Old 10-26-2006
SilentSound SilentSound is offline
Dedicated Member
SilentSound is on a distinguished road
Sonar 4 Producer Woes...
I've recorded flawlessly before with this same computer, but after a friend tweaked it deeply to be nothing but a recording machine and upgraded Sonar to 4 - Producer Edition, anything recorded independently of anything else seems slightly delayed upon playback. It's very slight but greatly affects how a drum and bass track recorded in seperate takes work together and requires lining up the track.
I've experimented with a lot of i/o buffer options to see what would yield any results but so far nothing.
I'm using 2 MOTU 2408 MKII's via firewire to its proprietary pci-324 card.
For example, I recorded to a 16 Track 1" analog machine, dumped it in the computer, but when we started tracking anything not recorded on the machine we heard a very slight but detrimental delay.
I hope someone else has heard of this problem.... Thanks,
Matt
Old 10-26-2006
Dedicated Member
delay
PS
I recorded the metronome into the headphones and when playing the track back with the metronome, the delay is about 900-1000ms. WAY too much for adequate recording..
Old 10-27-2006
dachay2tnr's Avatar
dachay2tnr dachay2tnr is offline
One Hit Wonder
dachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond repute
This obviously sounds like latency.
What drivers are you using?
When you said you reset the buffers, did you do this in Sonar, or in the Sound Card's applet?
What does Sonar report your latency as?
I assume you are using Input Monitoring. Do you need to for some reason, or can you turn it off?
Old 10-30-2006
keith turner keith turner is offline
azimuth of new ideas
keith turner has a reputation beyond reputekeith turner has a reputation beyond reputekeith turner has a reputation beyond reputekeith turner has a reputation beyond reputekeith turner has a reputation beyond reputekeith turner has a reputation beyond reputekeith turner has a reputation beyond reputekeith turner has a reputation beyond reputekeith turner has a reputation beyond reputekeith turner has a reputation beyond reputekeith turner has a reputation beyond repute
Hi SilentSound,
Sorry to read of your problem.
Just a few things to check if you haven't already done so:
Routing-Motu audio Console
1.Motu Audio Console all inputs you enable list" From Computer "
2.Buffers are the same for both 2408's
3.Both 2408 are set to clock from internal PCI
Sonar-options
1.options>audio>driver profiles>32bit pcm left-justified
2.options>audio>advanced>synchronization>trigger and freewheel
Make sure to run wave profiler and check that your buffers match in Sonar. i.e. if you set Both Motu's to 64 samples buffer. then 64 should be listed in Sonar options>audio>driver profiles>dma buffer size.
Good Luck
Problem with Sonar 4 producer inputs gtrplyrguy Cakewalk / Sonar Forum 2 03-04-2006 15:22
Sonar 5 Producer errors fixes jmorris Cakewalk / Sonar Forum 1 03-04-2006 00:51
Sonar Producer Edition Audiohead27 Cakewalk / Sonar Forum 1 02-15-2006 12:15
If You Haven't Taken the Plunge to Sonar 4.0 dachay2tnr Cakewalk / Sonar Forum 4 08-20-2005 18:43
Sonar Producer Edition HELP! colourblind1 Cakewalk / Sonar Forum 6 03-23-2004 15:31
