Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 11-12-2006
lasagne lasagne is offline
I fancy Fancy
lasagne has a reputation beyond reputelasagne has a reputation beyond reputelasagne has a reputation beyond reputelasagne has a reputation beyond reputelasagne has a reputation beyond reputelasagne has a reputation beyond reputelasagne has a reputation beyond reputelasagne has a reputation beyond reputelasagne has a reputation beyond reputelasagne has a reputation beyond reputelasagne has a reputation beyond repute
Previewing effects in Cubase
Probably a dumb question, but when I preview an effect on a track in SX3 I can only hear that track and how the effect changes it, when what I really want to preview is how the effected track will sound in the mix, if you see what I mean. Is there a way of previewing an effect on a single track while all the tracks are playing ?
Badly worded, but I'm sure you get the point.
"I'm here all week"
Old 11-12-2006
Phildo Phildo is offline
I heart guitars!
Phildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond repute
Um...just use the "Bypass" button on the effect? Are you talking about "Send" or "insert" effects?
"I killed the President of Paraguay with a fork..."
www.myspace.com/germanfilmstars
www.myspace.com/weirdoiom
www.myspace.com/stoliday
Old 11-12-2006
I fancy Fancy
I'm talking about audio - plug in - choose an effect, say reverb. Click on preview and it plays the track with the effect added, but not all the tracks together. If I'm adding reverb to vox (for example) I want to hear how that vox with the added reverb will sit in the whole mix - I'm not so interested on the track sounds individually.
"I'm here all week"
Old 11-12-2006
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
um, again are you talking about an insert or a send? all audio plugins are either one or the other...
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 11-12-2006
I fancy Fancy
um, OK. I'm using off-line processing, which I think answers my own question. I need to use either insert or send to be able to preview how the affected track sounds like in the whole mix.
Your posts did actually help me figure out the answer, so thanks for that.
Now if only I could understand the difference between insert and send......
"I'm here all week"
Old 11-12-2006
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
Inserts are used when you want the whole signal to go through the plugin, like with an eq or a compressor.
Sends are for when you want to still hear the original uneffected sound along with the effect, like delay and reverb.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 11-12-2006
I fancy Fancy
Thanks for the succinct response Farview. Seeing as they're the only effects I use, I shall use them in the way you've described.
"I'm here all week"
Old 11-12-2006
why are you processing the audio offline?
Old 11-12-2006
I fancy Fancy
Just because you click Audio - Plug Ins and choose the effect you want. I did it to get started quickly without having to read the manual
"I'm here all week"
Old 11-12-2006
Ah. its usually easier to RTFM then asking questions on how to do things incorrectly, no?
Syncing reel-to-reel to Cubase; or the other way round wolkenvelden Digital Recording & Computers 0 03-18-2006 16:38
Is Cubase for me? tsphillips Cubase User Forum 4 05-26-2004 08:02
Cubase effects iproduce Cubase User Forum 1 04-23-2004 14:35
live effects in cubase sx? dopey Cubase User Forum 5 04-14-2004 13:52
Triton Effects mart Keyboards and Sound Modules 1 04-29-2003 17:00
