I'm still uncertain as to why one of the tension rollers is more loose than the other. |
On mine, the left one will easily fall back down and on the right side it will more gradually fall back down. Considering that when the right one falls all the way down, the tape transport will stop so it may have been designed that way to prevent accidental stops due to pre-mature intended out of tape auto shut offs. Bottom line; I don't see this as an issue. Cheers! ![]() |
OK. Yeah, I think it's designed the same way on my Fostex 80.
Well, anyway...
I'll wish you the best of luck with the repair and so long as the rest of the deck is operating as it should, you should get lots of enjoyment from your 38. It's capable of making a VERY respectable recording. Cheers! ![]() |
Btw, Jeff, I'm glad you returned to your original avatar. It's the "Ghost" I know. Don't change it!
#12
Thanks for your help!
I love this forum ![]() |
#13
#14
~that the brakes are releasing the hubs (reel tables) properly on both sides;
~that the reel tables are securely attached to the motor shafts with the set screws. I think the failure of the brake solenoid (due to rubber deterioration) and the hub coming loose from the motor shaft are way more common problems than the motors failing. I'd check e'thing (simple) like this before snooping 'round the motors. That's my 2¢ ![]()
a.k.a. Davemania! Beatles and other Classic Rock covers!! Yeah, Yeah, Yeah!!! 637 songs by 191 bands.
#15
Would there be an added resistance to the take up reel table and hub assembly not wanting to turn counter clockwise if that were the case? Cheers! ![]() |
#16
Thanks! I'll check that on the weekend. It's surprising that unit has any problems at all, 'cause there's less than 30 hours on it, it's near mint! I suppose it's the long storage that's killing it. |
#17
It's not really any issue directly tied to your model of recorder but all mechanisms in general...the old adage; "use it or lose it", has some truth to it. Cheers! ![]() |
#18
Problem solved! (it was the Edit mode that was "stuck" and was giving some problems, didn't take much time to fix that). And yet another problem - channel 2 isn't recording. When there's a small "pop" at the moment the unit starts, the meter on channel 2 reflects that, when recording it's dead. What else can it be besides the line input?
#19
I forgot completely about that button. If it's engaged, the take up reel is disengaged to allow for dump edits. Sorry for leading you down a fearful path of expensive repair options. As for the track 2 problem, double check your hookups and the fitness of the cable that feeds it signal. If that checks out, the interior channel card might need to be reseated...basicly pulled out and put back in to clean any possible oxidized contacts that connect the board to it's motherboard. Cheers! ![]() |
#20
I'll try that
Thanks again! |
#21
(I'd probably sit for hours troubleshooting all the electronics )It worked like a charm. I've also took a sharp eraser and cleaned those contacts a little. Thank you! ![]() |
#22
Glad I could finally help you. Cheers! ![]() |
#23
It stopped working again! The same channel. So I swapped two channel boards. That didn't do it. I'm thinking it might be the output path somewhere. I'll be troubleshooting it tonight.
#24
Ok, no cold joints found.
So I've tested it again: In recording mode: meter reads it for channel 2, on Repro: it's dead. And during one of the previous tests it was working! So is that some of the electronics that are going out? Semi-conductors? Am I on the right track? I've tried switching cables and even swapping channel boards inside. By the way, can I do that? Or is there any special bias setting on every channel boards that's a bit different from the other? Thanks |
| Tascam 122 mkIII clip problem | _DK | Analog Only | 5 | 2 Weeks Ago 03:40 |
| tascam US 122 Recording Problem | thegermnyc | Analog Only | 1 | 05-23-2005 18:18 |
| Tascam 246 problem | analogbrad | TASCAM User Forum | 3 | 11-30-2004 02:26 |
| Tascam US 224 input problem | vwerner1 | Digital Recording & Computers | 0 | 11-16-2003 01:29 |
| Tascam Digital Mixer problem... | lost studios | TASCAM User Forum | 3 | 01-22-2003 11:21 |
