how can i get that click?
I really dont want to go down the triggers route, so is there any other way to get that clicky bass drum tone? right now i just have a pillow in my bass drum, with hard felt beaters on an evans eq4 head, and its just not doing it for me. any suggestions?
get some quarters and those pads you put on skin for were your beater hits and put quarters behind those pads right were beaters hit and it will give you click my friend!
Dont be mean to me!!!!!!!!! |
sweet thanks. keep the hard felt beaters or change 'em?
You can experiment with soft or hard beaters to determine what works best for any given sound.
I prefer a half dollar or a silver dollar to a quarter - simply because it disperses the impact area on the drum head a little more. As an option to coins (and certainly for a different sound) you can also try something like a patch of leather |
I use an EV vocal mic for kick drum mic'ing and have to do some extreme EQ. I'm working with a tech-metal duo right now and did a rough mix last night and A/B'd it beside Metallica's Master of Puppets to get sort of a reference mix. Boost around 50hz and 4-5khz cut the rest out and you should be getting somewhere.
sloanstewart.com |
A quick trick for an already recorded kick is :
duplicate the track use a HPF on the dupped track, rolling of all low end until all you hear is the click insert a limiter and crush it mix to tast with original track Hope this helps, -LIMiT
Put the mic up and hit record, simple as that... |
1. Take the pillow out of the kick.
2. get evans EMAD head 3. Get a hard beater, rubber, wood, plastic. Felt will always sound soft because it is. 4. Tune the heads low. 5. Hit the kick hard. IF that doesn't work, get the Danmar pads
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F. |
yeah my old band's drummer used EMAD's and i liked 'em alot. (im really a guitar player but i tinker with drums quite alot) i used to mess around on his kit alot. the only thing i didnt like was that his pedals were so damn sticky. but then again he got 'em for free so i dont see too much of a complaint factor there.
That's exactly what you want if you're looking for clicky!
“Build a man a fire and he'll be warm for a day. Set him on fire and he'll be warm for the rest of his life." |
mic the drum with anything you have, try to eliminate bleed as well as you can, then get or download a drum replacer .vst and replace the hits with a sample of your choice. you can find those clicky samples all over the place online.
#12
i was just gonna say you can always sample the kick drum!!
vinnie paul kick is a sweet sample with lots o click ![]()
#13
yeah the only thing i have against sampling is it tends to tear the dynamics all to hell. i have a replacer vst, but it only does one velocity level, and i dont want anything OVERLY clicky, but clicky enough. there are some of those clicky samples that just bother the hell out of me.
#14
I just use a typewriter.... and drumagog.
#15
i might try that chrisharris.
| Major Issues With Firepod | Littletrigger | Digital Recording & Computers | 11 | 01-26-2006 11:20 |
| WTF! Firebox problem | necrosensual | Digital Recording & Computers | 4 | 11-25-2005 17:29 |
| Trouble on Re-install of Tascam 428 file. | choctaw | TASCAM User Forum | 3 | 06-21-2005 13:21 |
| live use of laptop (at the mixing console)... | cedric | Digital Recording & Computers | 5 | 11-25-2004 02:35 |
| Metrenome / Click Tracks | dres | Recording Techniques | 24 | 06-24-2002 03:15 |
