CPU Usage Meter in SE3
I'm using SE3 with celeron 2.8 Ghz and 512 MB of ram. When the CPU Usage metre hits half, I get some popping noises...mainly when I run amp simulator pluug ins and Midi with inserts.
This sound like a ram or processing power issue? I was kinda under the impression thatd I'd be okay so long as the metre didnt peak. Thanks. tele.
512 is the minimum you should be using so doubling that is a good idea. If you don't have 2 hard drives yet you need to get another and dedicate it to just recording. I'm guessing you have the program running off the same drive you are recording to and the pops are being caused by interrupts from your programming.
Sorry if you already know this but two hard drives and duocore are not the same. You can pick up another hard drive for around $100 and you'll notice a huge difference. Duocore is 2 processors.
Installing a second HDD is WAY EASY. You can do it!!! ![]()
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F. |
So is this like...I have my C: drive...but I should get another one? Like E: (assuming D is my disc drive) And I should, say, run Cubase from E and save files in C??
I would say, however, that your problem probably is a RAM issue. What are your hard disk transfer rates like? My guess is that because you have so llittle RAM, your system is using the virtual memory on your hard drive as RAM--as it is supposed to--thus putting an extra strain on your system. Your processing speed is fine, and one hard drive does not necessarily cause problems--though two are preferable. 1 Mb of RAM is certainly the minimum you want for your DAW--I certainly wouldn't want to run with anything less--and 2 Mb would be even better. Cheers, Joe. |
| High CPU usage with FL, DVD, etc... | D da Producer | Digital Recording & Computers | 1 | 07-12-2006 09:21 |
| Cpu Usage | vijayjacob | Cubase User Forum | 1 | 10-20-2004 06:17 |
| Question on CPU usage, SF6 vs Cubase SX | MBP2112 | Digital Recording & Computers | 0 | 05-01-2003 22:20 |
| ASIO drivers and CPU usage | dachay2tnr | Cakewalk / Sonar Forum | 3 | 02-05-2003 06:50 |
| CPU usage and adding intros with no count-offs | VertuGoGo | Cakewalk / Sonar Forum | 1 | 11-05-2002 04:44 |
