Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 11-02-2006
TelePaul's Avatar
TelePaul TelePaul is offline
J to the R O C
TelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond reputeTelePaul has a reputation beyond repute
2 quick questions.
Hey guys, 2 quick questions.
Firstly, I'm in the middle of a project, and I noticed in the project window that its says im recording in 16 bit...but I'm using an ASIO 24 bit driver. Which is correct?
Second, why is there a VSt folder in the Steinberg directory, and a VST folder in the Cubase directory? Im moving my VTs into the STeinberg Directory.
Thanks guys.
Originally Posted by Gummblefish
Went out yesterday all day long and spent 125 quid on a bender (not literally a bender )
Old 11-02-2006
NYMorningstar NYMorningstar is offline
Recording Modus Operandi
NYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond repute
Thanks guys.
I'll byte. If it says you are recording in 16 bit then you are recording in 16 bit.
Originally Posted by chessrock
There's this thing on our site ... called "the Newbie section." And it's really cool. And even if your name isn't NYMonrningstar, you can still get a lot out of it. .
Old 11-02-2006
TelePaul's Avatar
J to the R O C
And how do i fix this? Is it down to driver selection?
Old 11-02-2006
RezN8's Avatar
RezN8 RezN8 is offline
Blick-um, blick-um...
RezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond repute
Did you set it in the project window?
Project/Project Set Up
Set the "Record Format" to 32 bit float.
Sorry I can't help with the second question. I dunno.
Old 11-02-2006
TelePaul's Avatar
J to the R O C
it can go a shigh as 32? Sorry to labour this, but I thought I could either have 16 or 24.
Old 11-02-2006
NL5's Avatar
NL5 NL5 is offline
Unpossible!
NL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond repute
There is no point to recording in 32 bit float.
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F.
Old 11-02-2006
TelePaul's Avatar
J to the R O C
hey NL5! I take it ya read up on my predicament, any ideas on how to record in 24 bit?
Old 11-02-2006
noisewreck's Avatar
noisewreck noisewreck is offline
Sound Destroyer
noisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond reputenoisewreck has a reputation beyond repute
Actually, depending on the driver of the soundcard (and most by now work this way) there is a performance benefit in working in 32bit float. It may not make a difference in sound as all internal processing is done at 32bit float anyway, but by also recording in 32 bit, you put less strain on the processor. Even 24 bit recording still uses all 32 bits of the pipes in the CPU registers, so the CPU will need to pad them with extra 0s, when flipping to 32 bit recording this padding is done at the soundcard level.
Think of how stupid the average person is, and realize half of them are stupider than that.
--George Carlin
Old 11-02-2006
travelin travis travelin travis is offline
Banned
travelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond repute
For most people that are just screwing around, there's probably no point to recording in 24 bit.
The Cubase vst folder contains the stuff included with Cubase. It does'nt matter where you put your plugins. You might want to create your own shared VST folder for easy access. For example C:\VST.
Old 11-02-2006
NL5's Avatar
NL5 NL5 is offline
Unpossible!
At the very least this part is not true, and I really doubt any of what you posted is correct.
TelePaul - Got to the project menu, and select project setup.
Old 11-03-2006
TelePaul's Avatar
J to the R O C
Thanks NL5! You the man!
  #12
Old 11-03-2006
RezN8's Avatar
Hey wait!!! I'm sapposed to me "the man"! I was the one who told you how to change your recording format in the first place . (sorry, I'm on new meds and they are making me a little edgy ).
The reason why I said to change it to 32-bit float is based on this info:
When you record with effects you should consider setting the record
format (bit depth) to 32 Bit Float. This is done in the Project Setup di-
alog on the Project menu. Note that this isn’t required in any way –
you can record with effects in 24 or 16 Bit format should you so like.
However, there are two advantages to 32 Bit Float format:
• With 32 Bit Float recording you don’t risk clipping (digital distortion)
in the recorded files.
This can of course be avoided with 24 or 16 Bit recording as well, but requires more
care with the levels.
• Cubase SX processes audio internally in 32 Bit Float format – record-
ing in the same format means the audio quality will be kept absolutely
pristine.
The reason is that the effect processing in the input channel (as well as any level or EQ
settings you make there) is done in 32 Bit Float format. If you record at 16 or 24 Bit,
the audio will be converted to this lower resolution when it’s written to file – with pos-
sible signal degradation as a result.
Note also that it doesn’t matter at which actual resolution your audio
hardware works. Even if the signal from the audio hardware is in 16 Bit
resolution, the signal will be 32 Bit Float after the effects are added in
the input channel.
Anyway, you're welcome.
  #13
Old 11-03-2006
TelePaul's Avatar
J to the R O C
pristine.
the input channel.
