M-audio Keystation 66 velocity probs
Does anyone know if there is a way to adjust the velocity sensitivity on the keystation 66?
At the moment its basicly impossible to hit 127 without smashing my fist onto the keys in a moment of rage. cheers
Instrumental Prog Metal all written and performed by myself. http://www.audiostreet.net/artist.aspx?artistid=31381 New stuff on the way as usual. |
There is no midi command that will compress the velocity or move the lower velocities up to the top of the key travel or however you want to put it.
That function is usually done through a user selectable series of velocity curves. Read your manual, then go into the unit and see if there's not something that the manual doesn't mention as far as a velocity curve utility page. It may even be a hardware knob on the side or back of the unit. Failing either of those, there's a feature in MidiOx called a 'translation map' that would be able to help, but you'd need to run it every time you wanted to play the Keystation... .
...now in HD. |
yep ive read the manual several times, there is nothing i can see in there. i was hoping for a workaround other than editing all the notes in the piano roll.
ill check out that MIDIox thing. cheers
Ah I figured it out, you have 5 keys too many!
But seriously I dont think the keystation series will alow that sort of functionality. Try e-mailing M-Audio Tech support they could give a yeah or neah. -Blaze
Analog! Shmanalog! I want my Digimon!....... Oh! thats were my hand was!
bah, screw it.
NEW KEYBOARD TIME!!!!! weeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee The Cme-8 is calling me ![]()
otherwise I would have exchanged mine straight away as well (and sadly changing velocity curves results in very unnatural and dodgy responses in my opinion)
The Woods |
| Sample CDs and Reason Refills for Sale! | AllStaar.Com | DJ & Hip Hop Production | 6 | 04-03-2006 13:16 |
| How do I... | SnoboarderX27 | Recording Techniques | 9 | 03-28-2005 02:17 |
| MIDI to Audio in DP 4.5 - Techniques and Levels? | RhythmRmixd | MIDI Mania | 2 | 12-27-2004 14:06 |
| CD Audio Playback (I don't get it) | AudioNovice | Digital Recording & Computers | 2 | 08-19-2004 17:11 |
| Difference between SEND and INSERT in cubase | Gabriel Sousa | Digital Recording & Computers | 4 | 01-27-2003 12:48 |
