Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 11-16-2006
lttoler lttoler is offline
Senior Member
lttoler has a reputation beyond reputelttoler has a reputation beyond reputelttoler has a reputation beyond reputelttoler has a reputation beyond reputelttoler has a reputation beyond reputelttoler has a reputation beyond reputelttoler has a reputation beyond reputelttoler has a reputation beyond reputelttoler has a reputation beyond reputelttoler has a reputation beyond reputelttoler has a reputation beyond repute
Drum machine program
I am looking for a good program that I can use to map out drum beats. I need something that will do more than just loops cause I plan to map out full songs with the program. Does anyone know something that I should try out???
Old 11-16-2006
Uladine's Avatar
Uladine Uladine is offline
Dedicated Member
Uladine has a reputation beyond reputeUladine has a reputation beyond reputeUladine has a reputation beyond reputeUladine has a reputation beyond reputeUladine has a reputation beyond reputeUladine has a reputation beyond reputeUladine has a reputation beyond reputeUladine has a reputation beyond reputeUladine has a reputation beyond reputeUladine has a reputation beyond reputeUladine has a reputation beyond repute
most of the more popular recording programs have midi sequencers built in. Sonar, Cubase, Nuendo...
Old 11-16-2006
danny.guitar
Guest
Posts: n/a
There's also Guitar Pro, a guitar tab editor.
You can tab out an entire song of drums, render it as MIDI and run it through a drum VSTi or something.
But if your recording software has a MIDI sequencer, you could also use that.
Guitar Pro also has a percussion list of all MIDI notes and which drum they correspond to, makes it real easy.
Old 11-16-2006
tc4b's Avatar
tc4b tc4b is offline
boom, BAP! Boom boom BAP
tc4b has a reputation beyond reputetc4b has a reputation beyond reputetc4b has a reputation beyond reputetc4b has a reputation beyond reputetc4b has a reputation beyond reputetc4b has a reputation beyond reputetc4b has a reputation beyond reputetc4b has a reputation beyond reputetc4b has a reputation beyond reputetc4b has a reputation beyond reputetc4b has a reputation beyond repute
Fruity Loops. It's the only one I've ever used, but it sure as hell does a lot, including what you describe.
Old 11-16-2006
Senior Member
Ok I got a tab editor and can map out drum midis on it. What can I run it through now?
Old 11-16-2006
danny.guitar
Guest
Posts: n/a
First export it as a MIDI file.
Then you need to find a drum VST. I use EZDrummer.
There are some free ones too, but you'll have to search around.
Try: www.kvraudio.com
Old 11-16-2006
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
Here's a link to a shareware drum machine --- LINK --- called Leafdrums.
It's easy to use, has some useful effects built in, uses .wav files and renders nicely to another .wav file when you're done putting your patterns together.
And it's very easy to string patterns together into songs.
...now in HD.
Old 11-16-2006
Senior Member
Is there anywhere I can download a demo of EX Drummer to see if it's something that I could use?
Old 11-17-2006
zacanger's Avatar
zacanger zacanger is offline
of Angry Man Records
zacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond reputezacanger has a reputation beyond repute
Leafdrums is pretty cool. I usually use Hammerhead, and instead of doing an entire song at once I'll make different loops and use them in Kristal, since I usually have the same sort of drums in verses, choruses, etc.
Digital drum machine program? Stereo_Phile Drums and Percussion 5 10-06-2006 03:00
Drums - Loops or Drum Machine? cincy_kid Recording Techniques 7 03-16-2006 20:00
how to use midi sync with drum machine & NI's BATTERY stingray Cakewalk / Sonar Forum 1 10-29-2003 12:03
dr 660 drum machine 4 sale. xpurt Keyboards and Sound Modules 2 09-19-2003 08:00
Drum Machine/ Drum Pad for Recording swingandstrings Drums and Percussion 2 12-21-2001 06:40
