Old 11-22-2006
reno reno is offline
Newbie
reno is on a distinguished road
Kjaerhus Class Master Limiter Freezes up in GTP 3?
I have the Kjaerhus Classic Master Limiter, Classic Compressor and Classic EQ.When I use the Compressor and EQ on a track or several/all tracks to an Aux bus everything works fine. When I use the Master Limiter the whole song freezes up. You try to hit play and nothing happens. No error messages, it just doesn't play. I delete it and everything is fine again. I've deleted the DLL file and reloaded all the VST Plugins. I then downloaded the DLL again and rescanned the VST Plugins and it picks it up with no problem. Still hangs up the song when I add it to a track or aux bus. Any ideas?
Old 11-22-2006
Jamz0r's Avatar
Jamz0r Jamz0r is offline
Senior Member
Jamz0r has a reputation beyond reputeJamz0r has a reputation beyond reputeJamz0r has a reputation beyond reputeJamz0r has a reputation beyond reputeJamz0r has a reputation beyond reputeJamz0r has a reputation beyond reputeJamz0r has a reputation beyond reputeJamz0r has a reputation beyond reputeJamz0r has a reputation beyond reputeJamz0r has a reputation beyond reputeJamz0r has a reputation beyond repute
It sounds like dropout.
You have likely maxed out the number of effects your computer can handle.
Try disabling a few other plugins in your mix and see if the limiter still causes the dropout.
Old 11-22-2006
Newbie
It happens even if it's the only plugin.
Old 11-22-2006
Jamz0r's Avatar
Senior Member
Hmm...
What sample/bitrate are you using?
Maybe your project is incompatible with the plugin.
Synchronising two machines jpmorris Analog Only 17 03-16-2009 15:34
Contracts bknot1 DJ & Hip Hop Production 16 06-01-2006 23:33
Master Fader Gain vs. Limiter Gain scarboro78 Mixing / Mastering 5 01-26-2006 15:05
Roger Nichols Master Class in L.A. caseyLA Mixing / Mastering 0 08-10-2005 14:49
knowledge share on my vocoding emerald tablet Recording Techniques 10 08-16-2002 12:40
