Cubase LE!! Need Help
arright so i have Cubase LE an im tryna mix but when i go to inserts i can only load 2 effects, is there any way i can Load More?
an im confused with sends....what exactly is that? can i put effects in threw that? thank u |
Inserts and Sends are both for effects. In general, use inserts for dynamic processors (compression) and sends for time/space processors (reverbs/delays). LE is limited to 2 inserts per channel. I think there are some VST effects that may let you load multiple inserts into a single slot, but I don't recall the names of any right now. You can also get more effects by grouping channels and applying additional effects to the group channel.
how do i group channels an what is that?
You create a group like this=
1)right click below your current tracks (as you would to add an audio or MIDI track)... and select create a new group. You'll be able to do it via a pull down menu at the top too. 2)Name the new group something sensible 3)Then go to all the tracks you want to group and route them from Bus 1 to the new group. |
| soundcards, and cubase system 4 | rxkevco | Digital Recording & Computers | 0 | 11-15-2005 17:53 |
| Hope For The Hopeless(Courses Offered From Cubase) | Sleddog72 | Newbies | 0 | 10-25-2005 17:44 |
| Atmosphere not working within cubase | bewildered | Cubase User Forum | 8 | 10-21-2005 22:46 |
| Midiman 4x4 and Cubase SL3 prob | xstatic | Cubase User Forum | 1 | 04-25-2005 11:16 |
| Simple Cubase SE Questions | seryozha | Cubase User Forum | 3 | 04-03-2005 01:54 |
