Publishing online - File conversion
Hey, for saving as an mp3 / m4a-acc / lame mp3, what program should I use to get the best results, no worries about time or anything of course.
I am worried about file size, and will be writing at 128kbps. Just would like some recommendations on what file type to use and what program. I've always done mp3's until now, on CDex. But abnormalities in the program have me thinking there must be better ones available. |
It's not the program you use, it's the encoder that the program uses. Using the LAME encoder with CDeX, is the same as using LAME with any other program. I would suggest CDeX using the LAME encoder, at 128KBPS. Although, if you can, I would suggest at least 192KBPS. I notice a huge quality difference between 128 and 192. |
I think the Fraunhofer codec sounds much better at 128kbs.
by the way, Sorry if I posted this in the wrong section, I didn't really know where to put it!
A second question: I'm saving as an mp3 from a .wav, but would this give a lower quality result than if I saved directly to an mp3 (I'm using SONAR). Recording in 16 bit 44.1, and that's the same as the .wav, but I'm thinking with the multiple tracks and the different gains/volumes and whathaveyou, there may be a slight loss of quality? Any insight would be appreciated! Thanks, Ian |
And yes, I had thought of that, and maybe I was using a crap encoder with it. I just downloaded CDex a long time ago, and have never known if it is meant to be reliable. Are the LAME and the Fraunhofer both free? |
And I should be able to use the encoder directly from SONAR right?
| simple stuff? LP>>>>CD (help the aged) | simpleone | Newbies | 10 | 01-10-2001 07:49 |
| MIDI file conversion to wav | robn | Cakewalk / Sonar Forum | 1 | 06-19-2000 11:11 |
| MT200 file conversion | tonzer | Roland, Boss, VS Series Forum | 0 | 05-14-2000 05:23 |
| Roland MT200 file conversion | tonzer | MIDI Mania | 0 | 05-14-2000 05:20 |
