turntable question
Ok i gotta question....... i wanna cop a turntable for mixing but this is my question i have the emu 0404 and an audiobuddy i wanna record str8 from a turntable to a computer and i was looking at getting the numark PT01 now would i need to go from the PT01 to the audio buddy then to the soundcard in and record mono...... or do I go str8 to the soundcard?
The Numark PT-01 has a built in preamp, so you can plug it straight into your soundcard.
What's an Audio Buddy?
Jibran aka The Deen Check me out on MySpace James Yancey and James Brown, Rest in Peace We'll keep your legacies alive by making that music! |
the m-audio audiobuddy is a mic/instrument preamp
it will work without a RIAA preamp but that tt is far from useful as a mixing deck
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual |
are you wanting to scratch or are you just wanting to sample off vinyl?
id like to do both but mainly sample
For recording it will be fine but for mixing/scratching (i.e. pitching the record to the right tempo and cuing it on beat) it is too light and the motor will not have enough torque.
could anybody recommend another turntable setup for maybe 100 - 200 that i could get that would allow me to be able to scratch and just record..... i ask about scratching because i could see myself trying that out for like hooks/beat breaks/ and other stuff like that
Look for a used Technics 1200 mkII, you should be able to find one for about that much
You cannot scratch on a belt drive turntable.
Look into a used Technics 1200/1210 Mk2 or a new Gemini TT-04 - both should fill your needs nicely.
#12
i think ill go with the pt-01 and say forget scratching for now
#13
Sounds good 'cause, even if you later get a direct drive for scratching, you still have a use for the PT-01 for when you go digging.
| Question about monitoring. | someguy211 | Newbies | 4 | 08-24-2006 21:48 |
| What Turntables Should I Buy | close | DJ & Hip Hop Production | 7 | 03-16-2006 11:21 |
| Grounding Turntable | What Have You | Newbies | 3 | 04-05-2003 01:38 |
| Delta 1010 output question? | henry_mullis | Digital Recording & Computers | 1 | 12-28-2002 11:12 |
