Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 11-24-2006
djclueveli djclueveli is offline
Dedicated Member
djclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond repute
hard punchy hip hop kicks
what is it that hip hop mixers use to get the kicks to sound real hard n punchy? i tried to do it with a compressor and tried to increase the low end frequency but all it does is make it muddy without adding and BIG punch to it. feedback will be appreciated. thanks
Old 11-24-2006
danny.guitar
Guest
Posts: n/a
I would think EQ and compression can only get you so far. They probably started with samples that were 'hard' and 'punchy' to begin with.
I would look at getting some better samples.
Then again I don't have any experience with hip hop stuff...
Maybe you post a clip of the sample you're using?
Old 11-24-2006
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is offline
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
Start with either a real Roland TR-808 or a high quality first generation sample from the 808. Shop around on the samples, there are some that are not so hot as compared to the "real" 808 sound.
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
Old 11-25-2006
Dedicated Member
yea thats true. also how do i post a clip up here of the sample so you guys can hear it? thanks
Old 11-25-2006
Bulls Hit Bulls Hit is offline
Been Here, Posted That
Bulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond repute
For increased phatness, try blending a couple of samples together
Old 11-25-2006
bigwillz24's Avatar
bigwillz24 bigwillz24 is offline
One Turd at a Time...
bigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond repute
punchy boom huh?
heres the recipe...
1 accoustic kick sample as punchy as you can find.
1 808 kick sample as boomy as you can find.
1 sprinkle of hat sample for attack.
mix those ingredients together for some punchy kick goodness.
Now it's time to bump it up a notch with some eq.
BAM!
Doesn't that smell delicious?
Okay it's looking good now but we can take it a little further.
Let's add a little compression, ah screw it lets add a lot of compression and let's let that sit for about 10 minutes.
put that into one of your mixes for some oh so good punchy kick sound.
Old 11-25-2006
LeeRosario's Avatar
LeeRosario LeeRosario is offline
"The Ears"
LeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond repute
It's called analog tape at 15ips.
"ghost" producer/Engineer
The Demure on ITunes
Old 11-25-2006
bigwillz24's Avatar
Originally Posted by LeeRosario
It's called analog tape at 30ips
That's what that Magneto plugin in Cubase is for.
Old 11-25-2006
LeeRosario's Avatar
"The Ears"
hmm...know about it, but never used it. How does it match up?
Old 11-25-2006
bigwillz24's Avatar
Well I don't have a real tape machine lying around so I really can't compare but I have to say I use that plug on everything.
I track with it on the input channel in Cubase.
I think it sounds great.
Old 11-25-2006
LeeRosario's Avatar
"The Ears"
I had read up on it a few times before and I know that it always came in the whole Nuendo bundle, for the times I did work in nuendo. However, couldn't see why I never got into trying it out.
Has me curious now, just to see how it works out.
  #12
Old 11-26-2006
X man Da Legend's Avatar
X man Da Legend X man Da Legend is offline
Vinyl Hugger
X man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond repute
To make ur kicks knock they already have to be hard hitting to begin with. The best way to get these drums are sampling them from vinyl records and drum breaks in other songs. I like to run my drums through a maximizer and eq inside of reason and it works really well. Actually on some songs it works too well lol. Also velocity plays a big part in making your drums bang as well. Try layering your kicks with an 808 kick or even sample them from 80s records thats where I get a good amount of my drums from.
Myspace
Sonar Home Studio 7, Reason 4, Recycle 2, Behringer BCF2000, Ensoniq EPS, Roland Alpha Juno 2, KRK Rokit 5 Monitors, Stanton str8-60 Turntable and Stanton DJ Mixer, Roland XP-30, Korg Tr rack, Korg M3R, Stanton S.252, Lexicon Alpha
  #13
Old 11-26-2006
Vinyl Hugger
punchy boom huh?
heres the recipe...
BAM!
its also good to add to not over compress. That will kill your dynamics. I personally prefer not to add any compression to my kicks. Most of what needs to happen can be done through eq. Cut the space from other sounds in that frequency and it makes room for your kicks. It sounds louder but in reality everything else is just out of its way.
Myspace
Hip Hop MIc Pres Bloodbought DJ & Hip Hop Production 23 07-10-2009 17:48
Sample CDs and Reason Refills for Sale! AllStaar.Com DJ & Hip Hop Production 6 04-03-2006 13:16
Hip Hop Drum Loop CD's.... Gidge DJ & Hip Hop Production 10 07-02-2004 14:00
i posted this in the hip hop forum as well but im still looking for more advice needmyownstudio Mixing / Mastering 10 06-29-2004 18:39
Choosing the right mic for Hip Hop vocals kin_jai Microphones 4 02-27-2002 22:14
