Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 11-20-2006
beezelbubba's Avatar
beezelbubba beezelbubba is offline
Male Lesbian
beezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond repute
The absolute minimum for midi guitar
I'd like to be able to use my guitar as a midi input device to use with VSTIs.Can anyone tell me the absolute minimum that is required to do this.
Old 11-20-2006
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
Either a midi pickup like to Roland GK3 (http://www.zzounds.com/item--ROLGK3)
or an actual midi guitar controller like the Yamaha G10 (what I use)
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 11-20-2006
Male Lesbian
I'm going to assume that something needs to go between a guitar mounted with a GK3 and my computers midi port.
Old 11-20-2006
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
The ones that work the best are the ones where the pickup is part of the bridge. They seem to track the best.
All you need a is the pickup, the converter and a midi cable.
If you are going for authentic representations of other instruments, you will have to learn to play the part like the instrument you are emulating.
For example: an E maj chord on a piano won't sound right if you play it like you normally would on the guitar, because the notes are in a different order.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 11-20-2006
Male Lesbian
Which converter?It isn't part of what altitude909 linked to,is it?That is only the pickup,correct?
Old 11-20-2006
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
No. A midi cable will be all you need in addition to that pickup in order to go into a single synth or a stand alone sequencer.
In order to use it with a computer you will need a USB - midi interface like this one.
...now in HD.
Old 11-20-2006
Sorry,
I should have looked that up. The GK uses a GK (not midi) cable which needs to be interfaced with a Roland GK device (there are several) before it will spit out midi
here is one: http://www.zzounds.com/item--ROLGI20
Old 11-20-2006
Male Lesbian
Originally Posted by altitude909
Sorry,
These posts seem quite contradictory.
I definately can't afford the RolandGI20.Is there a midi pickup that I would be able to use with the M-Audio thingie?
Old 11-20-2006
Farview's Avatar
Here's how it goes, there are 3 parts to the system.
1. hex pickup
2. pickup to midi converter
3. midi device (sequencer, keyboard, sound module)
I haven't looked into it in about 10 years, I'm sure there is some all-in-one solutions, but you need all three things present in order for it to work.
Jay Walsh
Old 11-20-2006
Info you can use...
Altitude and Farview are right and I am wrong.
I should have looked more carefully.
Here's a link to the full monty...
...now in HD.
Old 11-21-2006
Male Lesbian
Well, it would seem that this is a bit cost prohibitive!
Thanks for the help!
Stereo Mic'd Guitar Panning norg Mixing / Mastering 0 06-16-2005 17:33
Music - please rip apart Greenshoe MP3 Mixing Clinic 20 07-29-2003 00:49
Clipping, voice and guitar vagabond Recording Techniques 8 08-30-2002 23:52
