VST Plugins.
I just go my Sonar 6 and maybe I could start collecting some VST effects from now.
Any good website or reccomendation on VST ? Probably free one is good : ] |
You can go here, and search for many. http://www.hitsquad.com/smm/
I have used the Classic series from KVR Audio, and they work well. I've tried many others, and some are good.
I won the internets...... |
http://www.kvraudio.com/ has a search feature. I'd bet 90% of the plugins I use I found here. Almost all of the ones I never use are from there too
Dogman has the best Avatars ever. |
5 threads down from yours is one about Pro Audio & VST wrappers. There are a couple of posts through there that have links to FREE VSTs. Just be sure to trawl through the whol thread & try all the links.
If you are looking for VST effects, give the Kjaerhous (?sp) suite a try. They are well regarded.
There are a million and one VST effects out there. The question is, what will you actually use? A good idea is to practice using the standard effects (EQ, compression, chorus, delay, reverb) so you get to learn how to use them, then go searching for extra VST effects if you need something more. Why not just start using the Sonitus suite that comes with Sonar? |
| Vst Plugins In Acid Pro 6 | gblaze | Cubase User Forum | 3 | 08-19-2006 08:33 |
| In Cubase SX 3, my VST plugins receive key commands even if it's unchecked in prefs.. | geneticfunk | Cubase User Forum | 0 | 08-01-2006 01:40 |
| *Download* VST Plugins | Phoenix5891 | Mixing / Mastering | 35 | 02-24-2006 12:10 |
| VST plugins for Cubase SE | SMX_Dizzy | Cubase User Forum | 2 | 06-08-2005 20:10 |
| Newbie question about VST Plugins | Riff_hunter | Cubase User Forum | 1 | 01-12-2003 12:44 |
