A quick question for the gurus out there... I recently picked up a mic headset to use for VOIP that is terminated to separate stereo 1/8" mic and speaker connections. Is it possible for me to use an 1/8" to 1/4" TRS adaptor, then a Female 1/8" to Male XLR adaptor such as the one below... and get a usable signal from the mic when plugged into the XLR input of my mixer? Or do I need a transformer of some sort?
http://www.jacksmusicfactory.com/def...-_XLRM_Adapter Also, is there a reason why a female 1/8" to XLR male is much more expensive than a female 1/4" to XLR male? http://www.soundprofessionals.com/cg...source=froogle Regards, MrPlow |
Headset mics usually get a few volts of power from the device they are plugged into . . . if your headset needs power, your solution won't work.
I agree that you may need power from one of the contacts on the mic part. The reason that the 1/8" connection is trs is probably due to that fact and not because it is a low z balanced connection. The headphone connection should work so long as you are sending it stereo information. As to why the 1/8" adaptor is more expensive would probably be because there is less demand for such a connection, 1/4" to xlr is a far more common occurance in audio, thus less are manufactured, thus more pricey to do so.
Peter Miller |
Thanks for the info guys. Looks like I'll have to go with an XLR headset w/mic... any recommendations in the $75-$150 range?
if you are only looking for a mic, look at the shure wh20XLR, should sell for about $80.00-$90.00.
Let me know if you need one, I can ship one to you. Or see if you can find a Crown CM311 used, I have seen them new online for around $170.00 oh yeah, you might be able to find some telex stuff used with headset and mic. Usually you can find someone who has them as part of a broadcast system , who doesn't really know how much they go for. Audio technica and senn make them too but they all are at least $200 or more.
Peter Miller Last edited by petermiller; 10-28-2006 at 11:18.. Reason: more info |
Thanks for the recommendations, Peter. I should of clarified that I'm actually looking for headphones with a mic (ie for Internet radio use). I've seen the Sennheiser HMD280 and Beyerdynamic DT290, but both are a bit too bulky and out of my budget as well. Would I be better off getting just using the headphones I have right now, and getting an omnidirectional XLR clip-on lav mic, such as the AKG D409?
| Quick newbie question about the Motu 828 MKII | maxf | Digital Recording & Computers | 30 | 08-08-2006 17:19 |
| Help: Mic Decisions and My Trip to Guitar Center | JohnnyMan | Microphones | 61 | 04-16-2006 22:38 |
| Problem putting XLR cable into mic | RideTheCrash | Microphones | 9 | 06-29-2005 15:00 |
| Ok, I just got a new mixer and mic..... i need some help | Revone | Newbies | 13 | 08-08-2002 16:52 |
| NT1 Rode ? | Ears | Microphones | 24 | 06-27-2000 09:16 |
