Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 11-13-2006
rgraves rgraves is offline
Senior Member
rgraves has a reputation beyond reputergraves has a reputation beyond reputergraves has a reputation beyond reputergraves has a reputation beyond reputergraves has a reputation beyond reputergraves has a reputation beyond reputergraves has a reputation beyond reputergraves has a reputation beyond reputergraves has a reputation beyond reputergraves has a reputation beyond reputergraves has a reputation beyond repute
Using a high pass or low pass filter
Hi there, can someone help to explain to me how to make a high or low pass filter on Cubase? I've used the EQ on the track mixer a lot, but I couldn't see any kind of complete filter for a wide range of freqencies or something like that. I want to use something like that for bass guitar and then high pass for distorted guitar.
Any help would be appreciated,
Thanks!
Old 11-13-2006
RezN8's Avatar
RezN8 RezN8 is offline
Blick-um, blick-um...
RezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond repute
On the EQ, click on the number 1 and click the "cut" button below it. This will give you a low cut. You can do the same for the number 4 for a hi-cut.
Old 11-13-2006
Kevin Deschwazi's Avatar
Kevin Deschwazi Kevin Deschwazi is offline
Brittunculus
Kevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond repute
On the high and low filters turn the Q (bandwidth) control (bottom knob) fully clockwise. It will say High P or Low P in the Q window and you're away.
"Just give the great unwashed a pair of oversized breasts and a happy ending, and they'll 'oink' for more every time."
C. M. Burns
http://www.shuttleworths.co.uk/micloop.gif
Old 11-13-2006
Brittunculus
Looks like you have the method for 2 different versions of Cubase.
Mine is for SX3.
C. M. Burns
Old 11-13-2006
Senior Member
Oh yeah, I should have specified, sorry. I have SX3...the method Kevin mentioned seems the only one that would make sense in the version I have. I will try that, thanks a lot!!
Old 11-13-2006
Senior Member
Also, how would one set up a bandpass filter?
Thanks again
Old 11-13-2006
Brittunculus
A band pass filter allows a selected ‘band’ of frequencies to ‘pass’ and rejects frequencies either side of that selected range.
So if you think about it, engaging both high and low pass filters at the same time gives you a band pass filter.
C. M. Burns
Old 11-22-2006
RezN8's Avatar
Uh Doi! I just realized I was referring to the "Q" plug in that comes with SX3. I think it sounds better than their standard EQ channel. Sorry for the misinformation.
BTW- SX4 is said to have a much better updated EQ. I hope that's not just hype. Cheers, Rez
the Basics fuquam Mixing / Mastering 26 02-26-2007 18:45
low cut/ high pass surfmaster Mixing / Mastering 2 06-23-2006 19:26
100 Hz high pass cut djclueveli Mixing / Mastering 4 02-04-2006 17:38
What's your best recording tip? bluelot2 Mixing / Mastering 53 11-03-2000 17:11
high pass on aux sends crosstudio Mixing / Mastering 1 08-09-2000 00:08