Thats cool and thanks, you are also 'the man'. So...theres 16 bit, 24 bit AND 32 bit float? There was I thinking i could only use 16 or 24. Hmmmm. Are tehre drawbacks of 32 bit float?
  #14
Old 11-03-2006
Banned
File size.
  #15
Old 11-03-2006
TelePaul's Avatar
J to the R O C
Originally Posted by TravisinFlorida
File size.
Bigger file size, gotcha. I dont keep many projects after I'm done with em anyways though. Thanks.
  #16
Old 11-03-2006
RezN8's Avatar
I wonder if that's the only disadvantage, though. After I clearly heard the differences between 16 bit vs. 24 bit, etc. -- I never gave it much thought.
When I first starting using 32-bit, I couldn't understand why I had so much headroom. I guess that's the biggest advantage for me.
  #17
Old 11-03-2006
pristine.
the input channel.
When you have 24 bit converters, doesn't that limit the recording to 24 bit resolution? When you change Cubase to 32 bit float format does that make your 24 bit converters clip less?
  #18
Old 11-03-2006
noisewreck's Avatar
Sound Destroyer
Hmmm. Perhaps I am not reading this right. It seems the padding is done regardless. So, NM!
Aardvark Q-10 Pro Manual
There are several ways for a program to interpret 24 bit audio
data. The Q10 does this by left justifying 24 bit data in a 32 bit word. In some
audio programs, you will have to specify this particular 24 bit format in order for
it to work. Depending on the program, it may also be referred to as "24 bit
unpacked", "24 bit left-justified" or "24 bit alternate".
Terratec EWX 24/96 Manual
The drivers support another, special data transport format, called “32 Bit unpacked”.
For the curious: audio data streams are sent over the PCI bus to the main memory. The
PCI bus operates on 32 “channels” (32 Bit). So a PC usually pays special attention that
all of it’s resources get used for the task at hand, and so for the transport of 8 Bit
audio files they are bundled into fours (4 x 8 = 32), bei 16 Bit and 16 Bit data into
bundles of two (2 x 16 = 32) so that they can be sent along (diagram top).
With 24 bit audio material the situation becomes more complicated to process: all of a
sudden there are “only” 24 harmonious bits there - then 8 are “missing” completely.
The “24 Bit packed” method solves this in the following way: the CPU (lets say a
Pentium) splits the 24 Bit stream into multiples of 32 (diagram middle). That costs
power and doesn’t have to be.
Using the “32 Bit unpacked” method the rest of the 24 data-bits are filled with zeros
by the hardware and sent by the driver as an appropriate 32 Bit packet. Most of the
software on the market today supports this resource saving method (diagram bottom).
--George Carlin
  #19
Old 11-03-2006
noisewreck's Avatar
Sound Destroyer
No, but it minimises the possibility of clipping [i]within[/w] Cubase. Plus, it's still makes it easy on FX specially stuff such as reverbs and delays to cope with extremely small numbers.
--George Carlin
  #20
Old 11-03-2006
TelePaul's Avatar
J to the R O C
Thnaks alot Noisewreck, it sounds pretty handy, i'll give it a shot and see how it goes, I only have 512 mb of ram, so any saving of processing power is handy.
  #21
Old 11-03-2006
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
This is only relevant if you insert effects in the input buss. If you don't record with effects, there is no advantage.
Maybe some people do, but I never print a reverb (or anything else) on a track that I am recording. I record it dry, then put the reverb on during the mix. The only exception that I can think of is using some sort of amp simulator plugin, but I would still just record the dry signal and monitor the simulator.
Recording in 32 bit doesn't minimise the possibility of clipping within cubase, because all of the math inside cubase is 23 bit float no matter what the file is saved at.
The CPU cycles that are saved by having the soundcard add the zeros don't matter much when you take into account the fact that the hard drive now has to write 1/3 faster to keep up. You probably have more extra CPU cycles than you do hard drive throughput.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
  #22
Old 11-03-2006
TelePaul's Avatar
J to the R O C
Uhmm....is 24 bit okay? My 2 quick questions were'nt so quick.
  #23
Old 11-03-2006
Farview's Avatar
24 bit is preferable.
Jay Walsh
  #24
Old 11-04-2006
RezN8's Avatar
OUCH! Now my head hurts!!!
If what you're saying is correct, Fairview, then I have no use for 32bit float. Thanks!
quick questions about mixing dave123454321 Newbies 9 04-05-2006 11:14
questions, questions, questions chronicinsomnia Newbies 8 12-08-2004 18:48
BUILDING A NEW DAW: What to buy and better yet, what questions to ask? 3des Digital Recording & Computers 16 06-29-2003 03:33
Two Quick Sonar Questions rjt Cakewalk / Sonar Forum 3 12-17-2001 20:40
Please try the search before asking questions ola Other Equipment and Reviews 5 10-24-2000 02:09
