Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 10-30-2006
allmusic allmusic is offline
Newbie
allmusic has a reputation beyond reputeallmusic has a reputation beyond reputeallmusic has a reputation beyond reputeallmusic has a reputation beyond reputeallmusic has a reputation beyond reputeallmusic has a reputation beyond reputeallmusic has a reputation beyond reputeallmusic has a reputation beyond reputeallmusic has a reputation beyond reputeallmusic has a reputation beyond reputeallmusic has a reputation beyond repute
MIDI to Audio in Cubase SX
How do I convert MIDI to audio file or wav file in Cubase SX? I'm a beginner, so please bare with me I thought to play back MIDI file in Cubase while hitting Record in Wavelab - but Wavelab doesn't record anything. Could be that my soundcard, Audiophile 2696, doesn't support MIDI playback and I don't know how to use VSTi to reroute.... I'm lost, where do I start to figure this out?
Old 10-30-2006
studiomaster's Avatar
studiomaster studiomaster is offline
MachWave
studiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond repute
MIDI is NOT audio. Hence, you cannot convert audio to MIDI or viceversa. If you have a soft synth routed to the MIDI output of the specific MIDI track, you could record the soft synth's audio signal to an audio track to hear the audio. I really suggest learning the basics at www.tweakheadz.com.
Old 10-31-2006
Superhuman Superhuman is offline
Shagaholic
Superhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond reputeSuperhuman has a reputation beyond repute
Check out www.cubase.net
There is a sticky on the top of the SX3 forum regarding this, everything is explained. Make sure you register your product there too, if you post a question and don't register it will be deleted.
Some 7 string shred...
Old 10-31-2006
legionserial's Avatar
legionserial legionserial is offline
Dead
legionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond repute
Do an audio mixdown of the midi to a wav file. Cubase's built help should fill you in more on audio mixdowns.
"Introduce a little anarchy. Upset the established order, and everything becomes chaos. I'm an agent of chaos.
Oh, and you know the thing about chaos? It's fair..."
Old 11-01-2006
Newbie
Thank you guys for your tips. I've tried all the tricks and it still doesn't work. I'm thinking it's because of my soundcard, M-Audio 2496 - it doesn't support playing back MIDI on the computer speakers- so I always play back MIDI on the synth speakers (Yamaha Clavinova). I've heard there's a way around to rewire thru VSTi but I'm not there yet - it's all a little too much for now. In Cubase the only In and Out for sound is 'Delta AP MIDI'.... it gets me nowhere but back to my synth speakers.
Old 11-01-2006
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
You have to record the audio as an audio track, there is no other way to do it with an external synth. You can use a VSTi and then do it internal via audio mixdown, but there is no real reason to do that since when you have a vsti running, cubase automatically creates an audio track for it
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 11-01-2006
RezN8's Avatar
RezN8 RezN8 is offline
Blick-um, blick-um...
RezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond repute
So to add to all the great responses above:
to record the sounds that are coming from inside your keyboard, you must patch cable(s) from the keyboard's out(s) to the M-Audio 2496 in(s).
to record midi data you use a midi cable plugged to your soundcard (or USB, etc.) This gets recorded as a midi file, which can tell your keyboard to play back those sounds OUT of your keyboard (or a softsynth if you route it that way).
using a midi keyboard to trigger sounds from a softsynth and record it as a wav file, you need to engage the record button not on the midi track but on the softsynth's audiotrack.
Hope this helps, or at least makes sense, I started me drinkin' early today - Cheers, Rez
Attention Newbies: Copy and Save This For Reference!!! (Pt 1) Buck62 Newbies 11 03-27-2009 15:57
Midi track with Sonar & Audigy’s Interface?? carlosfl Cakewalk / Sonar Forum 6 06-25-2005 11:16
Oriion, Rebirth & Fruityloops with Sonar acgt Cakewalk / Sonar Forum 10 09-13-2002 13:21
CD Writing Stephen Jones Cakewalk / Sonar Forum 15 10-12-2001 16:42
Cubase 5/G4/Fastlane Midi problem wormhole70 Cubase User Forum 1 04-23-2001 03:14
