Old 11-03-2006
aznwonderboy aznwonderboy is offline
Senior Member
aznwonderboy is on a distinguished road
Listen to these clips, Do I need room treatment?
After upgrading preamp from DMP3 to Great River ME-1NV and still could not hear any improvement in the vocal, I began to question the acoustics of my untreated room.
Some said that a good vocal recording can be obtained in an untreated room if the singer stands fairly close to the mic and keep the gain at a low level. I did just that (no computer noise or clock-ticking noise ever got into my recording, not even sounds of the dog barking in the yard or of occasional cars running by).
Maybe I just can't hear the difference due to my untrained ears or low-end monitors. However, I can clearly hear the high quality of the vocal in the professional sample. Please have a listen (these samples are in Vietnamese):
1. (Dry Vocal) http://www.lightningmp3.com/live/file.php?fid=5464
2. (Wet vocal with backing track) http://www.lightningmp3.com/live/file.php?fid=5466
3. (Professional Sample) http://www.lightningmp3.com/live/file.php?fid=5467
Question: Should I get either blankets or 703 panels to absorb the reflections during vocal recording? What else can I do to imitate that professional vocal sound?
Old 11-03-2006
kojdogg's Avatar
kojdogg kojdogg is offline
bollocks redux!
kojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond repute
Is this maybe a mic issue-- were the mics used the same? Did they also us a GR for the "pro" sample? Are there eq differences between the two samples as well? The pro sample seems to have more higher frequency stuff going on.
If this is a room issue, maybe some baffles would help. You can get the Auralex Aural Xpanders for like $35-45 on the bay, sE makes that crazy Reflexion filter thing for like $300, and I've been thinking of picking up a "modtrap" from here: www.modtrap.com
The modtraps are apparently made by a couple of TapeOp Diy's and are brackted, mountable 703 panels that mount on mic stands.
SPACE AVAILABLE FOR RENT
Old 11-03-2006
Senior Member
samples 1 and 2 used same mic.
No, I don't know what mic or preamp the pro used.
I just wonder if making a portable vocal "booth" with 703 panels (similar shape to the Reflexion Filter) will help improve the vocal or not. Or do you think it's good enough already?
Old 11-03-2006
metalhead28's Avatar
metalhead28 metalhead28 is offline
Hates Raymond
metalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond repute
It definitely sounds like the room is having a negative impact on the first dry sample. But primarily, I think it sounds like a drastically different mic with a different frequency respose.
Some of my music
size of CR window cmick Studio Building & Display 7 04-12-2007 02:20
Bare insulation as room treatment? mcolling Studio Building & Display 7 10-05-2006 09:08
Question on Room treatment thegatekeeper Studio Building & Display 19 01-13-2006 13:15
Inexpensive room treatment Jute Studio Building & Display 4 05-24-2003 23:10
Thanks! and an explanation of sjoko's control room (long post) sjoko2 Studio Building & Display 5 03-13-2001 03:32
