2 questions about levels
What's an ideal (peak) level to be mixing at? Or is there one? I usually try to keep it at about -6db.
And what's the ideal average level the mixdown should be at before sending it off to a ME? I usually try to keep it at around -12db. Is this enough "headroom" for the mastering process? Too much? What do the mastering engineers here prefer? |
-6dBFS is fine... It's a nice place to be.
Average levels on a mix like that would be around -24 to -22dBRMS... Also fine and a nice place to be. I'm *assuming* that when you say "average levels" you mean the average *peak* level... Otherwise, -12dBRMS with peaks at -6dBFS would be a nightmare sounding thing... |
My mixes usually turn out at around -20 (to 25) dB RMS with peaks at 0dB.
Is this ok? I place a limiter on the output but it only catches the odd kick or snare hit. Eck |
I don't have any RMS meters in Reaper, so I don't know what the RMS level is... I think there's some plugins for that though...So, a mixdown with peaks no greater than 12db is enough headroom? Eh, I'm confused. I've read about RMS along time ago but I'm still not completely sure what it means and I get confused between RMS and DBFS ![]() |
RMS just means average. For example if you had a signal that had an average strength of -18dbfs, you could say the signal was -18dbfs RMS. If you had a signal that peaked at -18dbfs, you would say the signal was -18dbfs peak.
Ah that makes sense.
Thanks Farview. ![]() |
Not too much to add to the above other than I wouldn't get very nervous if some peaks even went as far as -1 dBFS in the mix. The more important issue is the crest factor (difference between the peak and the RMS ). I'll take a mix with a good dynamic range that peaks high over the reverse any day.
For an average rock song, I would say that a crest factor of 20 db or more should be fine to work with.
Tom Volpicelli The Mastering House Inc. www.masteringhouse.com MySpace: www.myspace.com/masteringhouse |
![]() Eck |
There are also considerations in analog versus digital mixes. If taken too far in the analog world the signal to noise ratio of the devices you are using becomes a bigger factor. In general I would say that it's best to operate gear at their "nominal" level. Not too hot, not too cold. (unless you actually want distortion or noise for creative reasons)
@ Eck - On the snare thing... If you're limiting the *buss* to catch an occasional snare transient, try limiting *the snare* instead - Then the whole mix isn't subjected to the gain reduction - if even for an instant.
Eck |
| phase and meter levels | willow | Cakewalk / Sonar Forum | 2 | 05-21-2006 19:44 |
| Computer & Mixing Questions (Newbie questions I suppose) | Scinx | Digital Recording & Computers | 0 | 04-12-2003 09:47 |
| Sound Levels | L'espion Noir | Cakewalk / Sonar Forum | 7 | 07-20-2002 05:23 |
| recording levels | david j. cook | Recording Techniques | 0 | 10-10-2001 14:24 |
| Please try the search before asking questions | ola | Other Equipment and Reviews | 5 | 10-24-2000 02:09 |
