Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 11-15-2006
msmales555's Avatar
msmales555 msmales555 is offline
Senior Member
msmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond repute
Problem Exporting - Cubase LE
Hi,
I;ve been using Cubase LE for about two years now and I just ran into two problems today:
1)when trying to use a plug-in that has worked hundred of times in the past the plugin failed to work at all
and
2) When trying to export files the result was a file with no information or one that sounded teally bad. (locaters were set correctly).
Problem - 1 - For some reason the limiter plug-in that I was putting on the Master Channel was not working today....This is the fashion in which I always use it, so it doesn't make much sense to me as to why it wouldn't work at all. It is the Classic Master Limiter plugin.
Problem - 2 - When I tried to mix down the song I recorded without the limiter, it mixed down (I had the locaters in the correct spots too), but when i tried to play the wave file in two different media players it did not work...it also came up as being only 4kb in size. I mixed it down as a WMA file and this time the track played and was the appropriate size, but it was ridiculously quiet and sounded quite "tinny" and there was a lot of hiss and noise in the track.
Everything sounded great while playing it in Cubase. I restarted Cubase and reopened the file but it still did not work.
What is wrong? What should I do?
Old 11-16-2006
Carter's Avatar
Carter Carter is offline
Total gear slut
Carter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond repute
Uninstall Cubase, reboot, reinstall Cubase, reboot.
Carter
MCF Productions
Cubase LE installation problem. NLAlston Cubase User Forum 14 12-15-2005 09:14
Problem with Cubase SX, Absynth 3.0, Midi keyboard (all together) mcsantorini MIDI Mania 2 02-22-2005 17:57
Problem with Cubase SX, Absynth 3.0, Midi keyboard (all together) mcsantorini Cubase User Forum 0 02-04-2005 13:18
Argh! Reason & Cubase sync problem. trogdor Digital Recording & Computers 1 09-20-2003 11:08
I need help Im having major problem with Cubase on th Mac! c_r_a_z_y Cubase User Forum 0 02-20-2002 02:38
