Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 11-21-2006
slinky's Avatar
slinky slinky is offline
The Green Dream
slinky has a reputation beyond reputeslinky has a reputation beyond reputeslinky has a reputation beyond reputeslinky has a reputation beyond reputeslinky has a reputation beyond reputeslinky has a reputation beyond reputeslinky has a reputation beyond reputeslinky has a reputation beyond reputeslinky has a reputation beyond reputeslinky has a reputation beyond reputeslinky has a reputation beyond repute
Midi Cut Off
Hi again,
can anyone tell me how to program cut off in to a midi track so that it is automated. This is in cubase sx.
Thanks
Old 11-21-2006
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
um. cutoff in what? there is no such thing as "midi cutoff"
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 11-22-2006
slinky's Avatar
The Green Dream
cut off
Ok, well, in cubase sx the only place I have found the effect i am looking for is in the track control window of the inserts. When you tweak the cut off button you get that effect. I like to describe it as filter but it is also known as EQ or WAH WAH (with guitar) I would like to be able to program this effect so I don`t have to tweak in real time which is obviously very tricky and not good.
Old 11-22-2006
TelePaul's Avatar
TelePaul TelePaul is offline
J to the R O C
TelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond repute
You mean an envelope filter??
Originally Posted by Gummblefish
Went out yesterday all day long and spent 125 quid on a bender (not literally a bender )
Old 11-22-2006
Ok, those are three completely different things and none of those has anything to do with midi.
There are several plugins that are included on the cubase CD that will do what you are looking for, check the manual for "included plugins" and "plugin automation"
Old 11-22-2006
slinky's Avatar
The Green Dream
Enlighten me.
[QUOTE=altitude909]Ok, those are three completely different things and none of those has anything to do with midi.
Ok please can you tell me what that effect is called which takes a sound from a low to a high frequency or visa versa. I called it cut off because the tweaker in the midi effects under track control is called this. I know of a hardware product which does this called a filter. How can you say that EQ , WAH WAH and Filter are completely different? Would you mind expanding a little please?
Cheers
Old 11-22-2006
slinky's Avatar
The Green Dream
Erm I don`t know - sounds good though. The closest way of describing it is a wah wah effect like on a guitar but is used typically on keyboard sounds or often the whole mix is squashed and spat out again like in contemporary dance music.
Old 11-22-2006
travelin travis travelin travis is offline
Banned
travelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond repute
i don't have any idea what you're looking to achieve but if you're getting the effect you want with the cufoff knob in the track control plugin, see if you can automate the cutoff knob. press the "w" button (automation write), hit record, and play around with the knob. at playback, press the track's "r" button (read automation).
Old 11-22-2006
legionserial's Avatar
legionserial legionserial is offline
Dead
legionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond repute
Have you tried playing around with the stepfilter plugin in Cubase?
"Introduce a little anarchy. Upset the established order, and everything becomes chaos. I'm an agent of chaos.
Oh, and you know the thing about chaos? It's fair..."
Old 11-22-2006
noisewreck's Avatar
noisewreck noisewreck is offline
Sound Destroyer
noisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond repute
I think you're referring to filter cutoff. A filter can be Low-pass, High-pass, Band-pass, Notch... and other hybrids. What kinds of filters (if any) are available depend on the plugins (instruments, effects)... Different plugins will have different MIDI controller assigned to this knob (if they support MIDI at all... most VSTis do, but many VST effects don't). You need to find out what MIDI controller is assigned to that knob (or perhaps use MIDI learn) or if available use track automation to automate the movements of this knob.
In any case, read up on plugin automation in the manual or in the help menu... and pick up a bunch of electronic music related magazines and start reading them too. From the sounds of it, you could use all the education you can get
Think of how stupid the average person is, and realize half of them are stupider than that.
--George Carlin
Old 11-22-2006
slinky's Avatar
The Green Dream
[QUOTE= From the sounds of it, you could use all the education you can get [/QUOTE]
Yep, your not wrong there. Thanks for the help.
  #12
Old 11-22-2006
brzilian brzilian is offline
2.5K Gold Member
brzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond repute
What is the sound source? A VST instrument? Outboard synth?
MIDI is not audio. Wat you want to do has to be either done at the sound source (if your sound source allows for realtime control of sound characteristics) or applied to the bounced audio track in the form of a VST effect
Until you tell us where the sound is coming from, there is nothing anybody can do or say to help.
  #13
Old 11-22-2006
under inserts, look for step filter or tonic. That is what you are looking for and it is called a resonant filter btw. You will be able to "ride" the cutoff via the automation:
Right click on the audio (not midi) track that you have used the insert on, select show automation and click on the pull down menu and select Inserts: Tonic - Cutoff.
  #14
Old 11-24-2006
slinky's Avatar
The Green Dream
My sound source is the yamaha sw1000xg sound card and in this case I am dealing only in midi
  #15
Old 11-24-2006
Well, unless the filter is controllable via midi on that thing(which I doubt) then you will not be able to. If it is, then you will be able to do it inside the midi track by pulling up the appropriate CC lane
  #16
Old 11-24-2006
slinky's Avatar
The Green Dream
Ok thanks my friends for all the help. I will get there in the end. I promise you that!
Software samples for MIDI, what do I need to know? Vigilante Recording Techniques 3 12-06-2005 23:54
How do I hook everything together? mikara Newbies 20 09-02-2005 05:27
Midi and Creamware dangerman MIDI Mania 3 05-18-2005 00:53
drum machine, Cakewalk, USB MIDI interface, argh 55337 Newbies 14 03-09-2005 16:41
Oriion, Rebirth & Fruityloops with Sonar acgt Cakewalk / Sonar Forum 10 09-13-2002 13:21
